Suspension lift
Discussion in '1st Gen. Tacomas (1995-2004)' started by Grammer00, Feb 24, 2016.
  1. Feb 24, 2016 at 10:15 AM
    Grammer00
    Grammer00 [OP] Member
    Will
    Stock 04 tacoma 6 cylinder Manual
    Does any one know of a reasonable priced suspsension kit that will level a 1st gen and and add 2 inches
  2. Feb 24, 2016 at 10:27 AM
    Digiratus
    Digiratus Adventurer
    Roaming the PNW
    The RedHead
    Define 'reasonable priced'. What is your budget?
  3. Feb 24, 2016 at 10:39 AM
    Grammer00
    Will
    Below 5 hundred not sure if thats enough or not
  4. Feb 24, 2016 at 10:44 AM
    Digiratus
    Roaming the PNW
    The RedHead
  5. Feb 24, 2016 at 7:54 PM
    CodeSeven
    CodeSeven LOC: 33.781461, -115.867251
    Serge.
    Coachella Valley
    '00 Taco 3.4 4x4 TRD ( <3), '06 Taco Prerunner 4.0 (totaled)
    3 inch lift. bluetooth stereo. blue transparent skulls shift knobs
    I went with a daystar spacer kit. 160 parts alone. me and a toyota mechanic put it together reasonably easily for our first time ever seeing something like this. labor was free. peeps here will warn you to stay away from something like this, don't know why. but I haven't had any issues with it since i got it 3 years ago and I've been going on some pretty rough trails in the mountains and deserts like ocatillo wells. so long as youre not going places made for a $500k rig, youd be find using one of these.
