sway away help
Discussion in 'Suspension' started by nagorb, Jun 9, 2012.
  1. Jun 9, 2012 at 2:30 PM
    nagorb
    nagorb [OP] Should be a dang perma mod
    Alabama
    2001 dbl cab 4x4
    When I was installing my alcan leafs one of the bolts for the shock sheared off and I had to cut off the front pivot bolt.
    I just got a used pair of sway away racerunner 2.0s. They didn't come with nuts/bolts for the top.
    So my question is what type of bolts should I use? the hardware store has both grade 5 and 8, does it matter which I use?
    Thanks
  2. Jun 11, 2012 at 10:34 AM
    nagorb
    Alabama
    2001 dbl cab 4x4
    Anyone
  3. Jun 11, 2012 at 10:38 AM
    blackhawke88
    blackhawke88 wo ai ni bao bei ^_^
    SGV, CA
    07 TRD Offroad
    use grade 8 for suspension hardware for sure
  4. Jun 11, 2012 at 10:41 AM
    nagorb
    Alabama
    2001 dbl cab 4x4
    Great thanks!
