Suspension
Discussion in '1st Gen. Tacomas (1995-2004)' started by stucksucksnayota, Feb 8, 2012.
  1. Feb 8, 2012 at 8:26 AM
    stucksucksnayota
    stucksucksnayota [OP] Well-Known Member
    Barry
    Fort Smith, Arkansas
    14 Taco 4x4 TRD Sport DCSB
    OEM roof rack, Shorty antenna (eBay), soft tonneau cover, K&N drop in air filter, bed mat, interior LED lights, 5100's, MT tires to come soon!!!
    So i know this has been talked about alot but i really can't find the exact answer im looking for.
    I have an 01 double cab 4x4 taco with 240k miles on it. Time to redo my suspension.
    But i am on a budget and dont have the funds and dont want to go out and buy all new stuff and blah blah. Yea i would like to, but my plan is to drive it for a year or to more then ether sell it or build it to rock crawl.
    I have a buddy who's parents own a scrape yard so i have access to alot of different car and car parts for very cheap.
    Has anyone build springs for their tacoma out of leaf springs from another vehicle? I know this has been done before but i cant find exactly what im looking for. I don't want to lift the truck or anything like that. Just want a better ride.
  2. Feb 9, 2012 at 7:41 AM
    stucksucksnayota
    Barry
    So heres another question. I want to try and retain a stock ride.
    Should i go with chevy 63" springs or find some 4runner springs?
  3. Feb 9, 2012 at 7:42 AM
    JDMcQ
    JDMcQ Well-Known Member
    The Mushroom Capital of the World
    I have nothing to add, but I am interested in the answer.
  4. Feb 9, 2012 at 7:43 AM
    misterdmac
    misterdmac Well-Known Member
    Doostin
    In or around the truck
    '97 2.7L DLX
    You will not be able to improve ride quality with parts from a junkyard. If you can't find a Taco to pull from, you can try pulling individual leafs out of other trucks and using them as an add-a-leaf, which might fix your sag but it's not going to be plush. That ride quality you're looking for will cost you $1500, and even then, it's a pickup. Gonna beat you to shit no matter what ;)
  5. Feb 9, 2012 at 9:45 AM
    stucksucksnayota
    Barry
    I disagree with this. I have read about alot of people who have used different springs (ie chevy 63" springs) and have had a very good out come. Yea its a truck and it will never ride like a cadillac but anything has got to
    Be better then a set of springs with 230k miles on them.
    I think chevy 63" are the way to go but the negatives are that you have to do some light moding and it adds some lift to your truck which i wouldn't mind but i don't want it to look "goofy" with a 3" lift and 265 75 tires. This is why i had the 4runner springs thought, but i assume they are probably the same leaves that are on the tacomas.
  6. Feb 9, 2012 at 9:49 AM
    nfs257
    nfs257 Well-Known Member
    DFW
    She gone
  7. Feb 9, 2012 at 10:08 AM
    TacoMX
    TacoMX TW's Official anti body-lift pundit
    Jonathan
    Deltona, Florida
    I have to agree with you.
    Revamping an old pack like 4WD did using springs form another truck will greatly improve ride over a badly worn leaf pack. Yes. brand new leafs made for your truck will ride better...but if you are on a budget the option linked above is a good one.
    As for the front, you will want to purchase new coils (OME or toytec) and new struts. (OME and bilstein being the best strut/shock options)
    It all depends on if you want lift, and how much. Then we can point you in the best direction.
    And avoid 4 runner springs, They will have the same sag issues as the taco springs. And maybe worse because the increased weight of the 4runner.
  8. Feb 9, 2012 at 10:11 AM
    stucksucksnayota
    Barry
  9. Feb 9, 2012 at 10:13 AM
    stucksucksnayota
    Barry
    I'm not against a lift as long as I can keep my same tire setup and it not look like a truck with a lift and tiny tires lol
    As far as the coils and the bilstein shocks go I have a quick questions about those. I have read about people buying the 5100 I think is the number and then it lifting their truck 2.5" or so. Is this an adjustment made on the shock or do you need to buy different coils depending on how high you want the lift to be?
    This is probably the route I will end up going after I install the chevy leafs in the rear, I will buy new coils and struts for the front to adjust for the height change in the rear of my truck!
  10. Feb 9, 2012 at 10:32 AM
    JDMcQ
    A 3" lift and the 265/75/16 tires will look just fine. I ran this set up for a few years and I prefer it over the 285/75/16 I just installed. Way fewer clearance issues with the smaller tire and you only give up roughly .5" ground clearance.
