suspension
Discussion in '1st Gen. Tacomas (1995-2004)' started by socal19, Apr 5, 2009.
  1. Apr 5, 2009 at 8:52 PM
    socal19
    socal19 [OP] TACOMA03
    California
    03 tacoma pre runner
    2.5" Front spacers, 16inch wheelers steel wheels on 265-75-R16 BFG All Terrain, N-FAB prerunner bar, Flowmaster Exhaust
    hey people im getting rdy to put a suspension lift kit any ideas on what i should get
  2. Apr 6, 2009 at 7:31 AM
    TengoTaco
    TengoTaco Wish i was wheelin
    Tyler
    San Diego, CA
    2001 TRD stock
    None
    Depends on what you want. For a mild front 2-3 inch lift i recomend Old Man EMU 881 coils along with their shocks. It will give you about 2.25" of lift. The front will be about an inch higher after that. 1" toytec lift shackels or an AAL will do the trick.
  3. Apr 6, 2009 at 7:45 AM
    Ry1984
    Ry1984 Well-Known Member
    From Texas, Now Miami FL
    01' ExtCab SR5 2.7 4x4
    K&N FIPK, Billy 5100 all around, 881's in the front, Toytec AAL
    yup, definitely need to be more specific on how much lift and purpose of lift, then we can through some options at ya :)
  4. Apr 6, 2009 at 8:27 AM
    Ktaco
    Ktaco Well-Known Member
    New Brunswick, Canada
    03 Black 4x4 TRD SR5 Xtra cab.
    Grey wire mod, Deck plate mod, diff breather mod. K&N air filter. Toytec coilovers. AAL. Custom rear lift shackles. diff drop. Centerforce clutch. Superwinch LP8500 with custom "behind bumper" mount. Winch solenoid relocation with in cab winch control. 33x12x15 Duratracs. Aisin manual hub swap.
    I ordered the Toytec Ultimate Lift. Should come in later this week. I'll let you know how it turns out.
  5. Apr 6, 2009 at 11:10 AM
    socal19
    California
    yea i wanted to get like a 3inch lift front and rear or te pro comp 4" lift i do a little offroading and i just wanna make my truck a little bit bigger i aslo wanna fit at least 32s or 33s
  6. Apr 6, 2009 at 2:19 PM
    Ktaco
    I've heard the procomp kit is not so great for these trucks. If you choose to go into a drop bracket kit i would go with tuff country (5'') or fabtech (6''). There higher kits but better quality.
    I only want to run 33'' tires so thats why i settled for a smaller lift. The toytec ultimate lift will give you 2.5-3.5 inches of lift and a better on and off road drive. With the proper backspacing on the rims you can run 33's.
  7. Apr 6, 2009 at 2:28 PM
    STLharry
    STLharry Lube: It's the key to penetration.
    Harry
    VT
    Yeti Rescue Package with 270k miles
    '95-'97 camouflaged, ARB bull bar, RAT Products skid plate kit, sliders, Green Mountain Customs rear tube bumper and overland bed rack, King coilovers with Icon neoprene covers, defenestrated sway bar, OME Rear Suspension: CS046R leafs + AAL/5125 shocks/NWOR greasable hardware/U-bolt flip kit; S13WL Tundra calipers/pads/rotors, IPF H4 lenses and bulbs, IPF 968 DCG 100W lights, clapped out CB radio, Aussie-spec FJ60 inclinometer, ARB CKMA12 compressor, Superwinch S9000 with 12V Guy clock switch, 4' Hi-Lift, deckplate mod/grey wire mod/dif breather extensions, Duratrac tires, Sockmonkey bedside decals, boat cupholder, Dakine bike pad
    i have 32s and i put OME 881s with OME shocks in the front and i still have the rough country 2in lift shackles and shocks in the back that came with the truck when i bought it.
    definitely get OME (coils and shocks) and Emu Dakar (leaf springs, same company). you'll be able to fit 32s or 33s and be fine.
  8. Apr 6, 2009 at 2:46 PM
    peejay
    peejay Yep im that Peejay..
    PJ
    San Diego
    Running a tricked out rzr xp 4
    Rollin a Hemi, and wheelin a sick xp4
    I'm running the new RCD lift on my 08 4x4. Its a nice ride very smooth. But since you have a prerunner you can get away with a coil spacer. It will keep the price down and you can run 33's. When I had my 00' prerunner, I ran the fabtech coil overs with 33's. It was a nice set up. It all depends on how much you want to spend. From an inexpensive coil spacer... Or pricey Long travel.
