sway bar
Discussion in 'Suspension' started by nick jackson, Oct 15, 2006.
  1. Oct 15, 2006 at 9:56 PM
    nick jackson
    nick jackson [OP] New Member
    I recently purchased a 2000 ext cab 4wd v6. It runs well except has lots of body roll. A friend pointed out that it lacks a sway bar. Any suggestions on a sway bar brand that would work well to reduce the sway?
    Thanks
    Nick
  2. Oct 16, 2006 at 11:42 AM
    twoarezee
    twoarezee Well-Known Member
    esco, ca
    00 Dropped Mini
    rims,tires,3"/6" drop, 4x4 front end, 01 tails and corners, prerunner buckets,tenzo r steering wheel w/ momo hub, b&m shifterw/ jdm trd knob, alpine system, tint, 3 3/4" autometer tach, jardine cat back, k&n, debaged, hellwig rear sway bar, kyb monomax shocks, tundra v8 oil filter w/ mobil 1 in ever
    helwig makes an awesome rear sway bar. i put one on and it was a night and day difference
  3. Nov 6, 2006 at 8:54 PM
    khinanight
    khinanight Member
    I have an ADDCO rear sway bar and one of the spring bolts broke off due to stress. Has anyone ever heard of that? Plus it is next to impossible to buy a square U-bolt. Anyone have any information on this? Thank you in advance!
  4. Nov 7, 2006 at 9:42 AM
    TheMaster
    TheMaster Born to Ride
    Chicky Baby
    NY
    2007 DC TRD Sport
    Bug shield, window visors, skid plate, rust proofing, tonneau cover, paint & upholstery protection, side step bars, navigation system.
    Square U bolt? No such animal! A lathe shop may be able to make one for you. However, you must factor in the tensile strength required for the application, which won’t be easy. Therefore, the proper way to resolve this matter is to take your problem back to ADDCO and have them solve it for you.
    You could use a regular U bold and insert a pre drilled high tensile metal plate to form the square U. However, I'm confident the load bearing on the metal plate will cut into the U at the lowest stress points. Now that I’ve given this some thought, this is the very reason you don't find square U bolts. The 90 degree angle/joints makes them weak, unreliable and susceptible to split easily. The "home made" approach is not the advisable solution to your problem. :eek:
    Moo
  5. Nov 8, 2006 at 7:28 AM
    khinanight
    khinanight Member
    I agree with you wholeheartedly. The U-bolts are squared off instead of the usual curved ones. A friend of mine called it a SPRING-bolt. It looks like Ill have to contact ADDCO. Thanks for the assist. Lmabert
  6. Nov 15, 2006 at 8:12 PM
    flatboy
    flatboy Member
    Edmonton, Alberta, Canada
    FASTACO
    Turbo, meth, Nitrous, w/a intercooler.
    Hellwig for the rear
    Addco for the front
  7. Nov 16, 2006 at 7:50 AM
    khinanight
    khinanight Member
    You reccommended Helwig for the rear. Are there any disadvantages on Helwig for the front?
  8. Nov 20, 2006 at 9:40 AM
    flatboy
    flatboy Member
    FASTACO
    Noop, I just think the addco is a larger dia. bar but I can't relly remember for sure.
  9. Sep 23, 2007 at 4:28 PM
    gegundez
    gegundez Well-Known Member
    Miami, FL
    07 TRD Prerunner Dcab
    Overpriced stereo and alarm. MBRP Dual Exhaust.
    Hellwig makes big diff. I used Eibach for many other apps, but Hellwig works fine.
  10. Oct 20, 2008 at 7:03 AM
    SRFIVE
    SRFIVE Well-Known Member
    Upstate NY
    '09 SR5 AC
    I have (4) Square U-bolts that came off my '04 Tacoma DC, don't need them now since my AAL came with new ones. PM me if you still need them?
  11. Oct 20, 2008 at 7:06 AM
    SRFIVE
    Upstate NY
    '09 SR5 AC
    Have the ADDCO front, love it.
    Do you have pics of the Hellwig installed on the rear?
  12. Oct 20, 2008 at 9:55 AM
    jasonh
    jasonh tossed salad anyone?
    Dallas, TX.
    2007 Pre Runner SR5
    Billy 5100's
    dont our truck already come with a front one?
  13. Oct 24, 2008 at 12:31 PM
    RJSNoCal
    RJSNoCal New Member
    Sonoma County, CA
    Prerunner
    TRD high-flow air filter Alpine CDA 9883 CD receiver
    I have an Addco for the rear of my '99; haven't installed it 'cuz it seems to be too freaking heavy. Any recommendations for a bar that's lighter in weight?