  11. Feb 9, 2012 at 10:35 AM
    TacoMX
    Jonathan
    Deltona, Florida
    The 5100's are adjustable for lift up to 2.5'' using preload, and your stock coils.
    That is not recommended especially since your stock coils are probably shot at 240k miles.
    The 5100's have three positions, stock, 1''lift and 2.5'' of lift. Those are used w/ the stock coils.
    People use the 5100's with toytec coils to give 3-3.5'' of lift with the shocks set on the stock position, so the coils do the lifting.
    OME makes coils that are designed to be used with their struts. They have several coils for our trucks, the most popular are the 880s (1-2'' of lift) and 881's (2-3'' of lift). There are others for trucks with bumpers/winches.
    The amount of lift these coils also depend on what engine and body you have. ie...if you have a 4 banger and a regular or extended cab...you will get more lift because your truck weighs less. A V6 or double cab will get less lift.
    I see you have a v6 double cab, so if you chose OME struts and coils the 881's would be the way to go getting you around 2'' of lift, unless you plan on adding a winch and o/r bumper the 882's would be a better choice.
    The eibach/toytec coil and 5100 combo will get you around 3'' of lift.
    Downsouth motorsports, wheelers offroad, and toytec are the prefered retailers on TW.
  12. Feb 9, 2012 at 10:44 AM
    x2468
    x2468 Well-Known Member
    '02 TRD 4wd V6 Xcab Sr5
    265/75 should look fine. if you had 265/70s i'd say not so much....
  13. Feb 9, 2012 at 11:28 AM
    4Wheelin4Banger
    4Wheelin4Banger Supercharged Toyman
    Randy
    Ferntucky, NV Halfway between Reno & Falabama
    2011 4x4 Access Cab Supercharged Silver State Edition 245WHP
    3" OME lift 885s & Dakars riding on 33" KM2s
    There's a reason why they call it a junkyard it's full of junk.
  14. Feb 9, 2012 at 11:35 AM
    stucksucksnayota
    Barry
    So your telling me that if i got springs off of a 2011 chevy pickup that the front end was totaled that they would be junk?
  15. Feb 9, 2012 at 11:38 AM
    stucksucksnayota
    Barry
    Thats perfect just what i needed to know!
    My only other question and i will probably get grilled for this but say some one didnt want to pay for top of the line shocks and struts such as bilstien is there any other good brands out there where you could save a little bit on that stuff for a rig thats only gonna be drove on the road.
    I know i know lol you get what you pay for but just a thought.
  16. Feb 9, 2012 at 9:23 PM
    TacoMX
    Jonathan
    Deltona, Florida
    All four bilstein 5100's from DSM is $309 + the TW discount (5%) + plus free shipping.
    Thats pretty cheap....less than $75 per shock.
    I know OME is significantly more espensive. If you are on a budget, go Bilstein.
  17. Feb 9, 2012 at 10:30 PM
    stucksucksnayota
    Barry
    Ya thats not to bad at all for such a good shock.
  18. Feb 10, 2012 at 1:07 AM
    4WD
    4WD cRaZy oLdmAn
    Doug
    Lakeside, Ca / Gardnerville, Nevada
    2004 DC TRD 4x
    Grey wire MOD, deck plate, diff breather MOD, 2nd gen. OME 883# on Tundra 5100's, OMD custom 3" leafsprings, rear shock relocation, Ivan Stewart TRD rims w/285/75/16's, '02 bumper MOD, Famous Fabrications sliders , LED interior/exterior lights, bed bar, Custom tube bumper, Old school KC day lighters,Red Ring 8" HID flood, Kenwood vhf 2M.. umm some other shit I'm forgetting right now
    Oh really ???? Guess I'll take mine off & toss'em I'll tell others that have done this to do the same, with all due respect, more wrong you could not be....:cool:
    & why would he add more crap springs from a Toyota ? Thats what we're getting away from...
    Awww c'mon Randy, I expected better from you....:p:p
  19. Feb 10, 2012 at 1:24 AM
    4WD
    4WD cRaZy oLdmAn
    Doug
    2004 DC TRD 4x
    Yep , these are about the biggest pieces of shit that a junkyard ever spawned....:rolleyes::p
  20. Feb 10, 2012 at 1:30 AM
    4WD
    4WD cRaZy oLdmAn
    Doug
    2004 DC TRD 4x
    more POS junk springs, look, they don't even have an arc to them....
    please make it stop !!
    crappy springs, why oh why did i EVER go to a junkyard....
