Suspension problem, many new OEM parts + video link
Discussion in '1st Gen. Tacomas (1995-2004)' started by cjaz, Aug 14, 2021.
  1. Aug 14, 2021 at 8:46 AM
    cjaz
    cjaz [OP] Well-Known Member
    chris
    philly
    I had posted recently about overhauling my front suspension since the truck has 204k miles.
    Now something or things are not installed correctly or there is a problem with the truck that hasn't been identified yet. The suspension is extremely soft as though the shocks are not providing any dampening at all. When you push down on the bumper it feels like the shocks are blown, there is very little resistance. One thing that I remembered one of the mechanics say yesterday was that he had to lift the the LCA up to install the assembled strut. That doesn't make sense to me. I would think that the LCA would have to be held down with a pry bar to install the lower strut bolt. Did he reinstall the LCA's in the wrong position and now there is too much distance between the upper mount and the lower bolt? I have never done any work on control arms before. Couple other data points, they took the OEM shocks and springs off and put in some quick struts to just see if that would make a difference. One side was closer to normal and the other side was still terrible. They told me the quick struts were a bit longer than the OEM setup. When they put the OEM setback back on I had them switch right and left to see if the springs perhaps were installed on the wrong side. This seems to have made it worse.
    Here are a couple short video links
    Front View: https://youtu.be/og1luBV2LNU
    Side View: https://www.youtube.com/watch?v=2d8OlSAB8Dg
    This is a list of what I had a mechanic replace for me. All parts are OEM from one of my local Toyota dealers near Philadelphia. The truck is a 2003 with TRD package. Dealer Verified all parts are correct using my VIN. I triple checked many of them and didn't see any issues.
    Upper control Arms (complete arms with new bushings) (48630-35030 and 35050)
    Lower control Arm bushings (48061-35040 and 35050)
    Springs ( 48131 AD010 and AD040)
    Shocks (48510-A9050)
    Upper strut supports (48609-35010)
    Upper Ball Joints (43310-39016)
    Lower Ball Joints (43310-39016 and 43330-39556)
    Sway bar links (48820-35040 and 48810-35020)
    Sway bar bushings (48815-35090)
    Gear assembly insulator (45517-35010)
    All new Cam bolts (4840935050 and 4845235020)
    New mount bolts (9008011283)
    New upper control arm Bolts and nuts (90105-14105 and 90179-14062)
    New passenger side CV Boot kit (04438-04021)
  2. Aug 14, 2021 at 9:02 AM
    CrippledOldMan
    CrippledOldMan Well-Known Member
    David
    Salisbury North Carolina
    2003 TRD Crew Cab
    None
    if you push down and let go, how many times does it rebound before it stops.
  3. Aug 14, 2021 at 9:54 AM
    cjaz
    chris
    philly
    It bounces more that it should. It should settle quickly with all brand new parts.
  4. Aug 14, 2021 at 10:32 AM
    Digiratus
    Digiratus Adventurer
    Roaming the PNW
    The RedHead
    2002 XtraCab TRD 4x4 SCv6 AutoTrans With Lots of Mods ADS COs w/Compression Adjusters Camburg Uniball UCAs Whiteline Lower Control Arm Bushings Kartek 7" Limit Straps Plastics Guy Front Bumpstops Custom Alcan Springs +800 lbs +3" ADS 10" Stroke Triple Bypass w/Resi Rear Shocks Custom Rear Shock Relocate All-Pro U-bolt Flip w/Timbren Bumpstops 4.88 Nitro Gears ARB Front Locker ARB Twin Compressor Black 17x8 Konig Countersteer Type X 285/70r17 Falken A/T3w Gunmetal 16x8 SCS Ray10s 255/85r16 Maxxis Bighorns Limited Edition (Relentless) Elite Front Bumper Smittybilt X2O 10K Winch Diode Dynamics SS3 Sport Selective Yellow Fog Lights in the Bumper Diode Dynamics SS3 Pro 4,000 Kelvin SAE Driving Lights with Clear Lenses on the Bumper Morimoto D2S Projectors XB35 Ballasts + 4300K Bulbs Badland Sliders FrankenFab Tire Carrier Swingout bumper w/kitchen BudBuilt Front & Bellypan Skids BAMF Rear Diff Skid Dometic CFX 55im Fridge/Freezer Alpha II Hardshell RTT Badland Custom Bed Rack Denso 210-0461 105 amp alternator Dual Northstar 24F AGM batteries BlueSea 7622 ML-ACR Battery controller Peak DBI Dual Battery Voltage Monitor Magnuson MP62 Supercharger w/URD 2.2" Pulley Haltech Elite 2000 Standalone ECU Denso 650cc Fuel Injectors Doug Thorley Headers Aeromotive Stealth 340 Fuel Pump TransGo A340F Reprogramming Shift Kit 2.5" Magnaflow Hi-Flow CAT Magnaflow 18" Muffler w/Vibrant Resonator 13WL Brake Calipers Braided Steel Brake Lines ScanGauge II OBDII Scanner Kenwood TM-71A Dual Band Ham Radio Larson 70CM/2M Antenna Uniden 520xl CB radio 3' Firestik Adjustable tip antenna Pioneer DEH-P9400BH HU Alpine Amps & Type R components (F) and coaxials (R) Wet Okole Seat Covers Weathertech Digital Liners Deck Plate Mod 1" Diff Drop Carrier Bearing Drop
    What are the specs for your truck? Model year? Cab type? Regular, extra or double cab? TRD package? v6 or 4 cylinder?
    And what was the old suspension? Any aftermarket pieces?
