Sway bar broke
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Tacolawlor, Jan 12, 2017.
  1. Feb 21, 2017 at 7:16 PM
    #101
    AANorthwest
    AANorthwest Well-Known Member
    Washington
    2012 DCLB 4x4 TRD sport
    What's a asshat? Is that a east coast term for underwear? I hate when I loose control. End up with a big shitty mess in my asshat.
    Coot83[QUOTED] and itaro like this.
  2. Feb 22, 2017 at 5:51 AM
    #102
    JLink
    JLink Well-Known Member
    Josh
    Ocean, NJ
    Lifted, Locked, Armored. Ready To Wheel.
    Just do the sway bar flip or sway bar relocate. They both work equally well.
    Maggot61 and Coot83 like this.
  3. Feb 22, 2017 at 6:08 AM
    #103
    ItalynStylion
    ItalynStylion Sounds Gooooood
    Steven
    DFW, Tx.
    09 Double Cab TRD Sport 4x4
    Sway bar flip? Never heard of it. Can you elaborate?
  4. Feb 22, 2017 at 6:11 AM
    #104
    godofspeed
    godofspeed Washington State.
    2010 4x4 TRD OR DC
    Body Armor front bumper Body Armor rear bumper 17x8.5 Method Bead Lock 35x12.50 Camburg LT Fox coilover All Pro 11 pack leaf Fox rear shock with DSC Allpro frame slider Smittybuilt 9500 winch Cobra CB w/firestick antenna. Hi-lift Smittybuilt air compressor
    I took mine off a while back and never looked back. But to each their own.
    ensaladas[QUOTED] likes this.
  5. Feb 22, 2017 at 6:19 AM
    #105
    Coot83
    Coot83 DORKEL NATION
    Scottsdale, Az
    2012 Baja TX
    TC 3.5 LT, RCV axles, Demello sliders, BD light bar/fogs, LP6, DMZ rear, SOS skids, custom bumper, King 16" triples, Locked-on hydro rear bumps...
    Not sure if this might help, but I first heard the term from my gaming buddies. It is commonly considered an offensive remark.
    Coot
    AANorthwest and itaro[QUOTED] like this.
  6. Feb 22, 2017 at 7:48 AM
    #106
    tgear.shead
    tgear.shead Well-Known Member
    Lets put it this way;
    I once was driving a vehicle that had one of its swaybar links break DURING a turn. The effect is that the vehicle immediately tilted towards the outside of the turn (inside suspension fully extended, outside suspension fully compressed), and then, it kept tilting even further -- the inside wheel LEFT THE GROUND. It came very close to rolling over. If I was taking the turn just a little bit tighter, or a little bit faster, it WOULD have rolled.
  7. Feb 22, 2017 at 7:57 AM
    #107
    stevotivo12
    stevotivo12 Well-Known Member
    Stephen
    2016 Silver Tacoma TRD Sport MT
    Front hellwig sway bar,All pro sway bar end links, Fox 2.5 Resi Coilovers and Shocks, Fox 2.5 Hydraulic Bumpstops, Budbuilt Traction bar, Total Chaos UCAs w/ heim joints, Icon AAL, AFE Power Intake with dynamic scoop, URD spec U, URD short shifter, Flossy weighted shift knob, michelin tires, black badges, black tailgate letters, black grill with custom Diaz Fab Devil horn yota logo, retrofit/morimoto HID conversion, red interior LED lights, Pioneer head unit, kenwood excelon door speakers, 2 10" pioneer subs,
    Actually its quite the opposite. A sway bar gives you the 'sensation' of the truck being better composed because it forces the suspension to act as one single piece, rather than working INDEPENDENTLY like INDEPENDENT front suspension was designed to work. The sway bar might make the truck 'feel' more composed, but what actually happens is the sway bar keeps the suspension even as far as travel is concerned. Under strong cornering forces, the sway bar will force the tire on the inside of the corner to lift excessively and can cause sudden loss of grip at the limit. If your suspension is stiff enough to limit bodyroll then you will experience much higher grip without a swaybar because the swaybar will not be 'peeling' the inside tire off the pavement by limiting its ability to downtravel.
    If you have too much body roll you CAN more easily flip, which is what ItalynStylion was getting at. If you have stiffer suspension to control bodyroll then allowing the suspension to work independently will increase cornering grip, and significantly so.
    Lord Helmet and Coot83 like this.
  8. Feb 22, 2017 at 8:11 AM
    #108
    ItalynStylion
    Steven
    DFW, Tx.
    One thing that hasn't really been mentioned is the idea that MORE grip, for a vehicle with a high center of gravity, isn't necessarily a good thing. If you have enough grip, eventually you'll turn so hard you roll the vehicle. But when grip is diminished, the tires will slide BEFORE the vehicle turns over. So with a sway bar, your HANDLING is better (as defined as being more responsive to steering inputs) but the mechanical grip (defined as skidpad numbers) is diminished. Pick your poison.
    PottMatter, Lord Helmet and Coot83 like this.
  9. Feb 22, 2017 at 8:15 AM
    #109
    Coot83
    Scottsdale, Az
    2012 Baja TX
    Ah I do see that...atleast it seems both approaches have some benefits.
