Sway Bar Disconnects
Discussion in '2nd Gen. Tacomas (2005-2015)' started by fuscotj, Feb 13, 2015.
  1. Feb 13, 2015 at 7:35 AM
    fuscotj
    fuscotj [OP] Well-Known Member
    Travis
    Atlanta Area, GA
    SR5 4X4
    X Metal grill, LED DRL's, LED Light bars
    I know some will say just get rid of the sway bar altogether, but I am looking to see if anyone knows where I can get some sway bar disconnects for a 2013 4x4 DCSB.
  2. Feb 13, 2015 at 7:40 AM
    jmg256
    jmg256 Calmer than you are
    Al Tonter
    TRD Offroad
    Bilstein 5100 front/rear (front at .85), Hayden 678 Trans Cooler, 20% tint, Curt Hitch/Wiring Harness, Weathertech Digital Fit Floor Mats (Black), Wet Okole Seat Covers (Black), Cooper Discoverer ATP 265/75/16, LED Map/Dome lights, ImMrYo bracket, Debadged, Extang Tuff Tonno.
    No such thing exists
  3. Feb 13, 2015 at 7:41 AM
    Wiggins
    Wiggins Well-Known Member
    Jacksonville
    14 MGM DCSB 4x4 TRD OR
    TRD Sport Hood, ICON 3" Lift - 700lb coils, Total Chaos UCAs 5% Tinted Windows Crystal Front Window Film 2.5 resi shocks front and rear, dakar leaf packs Wheelers Bump Stops All-Pro Offroad APEX Front Plate Bumper, PIAA Fog Lights, PIAA Fog Lights, Black Line-X All-Pro Offroad Skid Plates, Black Line-X All-Pro Offroad APEX Rear Plate Bumper, Side Armor for Plate, Hidden Receiver Hitch, Black All-Pro Offroad APEX Sliders,Line-X All-Pro Offroad APEX Pack Rack, Black Line-X, 16" height ScanTool 427201 OBDLink LX Bluetooth Hankook Dynapro ATM 285/75/16 Vision Manx 16"x8" rims, 4.5" Backspacing Warn M8000-s Winch, Factor55 Flatlink, Factor55 1" Hawse Fairlead RIGID Industries Ditch Lights Tractor Supply Bed Box 260amp H.O. Alternator Big 3 Cable Replacement NorthStar AGM34 battery Pelfreybilt Battery Cage Plefreybilt Fuse Plate BlueSea fuse block Kenwood TS-B2000 Short Wave Radio, Remote face, Pack Rack Mounted Antenna Uniden Bearcat CB Cab Mount Chop (BAMF Inserts) TODO: ARB Air System ARB Rear Air Locker w/ 4.88 gears ARB Front Air Locker w/ 4.88 gears HID Retrofit Headlights Rigid Industries RDS-Series 54" Midnight Edition LED Rigid Industries R2-46 Combo Round Light (x2)
  4. Feb 13, 2015 at 8:20 AM
    boogie3478
    boogie3478 Well-Known Member
    14 TRD Off-Road V6
    All the mods
    See second post above mine if you want to see something I agree with.
  5. Feb 13, 2015 at 9:27 AM
    nd4spdbh
    nd4spdbh Well-Known Member
    SoCal
    13 DCSB TRD OR v6 Auto
    take the 20 min to pull it off, you will never put it back on.
  6. Feb 13, 2015 at 9:29 AM
    MGMTacolover55
    MGMTacolover55 Well-Known Member
    Orygun
    2013 MGM Taco TRD Off Road
    floor Mats
    If you want sway bar disconnects get the trail edition 4Runner with kDSS
  7. Feb 13, 2015 at 9:32 AM
    Pigpen
    Dan
    Northwest Montana
    I pulled mine a couple weeks ago. I keep forgetting it's gone. Truck drives exactly the same and the suspension characteristics are improved.
  8. Feb 13, 2015 at 11:19 AM
    DVexile
    DVexile Exiled to the East
    Ken
    2015 DCSB V6 TRD OR 4X4
    Don't exist is the answer to your question.
    Now that that is out of the way, be prepared for ten pages of replies.
    Five pages of which will be from people who have removed their bar and say it is just fine despite not actually having had to execute any sort of emergency steering at speed that would demonstrate the problem of removing it. But that's OK, they know they are driving a truck and are "careful" when driving. And they prominently display a sign that says "I am driving a truck, so don't suddenly get in my way or I'll roll this thing" and amazingly all the other drivers when they read the sign suddenly decide not to do stupid things around their truck. Since most people only experience a near roll over situation once in their life, if ever, most all of these folks will be just fine. Just like most people texting while driving will be just fine too.
    The other five pages will be from people saying your truck will suddenly end over when you make a left turn. Furthermore if you are ever in an accident they will claim your insurance will be invalid and you'll be liable for all damages within a 10 mile radius of your truck.
    None of these will get to the heart of your question though, which is that despite this model existing for a decade there are no quick disconnects available for it.
  9. Feb 13, 2015 at 11:24 AM
    Canazes9
    Canazes9 Well-Known Member
    David
    Texas
    '07 Dbl Cab TRD Sport / '12 Dbl Cab Offroad
    OP can stop reading now....
    David
  10. Feb 13, 2015 at 11:32 AM
    Boone
    Boone Vaginas are rad.
    Boone, NC
    Airbags deployed
    That's a pretty broad assumption to make. I've not had a sway bar on anything I've owned for the past 15 years and I like it that way. Plenty of times executing "emergency steering". Maybe I'm just lucky.
  11. Feb 13, 2015 at 7:16 PM
    steelhd
    steelhd Well-Known Member
    Eastern WA
    2011 DCSB TRD OR
    No need for a moose. Washington State law requires all vehicles to meet this standard;
    "A motor vehicle must be capable of stable, controlled operation while traversing a slalom-type path passing alternately to the left and right of at least four cones or markers arranged in a straight line and spaced sixty feet apart at a minimum speed of 25 mph."
    Pretty easy test to set up.
  12. Feb 13, 2015 at 7:42 PM
    Pigpen
    Dan
    Northwest Montana
