Sway Away 3" lift Questions???
Discussion in 'Suspension' started by tc2008, Sep 2, 2008.
  1. Sep 2, 2008 at 7:10 PM
    tc2008
    tc2008 [OP] Well-Known Member
    Garden Grove, CA
    06 Speedway Blue
    8000K HID light, LED map and dome light, cluster + AC blue, Camburg 2.5 front and rear, Deaver 10 Packs. Satoshi Grille, Eyelids, Carbon fiber hood w/ scoop, BHLM, 285/75/16 km2s, KMC enduros
    Hey guys I'm about to buy a set of Sway away front coil 3" lift with sway bar, I was wondering do I need to lift the back too to make the ride better? I kinda like the uneven look in the front and rear. Also what are your ratings on the sway away coil over shocks?
  2. Sep 2, 2008 at 7:14 PM
    JimBeam
    JimBeam BECAUSE INTERNETS!! Moderator
    JB
    2015 Tundra
    i LOVE my saws
    as for the rest of your post...i dunno what to tell you
    but SAWs are DEFINATELY worth the money
  3. Sep 2, 2008 at 7:17 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    2019 Rubicon 4 Door,
    Sway-A-Ways are good coilovers. Set at 3" its gonna be pretty stiff, though.
  4. Sep 2, 2008 at 7:50 PM
    tc2008
    Garden Grove, CA
    06 Speedway Blue
    but without the rear lift is fine right? also can I still get bigger wheels without doing the rear lift?
  5. Sep 2, 2008 at 9:27 PM
    tacomaman06
    Will
    York,South Carolina
    '16 Tundra TRD Pro
    getting there....
    the rear shouldnt have a problem fitting bigger tires as it is. if it happens to be....get an aal.
  6. Sep 2, 2008 at 9:42 PM
    tc2008
    Garden Grove, CA
    06 Speedway Blue
    how come the guy at EZlift told me that it's better to go with 2"block better than AAL?
  7. Sep 2, 2008 at 9:44 PM
    tacomaman06
    Will
    York,South Carolina
    '16 Tundra TRD Pro
    getting there....
    who knows!!! the aal will ride better, and its also safer than a block. you wont have axle wrap with an all like you will with a rear block.
  8. Sep 3, 2008 at 3:36 AM
    JimBeam
    JB
    2015 Tundra
    either he's an idiot or they sell a really short single aal
  9. Sep 3, 2008 at 5:50 PM
    tc2008
    Garden Grove, CA
    06 Speedway Blue
    Anyone with just 3" lift in the front? I want to see how it looks like before I make my final decision. btw what's the biggest tire I can fit on the back without lifting it? I'm planning to go with something like 295 max for front and back, don't know if it'll work fine?
  10. Sep 10, 2008 at 10:50 PM
    sooner02r1
    sooner02r1 Well-Known Member
    Sway a ways are some of the best shocks you can buy. Setting them up to 3" lift is not ideal though, 2-2.5" will handle much better and unless you are getting new upper control arms, you will demolish your ball joints in the front end at 3".
    Because he was obviously misinformed (read: retarded). But he works at a company that builds junk so what do you expect.
