Swapping TPMS from OEM wheels
Discussion in '3rd Gen. Tacomas (2016-2023)' started by rlx02, Sep 27, 2017.
  1. Sep 27, 2017 at 10:46 AM
    RichVT
    RichVT Well-Known Member
    Rich
    Northern Vermont
    2016 Tacoma TRD Off Road 4X4 AC Grey
    If you are reusing your original sensors, you should only need to do the simple reset procedure using the button under the dash (instructions are in the owners manual).
    shakerhood likes this.
  2. Sep 27, 2017 at 10:53 AM
    RichVT
    Rich
    Northern Vermont
    I agree. Lots of people need new tires but not wheels. Save the boxes from your new wheels and sell them on ebay or the for sale section of these forums. I buy a second set of wheels to mount snow tires so I want rims but have no interest in the tires.
  3. Sep 27, 2017 at 11:07 AM
    rlx02
    rlx02 [OP] ¯\_(ツ)_/¯
    Western WA
    2017 Inferno DCSB TRD OR 4x4
    Oh, you just put the same ones into new wheels. We have to swap and mount both sets of TPMS into each other's wheels. They're quoting 100/set of wheels.
  4. Sep 27, 2017 at 11:09 AM
    rlx02
    Western WA
    They charged you 19.99 just to read the codes so you can program or 19.99 to read the codes AND program?
  5. Sep 27, 2017 at 12:04 PM
    DriverSound
    DriverSound Señor Member
    Oregon
    2015 DCSB OR 4x4
    Too few to list.
    They charged me $19.99 to read and reprogram my TPMS as they were from another Tacoma.
  6. Sep 27, 2017 at 1:45 PM
    rlx02
    Western WA
    That is awesome. I'll have to give them a call. A different toyota dealer quoted me $150 to this exact same thing.
  7. Sep 27, 2017 at 1:54 PM
    TruSkillz1982
    TruSkillz1982 Well-Known Member
    Walter
    08 Tacoma DCSB
    $20 for all four or five to be reprogrammed or $20 per wheel?
  8. Sep 30, 2017 at 8:16 PM
    Athan1
    Athan1 Well-Known Member
    SoCal - Anaheim
    16 White Double Cab PreRunner TRD Sport 4x4
    $60 for demount, mounting new tires with balance, and TPS switch over
  9. Oct 2, 2017 at 10:42 AM
    DriverSound
    Oregon
    2015 DCSB OR 4x4
    Too few to list.
    $20 for the whole thing.
  10. Oct 4, 2017 at 5:12 PM
    tacitos
    tacitos Tah-Key-Toes
    16 TRDORDCLBJBL
    Curious about this. I want to swap my spare wheel with an oem for rotating.
    If I add a 5th TPMS to the spare I want to have control over what sensors are being read in the dash. I read the whole thread here and the TPMS tool Is nice but expensive for a once in a while use.
    So I'm curious if anyone has tried this before:
    When running (5) TPMS, (1) in the spare, if you remove the spare and place far away out of range, then reset the TPMS using the button under the dash. Will the ECU pickup the (4) TPMS? Or will it pickup the 5th TPMS after you install the spare in the spare tire bay?
  11. Oct 5, 2017 at 6:02 AM
    RichVT
    Rich
    Northern Vermont
    As far as I know, the truck's ECU will only accept 4 TPMS ID's at a time so it will read the four that were programmed in and won't care about the 5th in the spare. The truck is only going to look for the four sensors that it knows about. If you want to use the spare in rotation, you will need the programming tool to add that ID to the ECU and remove the ID that is now your spare. That's how I understand it.
    tacitos[QUOTED] likes this.
  12. Sep 4, 2018 at 10:34 AM
    whitedlite
    whitedlite Well-Known Member
    USA!
    3RD Gen TRD 4WD
    kicking up an old thread...
    if I broke one TPMS and replace the OEM with a knockoff can I program the TPMS reader so that 1 TPMS is aftermarket and 3 are OEM?
    or is it an all 4 have to be either OEM or Aftermarket?
    thanks,
    caliburrito likes this.
  13. Sep 4, 2018 at 10:38 AM
    shakerhood
    shakerhood Well-Known Member
    Southern Ohio
    I would think as long as the replacement is compatible then you should be good to go.
    whitedlite[QUOTED] likes this.
  14. Sep 4, 2018 at 10:43 AM
    hcenteno21
    hcenteno21 Well-Known Member
    Tito
    El Paso, TX
    2020 AG Tacoma TRD Pro Supercharged
    I got new tires, and ordered sensors from eBay https://ebay.to/2MPaDqy
    Took it to pepboys and they charged 15.99 to program all 4! Working great!
  15. Oct 24, 2018 at 4:24 PM
    #35
    CusterFan
    CusterFan Well-Known Member
    Southeastern Illinois
    Silver Sky 2019 Tacoma SR, AC, 4X2, 2.7
    That is what I'm planning on doing. I'm not paying them nary a coin.
  16. Oct 24, 2018 at 4:29 PM
    #36
    Tac0Tic0
    Tac0Tic0 новий член
    SLC, Utah
    17 TRDOR QS
    OVTune Volk TE37XT 17x8.5 295/70r17 G003 Yukon 5.29 differential gears Cab Mount Relocate Icon Coilovers Icon AAL Uptop Overland Bed Rack Maxtrax Baja Designs Squadron Pro Ditch Lamps Rough Country Speedometer Calibrator
    Deflate old tire, push tire down, remove sensor, inflate tire.
    Deflate new tire, push tire down, put sensor in, inflate tire.
  17. Oct 24, 2018 at 5:30 PM
    #37
    CusterFan
    I have a '19 SR with steel wheels. It is my understanding your,
    "Deflate old tire, push tire down, remove sensor, inflate tire.
    Deflate new tire, push tire down, put sensor in, inflate tire"
    will not work in OEM alloy wheels.
  18. Oct 25, 2018 at 9:54 AM
    #38
    Tac0Tic0
    Tac0Tic0 новий член
    SLC, Utah
    17 TRDOR QS
    It worked on mine. Went from stock TRD OR wheels to TRD PRO wheels.
  19. Oct 25, 2018 at 3:53 PM
    #39
    CusterFan
    Alloy wheel to alloy wheel. I can understand that working just fine.
    Tac0Tic0[QUOTED] likes this.
  20. Nov 2, 2018 at 2:24 PM
    #40
    Shearboy2005
    Shearboy2005 It can't stay tight if it's a liquid.
    Ky
    2015 TRD SPORT, 06 PreRunner
    Have a 2015 that I put a set of 2018 OR wheels and tires on. Didn't swap sensors because tires were already mounted. Stealership wanted $105 to break down the tires and read the sensor Id's. Was told that was the only way to get them. Took truck to tire store, they read the Id's and attempted to program to the truck. I say attempted because they never got the light to go off. It flashes for couple seconds then is solid. When codes were checked it showed C2126. Anyone know what might be the problem.
    Also after spending roughly 45 minutes working on it I was not charged anything. Said it was a free service and apologized for not getting the light to go out.
