Suspension Upgrade Question and Comments
Discussion in 'Suspension' started by mikewho, Feb 11, 2012.
  1. Feb 11, 2012 at 7:28 PM
    mikewho
    mikewho [OP] Well-Known Member
    NorCal
    07 DCSB
    Bilstein 5100's, OME 885x's, Toytec 1.5 AAL's, shorty antenna x, Trd sport hood, bed extender, ProComp7098's, BFG 275's, K&N filter, black anzo led tails, OEM roof rack, sock monkey bed decal, extra d rings, weathertechs
    Planning on upgrading my suspension to Bilstein 5100 on all fours and setting the front to 2.5. Thats the only part I'm positive about so far.
    I also plan on adding Toytec AAL either 1.5 or 2 for the rear. (anyone recommend one or the other?) Last I'm looking into Spidertrax spacers. I'm currently running stock wheels with 265/75 tires.
    My first question is if I'll have any rubbing with the billies and/or with billies and spacers together?
    Looking for any comments from anyone running a similiar setup.
    My truck is mostly used for daily driving with little to no off-roading. I've been reading that new UCA's are mainly needed for lifts over 3, but also wanted to verify from someone that I shouldn't need them for the setup I'm planning.
    Thanks!
  2. Feb 11, 2012 at 7:30 PM
    1337Taco
    1337Taco Sold all 3
    Kevin
    NorCal
    2012 4x4
    Kings
    I would go for the 1.5" AAL for an even look, 2" if you want a little rake. I would not put wheel spacers on, no need for them, you will be much more likely to rub.
  3. Feb 11, 2012 at 7:39 PM
    mikewho
    NorCal
    07 DCSB
    Thats the direction i was leaning towards, since im not too crazy about the rake look
  4. Feb 11, 2012 at 7:48 PM
    Irish020
    Irish020 Well-Known Member
    Phil
    Pennsylvania
    '05 Tacoma TRD Sport 4 Door Longbed
    ARE Hard Tonneau Cover Flowmaster American Thunder Super 50 Series Stainless Dual Exhaust Toytec Ultimate 3" w/ UCA's
    I'm running this set up from Toytec (Ultimate) w/ the AAL, Diff spacer, sway bar relocator, and new UCA's. Running 285/75/16 with no rubbing after removing front mudflaps and a slight shave of the iner fender with a grinder - not visible....
  5. Feb 11, 2012 at 7:56 PM
    mikewho
    NorCal
    07 DCSB
    Thanks for the info wolf - i know some say yes on the uca's while others are saying no.
    Nice ride irish. Your setup goes to 3 right? Is that where u have it set at?
  6. Feb 11, 2012 at 8:00 PM
    mikewho
    NorCal
    07 DCSB
    Also wondering where u bought it? If i do need the uca's i may end up getting a similiar setup as it wouldn't cost too much more
  7. Feb 11, 2012 at 8:04 PM
    Irish020
    Phil
    Pennsylvania
    Toytec - They are a vendor here on TW and give us a price break...
    I'm between 4 and 4 1/2 inches with the factory settings of the Eibach/Bilstein coilovers and the wheel/tire combo I have...from stock...
