Suspension TSB & Leveling Kit
Discussion in '2nd Gen. Tacomas (2005-2015)' started by braggman7, Dec 5, 2009.
  1. Dec 5, 2009 at 4:52 PM
    braggman7
    braggman7 [OP] Well-Known Member
    Athens, GA
    '10 Double Cab TRD Sport 4WD
    Ok, I have a '10 Double Cab 4WD Sport. I tow a trailer often for work, so I am considering the rear leaf spring TSB. The only thing I'm concerned with is the look of the truck afterwards. I'm assuming I can get a leveling kit for the front to get her back to the way I like her? For those of you have had it done, what size kit would I need, or does the TSB really even move the back end up a noticeable amount? Is a leveling kit a DIY job, or is it best to have the pros do it? Any help's awesome.
    Thanks,
  2. Dec 5, 2009 at 4:54 PM
    Incognito
    Incognito No better friend, no worse enemy
    VA
    2012 Pyrite AC TRD OR
    Spacer lift, bumper stickers, ejector seat, etc.
    I wouldn't go with a leveling kit... I'd much rather go with Bilstein 5100 shocks up front.
  3. Dec 5, 2009 at 5:00 PM
    focotacoma
    focotacoma Well-Known Member
    Fort Collins
    07 Speedway Blue 4x4 TRD off-road
    Im getting there......
    Hey man my dad added TSB 9sliff leafs) and a leveling kit when he first got his TRD Sport long bed... He liked how it looked but not how it worked.
    You bought a sport to some extent because of the improved ride quility over the offroad I assume so....
    He felt that the ride quality should be mantained
    Using an bag setup in the rear gives you adjustablity of ride and ability to haul various weights while maintaining quality of ride.
    For example with a TSB (stiff leaf) motorcycles and light loads on trailers feel very jumpy as does the rear of the truck.
    with a heavy load the springs get weighted and the ride is like constant bottoming cause the bed weight wont allow any more suspension give!!!
    With airbags problem is solved with the use of a compressor and you dont need a leveling kit cause when your not using a trailer you release most of the air pressure :)
    HOPE THIS HELPED
  4. Dec 5, 2009 at 5:15 PM
    TRICOMA
    TRICOMA Tacoma with the TRI package
    Tri
    Carlsbad, CA
    2010 Tacoma DC SB 4x4 TRD Off Road
    King Off-Road Shock Coilover 2.5 with Resi in the front. King Off-Road Shocks 2.5 with Resi's for the rears, Rear Spring TSB, KMC XD Enduros 16x8, Black Vinyl Fenders, Bed compartment locks, Cobra 19 DX IV with Lil Wil mag mount antenna, CoverKing Seat covers front and rear, Built Right UCAs, Aluminess Expedition Bumper, GY Wrangler MT/R with Kevlar 265/75-16, Custom hybrid style rock sliders.
    I agree with Colton, Don't get a leveling kit when you can get 5100s for not much more and your truck will ride much better. You can get 5100s all the way around from Down South Motorsports who is a vendor here. The fronts are adjustable so just move them up a bit and you will be all set. I have the Rear Leaf TSB on my 2010 and it sits higher in the back for sure. I am getting King Off Road Coilovers to fix that. Good Luck.
  5. Dec 5, 2009 at 6:26 PM
    braggman7
    Athens, GA
    Thanks guys,
    I have the TRD Sport, so do I already have these? Also, Tricoma, do you have pics of what the post-TSB rake looks like?
  6. Dec 5, 2009 at 6:34 PM
    focotacoma
    Fort Collins
    no you dont have 5100s you have base blitsen shocks that come with the trd package the 5100s are ome and are a really good value...you can also get up to 3 inches of lift with them
  7. Dec 5, 2009 at 6:42 PM
    60guy
    60guy BADASS
    Dustin
    Maryland
    2017 Limited Double Cab
    I have a 10 DC TRD Off Road and am getting the TSB spring done on Monday. I'm planning on adding the 5100s set to .85. I think that should just about give it the stock rake again.
  8. Dec 5, 2009 at 6:43 PM
    focotacoma
    Fort Collins
    you would be correct
  9. Dec 5, 2009 at 6:49 PM
    braggman7
    Athens, GA
    So would yall recommend just getting 2 front 5100s or would it be best to go ahead and get all 4?
  10. Dec 5, 2009 at 6:51 PM
    Incognito
    VA
    If ya have the money, go ahead and get all 4. The ride will be somewhat better also with the rear Bilsteins. Good luck!
  11. Dec 5, 2009 at 6:59 PM
    Juggernaut
    Juggernaut Captain
    Sacramento
    18 PreRunner TRD OffRoad DCSB
    Make sure you say you are a TW member, you get a discount!
  12. Dec 5, 2009 at 7:05 PM
    braggman7
    Athens, GA
    If I get them from where?
  13. Dec 5, 2009 at 7:45 PM
    Incognito
    VA