  5. Aug 14, 2021 at 10:33 AM
    cjaz
    chris
    philly
    I just took out the drivers side strut, and measured the distance between the upper mounting points and the bolt on the LCA and got approx 19". I measured the OEM strut from the center of the lower bolt and and upper mount and got approx 19". It lines up almost perfectly. I might need to push the LCA down 1/8 or 1/4 inch to reinstall. Hopefully someone can comment. This doesn't seem right to me.
  6. Aug 14, 2021 at 10:35 AM
    cjaz
    chris
    philly
    2003 TRD, extended cab, V6, manual trans
  7. Aug 14, 2021 at 10:37 AM
    cjaz
    chris
    philly
    Does it make any sense to loosen the UCA bolt, jack up the LCA, then retighten the UCA bolt and try to close that distance or will it still just droop to the same spot?
  8. Aug 14, 2021 at 10:49 AM
    Digiratus
    Roaming the PNW
    The RedHead
    I don't think this a lower control arm issue. The 'soft' ride is either from the new coil springs or the shocks themselves. In your video I can hear the shocks working, they make a slight hissing noise, though one side was a little louder than the other.
    I am wondering about the coil springs that were used. They could be to light for the truck's front end weight.
    When I put the part numbers you listed into the OEM parts house I use, they say they are not the correct ones for my truck which is an '02 extra cab v6 4x4 TRD.
  9. Aug 14, 2021 at 10:58 AM
    Digiratus
    Roaming the PNW
    The RedHead
    As for the distance between the upper coil bucket mount and the lower shock bolt mount, 19" is reasonable. Especially with new OEM, rubber lower control arm bushings installed. You might find that will increase a little with more mileage on them.
    I asked this earlier, but you may have missed it. What was the old suspension? Any aftermarket pieces?
  10. Aug 14, 2021 at 11:00 AM
    cjaz
    chris
    philly
    can you post a link to what you see for those parts?
    Supposedly the LCA bolts weren't tightened all the way until the truck was on the ground, but maybe they didn't leave them loose enough to make a difference when the truck was on the ground. But then again the truck was aligned after this, so wouldn't they adjust those LCA bolts unless the truck needed no adjusting. I wouldn't bet the truck was aligned perfectly after all that work.
  11. Aug 14, 2021 at 11:02 AM
    cjaz
    chris
    philly
    The old suspension was some napa quick struts. They were put on as a temp solution and ended up being on there for nearly 30k.
  12. Aug 14, 2021 at 11:17 AM
    Digiratus
    Roaming the PNW
    The RedHead
    To identify the correct part numbers for my truck I use https://partsouq.com or https://www.toyodiy.com/parts/
    Both of these places have a place to enter your vin# and will then only offer the correct part #s for your truck.
    Today I used https://www.toyotapartsdeal.com/. Keep in mind that I have entered my vin# there also so they can tell me if a given part number fits my truck.
    Try this with your vin# to see what you get.
  13. Aug 14, 2021 at 2:28 PM
    cjaz
    chris
    philly
  14. Aug 14, 2021 at 3:34 PM
    Digiratus
    Roaming the PNW
    The RedHead
    It is very interesting that your vin says your truck was built in Sept 2000. Is it really an '03 model? You sure it's not an '01?
    For reference, here's my toyodiy page. As you can see, different part #s from yours. Makes me wonder what the difference is. Are you a 4x4 or a prerunner? I don't see how the transmission type would make a difference but maybe that is it.
    https://www.toyodiy.com/parts/p_U_200111_TOYOTA_TACOMA_VZN170L-CRPDKAB_4803.html
  15. Aug 14, 2021 at 6:30 PM
    cjaz
    chris
    philly
    Here is my page with my VIN. i was searching under part number before. yes my truck is a 2003. The part numbers I have seem to be correct. I mean the dealer when through this with my VIN a few times. If I have the wrong parts they really screwed up.
    https://www.toyodiy.com/parts/p_U_200302_TOYOTA_TACOMA_VZN170L-CRMDKAB_4803.html
    I loosened the control arm bolts a bit and put it back on the ground and tightened them up to see if that would make a difference and it did not.
  16. Aug 16, 2021 at 7:38 AM
    Boone Wesley
    Boone Wesley Well-Known Member
    Boone
    LA 818
    01 4D 4WD Limited
    This is like a kristi with a K thread- you're basing all this off the ol' push the bumper down test? Soft is the only symptom?
  17. Aug 16, 2021 at 9:27 AM
    cjaz
    chris
    philly
    when it is that soft with me just pushing on it, imagine hitting a bump at 60-70 mph. It doesn't ride right on the road. I've been driving for for 32 years. I'm not 16 years old.
  18. Aug 16, 2021 at 4:20 PM
    Rastopher
    Rastopher Well-Known Member
    Ras
    Portland, Oregon
    2002 2.7 4x4 reg cab automatic
    Utility Shell, Ultra 062 wheels, bilstein 5100, OME880 coils, wheelers progressive AAL, Whiteline LCA bushings, poly sway bar and steering rack bushings, led dash cluster, shifter bushings, 4runner mirrors.
    Have you gotten it aligned properly? Not just a toe’n go? Also, what behavior/ performance exactly are you looking for?
  19. Aug 16, 2021 at 6:06 PM
    cjaz
    chris
    philly
    yes it was aligned properly at a reputable shop that only does alignments.
  20. Sep 6, 2021 at 7:46 AM
    cjaz
    chris
    philly
    I replaced the new OEM springs and shocks, with Bilstein 6112's. Very noticeable difference. I still can't explain why the oem parts were so bad. Maybe they don't make them like they made them 20 yrs ago.
