Suspension Questions
Discussion in 'Suspension' started by DevilDogTacoma, Jun 23, 2011.
  1. Jun 23, 2011 at 10:08 AM
    DevilDogTacoma
    DevilDogTacoma [OP] Well-Known Member
    Maryland
    2010 Tacoma V6 DCSB
    Flowmaster 40 Muffler, 15% Front Window and Windshield Sun Strip Tint, Antennax 14" Antenna, OME 3" Lift w/AAL, SlimCubby 6000K HID headlights and foglights, Thule tailgate pad for surfboards, 285/70/17 Nitto Terra Grapplers on 17x9 XD Addicts, LED map, dome and tag lights
    Hey guys, I'm pretty new at doing mods on my truck. I've done mostly cosmetic sort-of stuff myself, but I want to put a lift on it just to help with the ground clearance, correct the rake, and make my truck look a little more aggressive. I do just a little bit of off-roading, so I don't need anything really serious.
    If I get this lift:
    It's basically the OME 884 front coils, Toytec plate spacers for 3" front lift, and Toytec AAL for the rear. It says the AAl is a 2" lift. Since the front lift would be 3" and the back 2", that would correct the rake, right?
    Also, with a small lift like this, would I still have to put UCAs on the front to keep it from weaving around during highway driving?
  2. Jun 23, 2011 at 10:12 AM
    DeeKay21
    DeeKay21 Lieutenant Dan.
    Nevada/Utah
    06' TRD Sport 4x4
    Your gonna want to go with the 885's since you are a DC and have more weight to your truck. Yes the 3" of lift up front and 2" in the back will make you sit level. They say anything above 2.5"s of lift, you should go with aftermarket UCA's to get the alignment back in factory specs but there is a lot of guys that are running with their stock UCA's.
  3. Jun 23, 2011 at 10:12 AM
    Pugga
    Massachusetts
    '19 Ford F-250 6.7 SCrew
    F-250 Land Yacht Mod
    I believe the 885 coils are recommended for a double cab. Measure your truck from the center of the hub to the fender and see what the factory rake is and make your determination from there. "Level" seems to be in the eye of the beholder, level to me (as measured) looks nose high in my opinion which is why I'd say measure yourself and go from there. At 3" of lift up front, you may or may not need new UCA's. You're right on the border line where some are ok, some require new UCA's.
    Also, assuming you're getting new struts to go with those coils also? I don't think you'd want to run them on the stock struts.
  4. Jun 23, 2011 at 2:40 PM
    DevilDogTacoma
    Maryland
    2010 Tacoma V6 DCSB
    Okay, now what about doing Bilstein 5100s on all four wheels set at 0.85" or 1.75"? Would I have to upgrade the coils too, or can I keep them stock?
    I know I sound stupid asking all these questions, but I figured I'd try to learn from you guys who have already done this stuff.
  5. Jun 23, 2011 at 2:48 PM
    DeeKay21
    Nevada/Utah
    06' TRD Sport 4x4
    The 5100's only raise the front end and they are supposed to work with the stock coils up front. You would need an AAL or block to raise the rear end.
  6. Jun 23, 2011 at 3:39 PM
    DevilDogTacoma
    Maryland
    2010 Tacoma V6 DCSB
    Gotcha, thanks for the help fellas.
