Swapping wheels l
Discussion in '3rd Gen. Tacomas (2016-2023)' started by mlees, Feb 28, 2020.
  1. Feb 28, 2020 at 3:59 AM
    mlees
    mlees [OP] Well-Known Member
    Decided I am going to swap my steel wheels for oem aluminum. Wondering what people do about tpms when doing this swap?
  2. Feb 28, 2020 at 4:05 AM
    CrustyComa
    CrustyComa Well-Known Member
    Michigan
    2020 SR SX TRD Sport love child
    You will need new tpms, the factory ones from steel wheels will not work on aluminum, and vise versa.
  3. Feb 28, 2020 at 4:17 AM
    Steve Urquell
    Steve Urquell No Pants
    2017 2.7L/5MT AC Utility 4X4
    You can use the steel wheel TPMS in aluminum by rotating them around but they will supposedly be destroyed if the tire goes completely flat.
    I just pulled regular non-TPMS valvestems into my alum wheels after seeing how worthless the factory TPMS is. Downside is looking at the tire light on the dash lit up. Doesn't really bother me but some have a problem with it.
  4. Feb 28, 2020 at 12:26 PM
    Nakedgun
    Nakedgun Well-Known Member
    Southwest
    2020 SR5 AC V6 4x4
    My 2005 Tundra tire indicator is conveniently located in the lower right corner of the display panel - a small square of electrical tape hides it nicely.
  5. Feb 28, 2020 at 12:53 PM
    choose for me
    choose for me Not Sure
    Northwest Florida
    2017 Toyota Tacoma TRDOR
    Flux Capacitor
    Try turning the sensor 180 degrees. When I was on the FJ forum, guys would run into this issue. Apparently they will install properly if you turn them around, and it worked going from steel to aluminum and vice versa. I've heard that our trucks are only one way swappable, but I don't know from what to what. Others have said that it doesn't matter, and they're swappable both ways.
  6. Feb 28, 2020 at 1:06 PM
    Dilly
    Dilly Well-Known Member
    LOUISIANA
    2019 MGM SR
  7. Feb 28, 2020 at 1:09 PM
    choose for me
    Northwest Florida
    Flux Capacitor
  8. Feb 28, 2020 at 3:18 PM
    MarkOne
    MarkOne I plead the FiF
    Mark
    Las Vegas, NV
    2020 Attitude Black Tacoma TRD Offroad 4x4 DCSB
    I reused the oem tpms on my new wheels w/o any issues
  9. Feb 28, 2020 at 3:42 PM
    shift96
    shift96 Well-Known Member
    How would I reprogram them if i swapped on OEM wheels with OEM sensors?
  10. Feb 28, 2020 at 5:02 PM
    MarkOne
    Mark
    Las Vegas, NV
    When I ordered new wheels & tires from discount tire, so when it came time to mount & balance, I told them to swap the tpms sensors over. I think they have a tool to reset them.
  11. Feb 28, 2020 at 5:05 PM
    Dilly
    LOUISIANA
    2019 MGM SR
    yes they do, I just got them to program some OR wheels i got last week. Free of charge and took all of 3 minutes to do
  12. Feb 28, 2020 at 5:10 PM
    Vlady
    Vlady Well-Known Member
    Issy, WA
    2017 White SR5 DCSB V6 4x4
    Itm tpms on Amazon go for $109 for 4 and come already programmed. Still need to enter IDs into ECU though.
