Suspension problems
Discussion in '1st Gen. Tacomas (1995-2004)' started by Dl1998, Oct 30, 2024.
  1. Oct 30, 2024 at 4:42 AM
    Dl1998
    Dl1998 [OP] Member
    Will my rack and pinion bushing and lower control arm bushings cause my truck to not aline properly I maxed out my cams yesterday and the passenger side looks good but my driver side still has a noticeable camber issues also one tie rod looks to be out more than one side could this be all cause by my wore out bushings
  2. Oct 30, 2024 at 8:20 AM
    Andy01DblCabTacoma
    Andy01DblCabTacoma Well-Known Member
    Andy
    San Diego, CA
    01 Double Cab v6 4x4 TRD
    F: Kings SPC, R: 5100s+J59s. Custom armor.
    Bushings can play a role in alignment issues. But they would have to be really bad to have that much of an effect. Usually you would be able to align the vehicle, but it wouldn't stay in alignment. I have seen your other threads- Usually people Bump, or To The Top (TTT) their existing threads- not start new ones, so that others can see the whole story.
    I think in your case, you need to take the truck to a shop and get it aligned. DIY alignments are tricky at best.
