Suspention upgrade
Discussion in 'Suspension' started by Healyj7, Nov 15, 2017.
  1. Nov 15, 2017 at 4:42 PM
    Healyj7
    Healyj7 [OP] 2010TRD Cape Cod
    Cape cod MA
    2010 Tacoma 4x4 crew cab...
    Led third brake light All bulbs changed to LED Blue... Bed cover Extra tie downs in bed Borla 3' aftermarket excuast Blacked out front grill Smoked front lights White turn/running lights Bed security Mod 2 inch front lift and level with bilstein front and rear shocks... 1 Inch wheel spacers BF Goodrich AT tires 270/75/17
    18A733B9-99A9-4F59-AD0A-7E63AF3908A5.jpg Currently running 5100 with a leveling kit, don’t like the ride at all. Any additional things to improve it... or start. From scratch want3 inch lift with good road and beach ride?
  2. Nov 15, 2017 at 4:43 PM
    DustStorm4x4
    DustStorm4x4 BBC 2020
    U S A
    04 Jeep LJ
    Are the 5100s set on a lift notch? How big is the leveling kit?
  3. Nov 15, 2017 at 4:45 PM
    geekhouse23
    geekhouse23 The "Liftman" - @DrFunker
    2GMGMDCSB4WDTRDFTMFW!! TL;DR
    mostly stock, grocery gettin' Prius
  4. Nov 15, 2017 at 4:46 PM
    Healyj7
    Cape cod MA
    5100 are in full extension and a 2 inch block leveling. Came with truck when I got it used ride is ruff
  5. Nov 16, 2017 at 7:07 AM
    JT@Bajakits
    JT@Bajakits Well-Known Member Vendor
    JT
    Race Trucks and Off Road Suspension
    How do you use your truck? Do you know how long the Bilstein's have been on the truck?
    As for your rear, blocks are crap and will ride rough.
    I would take those blocks out and invest in some Springs...AAL, Mini Pack or Complete leaf pack.
  6. Nov 16, 2017 at 12:11 PM
    *TRD*
    *TRD* Well-Known Member
    Carson, Ca
    Are you going fast on the beach?
  7. Nov 16, 2017 at 5:57 PM
    Healyj7
    Cape cod MA
    The Shocks and blocks to level and slightly increase hight where installed 2 years ago. I drive out on two beaches here on the cape, simple off-road trails up north and drive to NC twice a year. I looked at a leaf spring pack for the rear and a friend has 2 front FOX 2.5 coil overs for 650$ I also have the BF Goodrich AT largest tire that would fit on the 17 inch rim.
  8. Nov 17, 2017 at 4:02 AM
    3coma
    3coma my kid says my truck is "Boss"
    rob
    19 dcsb sport cement 4x4
    Swap your coils out with 885's set to zero, and put in a 1-1/2" AAL. You'll get 2-1/2"s of lift up front and about 3/4" of rake in the back.
  9. Nov 17, 2017 at 7:02 AM
    JT@Bajakits
    JT
    OP...Not sure what your budget is but the above post from 3coma is the best and least expensive option for you.
    If you are looking to spend some $$, Coilovers and Leaf pack in the rear.
    *TRD* likes this.
  10. Nov 17, 2017 at 4:36 PM
    Healyj7
    Cape cod MA
    Money is tight, after the good news of remission comes stacks of bills. But I drive out on the beach everyday
    And make trips to NC for treatment. I
    Don’t want to go so cheap it’s worse then what i had but need improvement.
  11. Nov 17, 2017 at 5:14 PM
    *TRD*
    Carson, Ca
    Sounds like Bilsteins or Fox Performance Series are good options that'll do what you'd like to do.
