Suspension part needed
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Unchained 5150, Nov 7, 2014.
  1. Nov 7, 2014 at 10:35 AM
    Unchained 5150
    Unchained 5150 [OP] " Sprinkles "
    Rick
    Auburn Ma
    I have the adjustable 5100's in the box, and a new set of bushings, and a new pair of TRD Sport front coil springs. Trying to figure out what the top piece I would need to put it all together? Shock mount top I believe. Anyone have a link to that correct part. And I have that part and can all be compressed and put together correct?
  2. Nov 7, 2014 at 10:46 AM
    Large
    Large Red
    Use the top plates from the OEM shocks / coils
  3. Nov 7, 2014 at 11:01 AM
    Unchained 5150
    Rick
    Auburn Ma
    Trying to have it all assembled while my current truck is still together. So anyone have a link
  4. Nov 7, 2014 at 1:06 PM
    Unchained 5150
    Rick
    Auburn Ma
    So I just realized from a friend one spring has a big yellow and blue on it, and the other one doesn't. Does anyone know which one goes on the Drivers side? These are from a 2010 TRD Sport.
  5. Nov 8, 2014 at 6:56 AM
    Unchained 5150
    Rick
    Auburn Ma
  6. Nov 8, 2014 at 8:07 AM
    JPA2002
    JPA2002 Well-Known Member
    Roanoke, VA
    2020 DCSB TRD Pro
    You can get the moog setup from Advance Autoparts and it has everything you need to have two complete setups.
    Jon
  7. Nov 8, 2014 at 10:52 AM
    Unchained 5150
    Rick
    Auburn Ma
    Can you link a part number maybe? Just went on the site and could find nothing. Put 2014 in instead of 2015 in case the site wasn't up to date yet. And still no matching products
  8. Nov 8, 2014 at 11:16 AM
    Unchained 5150
    Rick
    Auburn Ma
    So I found 2 of them on Rock Auto, which one should I get?
    SM5640 KYB looks kind of plastic and cheap.
    907921 Monroe strut mount looks all metal
  9. Nov 8, 2014 at 11:36 AM
    JPA2002
    Roanoke, VA
    2020 DCSB TRD Pro
  10. Nov 8, 2014 at 11:48 AM
    Unchained 5150
    Rick
    Auburn Ma
    Thanks when I put that number in it states it does not fit my vehicle
  11. Nov 8, 2014 at 11:55 AM
    JPA2002
    Roanoke, VA
    2020 DCSB TRD Pro
    Hmm. It should work. Maybe someone else will chime in shortly. Also, make sure to search for a coupon, as advance has tons of them that will save you some money.
    Jon
  12. Nov 8, 2014 at 12:00 PM
    Unchained 5150
    Rick
    Auburn Ma
    Thank you though I appreciate it. You would think as much as the conversation of lif is talked bout on this site. More people would chime in and help.
  13. Nov 8, 2014 at 12:19 PM
    T4RFTMFW
    T4RFTMFW #DBBeer
    Probably because most people would give the same advice Large did.
  14. Nov 8, 2014 at 1:21 PM
    Unchained 5150
    Rick
    Auburn Ma
    Probably because if people read it correctly, these are extra springs, 5100's, and bushings. ( Trying to have it all assembled while my current truck is still together. ) As quoted above. Wanted to get them all compressed to make it easier to for the person on here that said they would help with the install. So I would just help unhook it all, pop the factory ones out, put the new already compressed assembly in. That's why I am not using the stock top plate.
  15. Nov 8, 2014 at 2:00 PM
    Germ
    Germ Master Navigator/Zipper Operator
    Arizona
    2013 TRD OR DCSB
    I'll sell you my stock coilovers for cheap and you can vulture the top mounts off of them.
  16. Nov 8, 2014 at 3:21 PM
    Unchained 5150
    Rick
    Auburn Ma
    Whats cheap?
  17. Nov 8, 2014 at 3:30 PM
    Germ
    Arizona
    2013 TRD OR DCSB
    PM'd
  18. Nov 8, 2014 at 3:37 PM
    el tardo
    el tardo Well-Known Member
  19. Nov 8, 2014 at 3:37 PM
    Large
    Large Red
    I guess I don't understand. You're obviously going to swap the front struts out, why not take them all to a shop, pay the $40 and have them assemble them or just do it yourself and rent a spring compressor?
  20. Nov 8, 2014 at 3:44 PM
    08TacoTrD
    08TacoTrD Well-Known Member
    08 TRD Offroad
    Not sure if there's a difference in the 14's but I just bought the Moog set p/n K160266 from Rock Auto for my '08. It has everything and when I finally get my front shocks I can install them and give a review.
