Swap Steering wheel from Sport to Off Road
Discussion in '2nd Gen. Tacomas (2005-2015)' started by 06WHITETRD, Sep 18, 2009.
  1. Sep 18, 2009 at 9:17 AM
    06WHITETRD
    06WHITETRD [OP] Gotta Love my Taco!!!!
    So Cal
    06 Toyota Tacoma OFF-ROAD
    Tinted windows, window visors, XDI True Flow intake, White Devil Emblem, sport white grill, stubbie 6' antenna, TRD license plate frame,TRD Exhaust, weathertech floor front & rear, LED map/dome & license plate lights,Black Grille,T-Rex eyebrows,black Skid Plate,Lower bumper cover,Black emblems,white TRD Emblem,lamin-x yellow,Slotted & Cross Drilled rotors,Redline shocks(hood),HID 6k,more to come
    Im going to swap my steering wheel from my Off road to a SPort steering wheel. Is there goign to be any problem? like using the buttons on the steering wheel with the radio or everything is going to work when i swap n connect everything???
  2. Sep 18, 2009 at 9:24 AM
    branct06
    branct06 Well-Known Member
    Thomas
    norcross Ga. and High Point Nc.
    05 4x4 black sr5 long bed trd sport
    super 40 flowmaster turned down before rear axle, k&n intake, ipod interface, 20% 3m tint all the way around, grill craft mx series grill with 2 hella 500 behind the grill, 2 55 watt halogens mounted on uws black low profile toolbox, 3'' toytec ultimate lift kit sitting on black xd monsters and 285/65/18 BFG A/T, HID headlight kit
    be careful of the airbag
  3. Sep 18, 2009 at 9:50 AM
    T0LLPHR33
    T0LLPHR33 Well-Known Member
    S1N C1TY...(from Hilo, HI)...
    BSP TRD Off-Road
    APR X-1 | TRD CAI w/Clear Cover | TRD Short Shifter w/ TRD "RED" Shift Knob | SGII w/Blendmount| Snugtop SL w/KeyLess Entry | 5% Tint | Pop-n-Lock | Bosch Icon WB | S2K Antenna | HRM | LS 8K Projectors w/BSP HLM & 8K Fogs w/FLM | Debadged |Tinted Tails | Black Weathertechs | MX RGM & RBM | Optima Red Top 35 | Gatorback Belt |
    that's exactly what I was thinking...:confused:
    I could see if you were swapping with a steering wheel from a sequoia...1 that has both the audio and bluetooth features...
  4. Sep 18, 2009 at 9:51 AM
    higherlux
    higherlux Well-Known Member
    Blake
    middle of S.C.
    1998 tacoma 2.7l 4wd/1986 POS
    Mall crawler status
    so why do you want to do this?
  5. Sep 18, 2009 at 9:52 AM
    Brandon H
    Brandon H Well-Known Member
    Newhall, CA
    07 DC Offroad
    2017 4Runner TRD Offroad Premium. Icon stage 7, RCI skids, SCS SR8 wheels, budbuilt sliders, 285/70/17 BFG Ko2s (Old rig) 07 Taco TRD Offroad FUlly Locked, Icon Extended Travel CO's w/ remote resis., Alcan AAL's,Icon Remote Resi Rear Shocks, All Pro Front bumper w/ warn 9.5xp,winchline synthetic winch cable,All Pro IFS Skid plate, OME Shims, OME Carrier Bearing drop, Trail Gear Sliders, Yakima Load Warrior Basket, OEM Roof Rack, Hi Lift Extreme, Cobra model 19, Wilson Lil Wil Antenna, Yaesu ft-7800
    I thought they were the same steering wheels????
  6. Sep 18, 2009 at 10:01 AM
    06WHITETRD
    So Cal
    my friend is going to do the work, im not. Im just paying.
    The reason why im swapping because I want the steering wheel controls.. thats why..
  7. Sep 18, 2009 at 10:02 AM
    06WHITETRD
    So Cal
    they are not the same.
  8. Sep 18, 2009 at 10:09 AM
    T0LLPHR33
    BSP TRD Off-Road
    what controls are on the TRD Sport that the TRD Off-Road doesn't have?
    on the left you have audio functions and on the right its blank accept for the lever for the cruise control...am I missing something...
  9. Sep 18, 2009 at 10:14 AM
    derekabraham
    derekabraham Living vicariously through everybody
    TW'S Hippy Liberal
    Portland, OR
    2002 4x4 4Runner
    Stick on hood scoop from Autozone.
    Some TRD models don't have the steering wheel controls. Mine doesn't. :(
    He has one that doesn't have the controls and he is swapping for one that does.
  10. Sep 18, 2009 at 10:19 AM
    06WHITETRD
    So Cal
    thank you derekabraham
  11. Sep 18, 2009 at 10:19 AM
    derekabraham
    TW'S Hippy Liberal
    Portland, OR
    2002 4x4 4Runner
    I'm smart sometimes. :)
  12. Sep 18, 2009 at 10:20 AM
    06WHITETRD
    So Cal
    When I do the swap, are the controls going to work after???
  13. Sep 18, 2009 at 10:21 AM
    derekabraham
    TW'S Hippy Liberal
    Portland, OR
    2002 4x4 4Runner
  14. Sep 18, 2009 at 10:26 AM
    yosh2000
    yosh2000 Well-Known Member
    Denver, CO
    '17 Tundra CM 5.7
    probably should research this before the swap...:D
    FWIW, most of the features are usually prewired, as it would create a ton of different wiring harness for the tacoma, not financially wise. i would assume the wiring is all there, but might want to do a once over before you start the swap...
  15. Sep 18, 2009 at 10:28 AM
    cjimenRR
    cjimenRR Be Good or Be Good At It
    North Hollywood, Ca
    12' Sport DC,LB, 4x4
    It probably won't unless the wires are already there to operate the steering wheel controls. It will fit but if the wires aren't there them it's pointless
  16. Sep 18, 2009 at 10:29 AM
    derekabraham
    TW'S Hippy Liberal
    Portland, OR
    2002 4x4 4Runner
    But, I'm sure you can get the wires to hook everything up if they aren't there.
  17. Sep 18, 2009 at 10:36 AM
    06WHITETRD
    So Cal
    Ima get everything with the wires. i believe. i just gotta get everything connect.
  18. Sep 18, 2009 at 10:37 AM
    06WHITETRD
    So Cal
    has anyone here done this before?
  19. Sep 18, 2009 at 4:14 PM
    T0LLPHR33
    BSP TRD Off-Road
    I didn't know that...thanks for clearing that up...
    the necessary wiring between the head unit and in the steering wheel should be in place...you just have to install the new steering wheel and connect the wirings...I don't know whether or not the head unit has to program the buttons...but I figure that should be all plug and play...
    good luck...keep us posted and let's see some pics once everything is finished up...
  20. Sep 18, 2009 at 4:28 PM
    06WHITETRD
    So Cal
    i just talk to the technician from Toyota. he said everything is goign to be there., just gotta run the wiring from the steering wheel to the radio. like u said.. bro.. I dont think i gotta program the buttons, it should work when i connect the wires. i will keep ya posted tommorrow..
    this should be fun.lol.