    Coot
  10. Feb 22, 2017 at 8:15 AM
    #110
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    MMVI 4.4L 4x4 Access Cab
    :facepalm:
    Lord Helmet and Nickel like this.
  11. Feb 22, 2017 at 8:16 AM
    #111
    stevotivo12
    Stephen
    Only thing that will measurably affect response to steering inputs is adjusting your toe out by ~.25-.5* per side.
    Again, I will reiterate that I would ONLY recommend removing a sway bar if somebody has stiff suspension. It should be noted that the third gen tacoma comes with 717in-lb coils which are plenty strong enough to control body roll. Pair those coils with some shocks that are stiff enough and adjustable and you would have the best cornering performance possible.
  12. Feb 22, 2017 at 8:17 AM
    #112
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    He's sitting back watching the :crapstorm:
    Coot83 and Lord Helmet like this.
  13. Feb 22, 2017 at 10:49 AM
    #113
    Wheelspinner
    Wheelspinner Coco Customs
    Northern NJ
    '13 4x4x4cyl
    That's when you take the bolts out and flip it right into the scrap metal pile
  14. Feb 22, 2017 at 10:50 AM
    #114
    stickyTaco
    stickyTaco Fuck Cancer
    Zack
    Reno/Tahoe
    '12 DCSB TRD-OR
    Fox/Dakar with Relentless goodies and stuff
    I have a swaybar in my garage I'll sell if you want to replace it (assuming it's the same as the 5 lug swaybar).
  15. Feb 22, 2017 at 11:16 AM
    #115
    Tdkrum5
    Tdkrum5 New TRD OR for me.
    Ted
    Oly, Wa/Sun City West AZ.
    2024 TRD OR
    New ride 2024 TRD OR. Old ride 2014 Icon Stage 5, 265/75/16 BFG AT KO2, Fuel wheels, KMFB sliders,BAMF trilogy skids, Baja Design Squadron Sport WC
    X4 Something like the rubicon.
  16. Feb 22, 2017 at 11:40 AM
    #116
    ItalynStylion
    Steven
    DFW, Tx.
    I'm actually working on something. I already sourced a spare sway bar and the work is in progress. No idea if my method will work or not. I'll be testing it on my own vehicle soon. Could be catastrophic lol.
    Crom[QUOTED] and Lord Helmet like this.
  17. Feb 22, 2017 at 1:41 PM
    #117
    EatSleepTacos
    Randy
    West Valley, AZ
    2017 4Runner
    I towed the largest size uhaul trailer (totaling 3.5k pounds) from Norfolk, VA to Pensacola, FL. Just shy of 1,000 miles. Did it in two days and the truck hauled it like a champ! Didn't need tow mirrors or any mods to the truck at all. If you're an auto transmission, then maybe you could pick up a scanguage or ultraguage to monitor transmission temps. I didn't need to worry about it since I had a 6 speed.
    https://www.tacomaworld.com/threads/how-to-remove-sway-bar-2012.365947/
    TacomaGinger[QUOTED] likes this.
  18. Feb 22, 2017 at 3:14 PM
    #118
    Supra4x4
    Supra4x4 IG: hash_brown55
    Andrew
    SoCal
    MGM 2011 DCLB 4X4 Long Travel'd
    Whole lotta stuff
    I will agree with this. However, I believe this slight mechanical center-of-gravity holdover to be not very significant in a pickup truck application. It neuter's IFS suspension's capabilities off-road and it transmits vibration, without much noticeable gain on stock vehicles. To me, it does more harm than good. On pickup truck applications.
  19. Feb 22, 2017 at 6:24 PM
    #119
    steelhd
    steelhd Well-Known Member
    Eastern WA
    2011 DCSB TRD OR
    I would love it if a few daily driver swaybar removal advocates took a video of a very simple test that any idiot can do in an empty parking lot.
    Washington RCW 204-10-036
    Suspension.
    A motor vehicle must be capable of stable, controlled operation while traversing a slalom-type path passing alternately to the left and right of at least four cones or markers arranged in a straight line and spaced sixty feet apart at a minimum speed of 25 mph.
    For bonus points post before and after video. Maybe we get some "moose test" fails or the delete advocates are proven right.
    Edit - Think I will post a swaybar delete Charlene challenge thread....
  20. Feb 27, 2017 at 1:19 PM
    #120
    Nighthawk
    Nighthawk 'streme spoats
    Levi
    Casper Wyoming
    2008 Red TRD OR AC V6
    Bilstein 5100's w/ Eibach coil overs in front (set at 3" of lift). Front diff drop kit. Extended Bilstein 5100's in the rear. Deaver 2" AAL in rear w/ axle shims. 285 x 75 r 16 Goodyear Duratracks. Wheelers steelies type B, AFE cold air intake. Sway bar delete. All Pro Apex front bumper (rattle canned Rustoleum primer + flat black). Plasti-dipped emblems. Mud flaps removed.
    I think every truck would have to have the same suspension and tires to draw any kind of useful data from this. Although it would be pretty entertaining to see either way. I regularly drive like an asshole and haven't come close to rolling yet so I'm about 87% sure I could pass this test.