  9. Apr 6, 2009 at 5:19 PM
    socal19
    California
    Yea I got 2.5inch spacers up front and the rear is stock I was going to run the tuff country 5inch lift but I need to buy new rims and tires cause my stock wheels won't fit? And also I was thinking about getting the 3inch tuff country lift kit and adding a 1to 2 inch body lift??
  10. Apr 6, 2009 at 7:27 PM
    ETaco23
    ETaco23 Marshall offroad Fabrication
    Evan
    PNW
    13' Pyrite Mica TRD Offroad DCSB 4x4
    Color Match Grille, Bed mat, Icon's with JBA UCA's, Dakars and 295 BFG KO2, Bora 1" spacers, Snugtop Canopy, and my "Marshall Fabrication" Rock Sliders.
    I got a 3" lift on mine and am running 33's well there actually like 32.7 or so... If you want to run 33's? A 3" lift kit will be plenty of lift!
    Make sure that your new wheels have a 4" or 4.25" back spacing. So that they dont rub any.
  11. Apr 6, 2009 at 7:31 PM
    socal19
    California
    would anybody consider getting a 3" suspension and either a 1or2" body
  12. Apr 6, 2009 at 10:06 PM
    peejay
    PJ
    San Diego
    it depends on what you want....with a prerunner you can crank the coilovers up to 3 inches(you dont have to worry about your cv's).. and you can fit 33's with no rub...and it looks good. Are u trying to tuck 35's in there?
  13. Apr 6, 2009 at 10:19 PM
    socal19
    California
    well see the thing is i like big trucks i wanna get a good lift so ui was thinking the 3" tuff country suspension with a performance acessories body lift like 1 or 2 inches will it look good i wanna go the cheapest way and i do a little offroading but not too much will i need to replace my uca's if i do it or the stock ones will workl
  14. Apr 6, 2009 at 10:26 PM
    socal19
    California
    this is also to go with what i wrote i also want it to be safe and to make sure everything is good and i will be checking the bolts for the body lift every month
  15. Apr 6, 2009 at 11:26 PM
    peejay
    PJ
    San Diego
    It depends on how much you want to spend. You can put a spacer in there and get 3 inches for under 300, but the ride will be rough( if your not always going off road, just every now and then, it could work for u) The coil overs will give you a nice ride. I would recommend putting your suspension lift on first. They riding around for about a month or so, to see if you like it. Then if you still want to go higher you can. Where in socal are u, if your close to san diego, I have friends that own or manage a few shops down here and can give you a good deal on the install or give you a recommendation. But it all really boils down to how much you want to spend... Like i said b4.. You can go really basic, or you can really go extreme. You can also by some new spindles and get about 4 inches out of it. Your 2wd, so there are alot of options out there for your truck.
  16. Apr 7, 2009 at 12:16 AM
    socal19
    California
    well if i go with the 3 inch lift do i nees to replace my uca's and if not when i do a body lift do i need to replace them then
  17. Apr 7, 2009 at 3:26 PM
    peejay
    PJ
    San Diego
    i had the Fabtech coilovers on my 00' prerunner, and didnt replace my UCA's. I as running 33x10.50 BFG's and it aligned fine, had no problems. The body lift does just that, it lifts the body up, nothing else, your suspension stays the same.
  18. Apr 7, 2009 at 3:54 PM
    socal19
    California
    yea im gonna go with the pro comp stage1 4" lift kit front and rear then i can run 33s but thanks though for all the ideas do u think this kit will be good
  19. Apr 7, 2009 at 8:40 PM
    peejay
    PJ
    San Diego
    I dont know about the pro comp stage I. never ran it.. I have the 4 inch rcd lift on mine and i like the height. Just go with what your willing to spend. have fun with it.. do your research online before you buy. Sometimes if you contact the company you can get the lift from them at a wholesale price, which is usually alot cheaper then getting it from the shop.
  20. Apr 7, 2009 at 8:44 PM
    socal19
    California
    yea im getting it from a autoshopwarehouse for 1100 dollars its kool i read it online how much was ur rcd lift kit
