Swaybar Removal Challenge
Discussion in '2nd Gen. Tacomas (2005-2015)' started by steelhd, Feb 22, 2017.
  1. Mar 9, 2017 at 1:04 PM
    #221
    tgear.shead
    tgear.shead Well-Known Member
    There's tons of pictures of it on google...
    https://www.google.ca/search?q=deer...qMrSAhWI54MKHbHpCWgQ_AUICCgB&biw=1032&bih=744
    I'm sure they can't all be fake.
  2. Mar 9, 2017 at 1:04 PM
    #222
    tgear.shead
    I agree with that.
  3. Mar 9, 2017 at 1:21 PM
    #223
    metrick1215
    metrick1215 Pirate Medic
    Habersham GA..
    Black 2008 4x4 4door
    as a firefighter and medic we see some shit. Now as far as dropping the vehicle nose when you hit the brakes this is true, but as far as a deer coming up into the windshield because of it would be a stretch but not impossible.. There are too many things at play for this. Including height of deer, vehicle, is the deer jumping, the road condition (bumpy flat, ect) With this logic you wouldnt slow down if you were about to hit a person because it would make them come through the windshield. We are taught in medic and fire school that when an adult size person gets hit by a vehicle they will go up and over a vehicle because it hits the person in the legs. A child will go under a vehicle due to it hitting above the torso and pushing the top side over and legs under. Personally i would try and stop before i went full force into any object. (unless i was trying to hit it)
    danbow and Maggot61 like this.
  4. Mar 9, 2017 at 1:47 PM
    #224
    ItalynStylion
    ItalynStylion Sounds Gooooood
    Steven
    DFW, Tx.
    09 Double Cab TRD Sport 4x4
    I'm under the impression the above scenario is the real reason for the moose test. A deer is a good bit lower to the ground than a moose. Thus, when you hit it, you're likely hitting the body. However, a moose is basically a cow on stilts. Way heavier than a deer and the legs just snap right out from under it during impact. Then that half ton body comes into your windshield and literally hits you in the face.
  5. Mar 10, 2017 at 2:20 PM
    #225
    yodatoyota
    yodatoyota Scrub
    tim
    Barrie Ont. Can
    2021 TRD OR 4x4 sb
    Empty wallet mod
    Old man winter is currently bashing my area for the next couple days. But after that I'll get around to posting a video.
    I still have my sway bar on with OME 886x coils. I'm undecided on whether or not to remove it.......
    Kyitty likes this.
  6. Mar 10, 2017 at 3:49 PM
    #226
    Kyitty
    Kyitty Mr. Beard
    Bozeman, MT
    2015 Tacoma DCLB Better Than TRD
    See Build Page
    OME 886 coils... plus heavy stuff.
    Took my sway bar off.
    Love it.
    danbow and BraskaTaco like this.
  7. Mar 10, 2017 at 7:58 PM
    #227
    Larueminati
    Larueminati Well-Known Member
    Western MA.
    2013 DCSB TRD 0FF-ROAD
    At least try it, it's really nice
    Kyitty likes this.
  8. Mar 10, 2017 at 9:50 PM
    #228
    dumprat
    dumprat Well-Known Member
    Southern B.C.
    08 tacoma DCLB
    TSB leafs, weather techs, ram mount,jack&shovel mount, and more to come.
    Do you want to know the reason that you don't hit the brakes in an emergency?
    You have WAY more control of a vehicle under power than you do with the brakes slammed on and the abs howling. I am told they teach this in driving schools.
    And having lived in moose country you have a way better chance going around one with the throttle down than you do sliding down the road straight at it with the brakes locked.
  9. Mar 11, 2017 at 9:51 AM
    #229
    Suicyco
    Suicyco Well-Known Member
    14 ac 4x4
    Replacing my swaybar today after about 10,000 miles. Anyone have a comment on whether i should i put some some loctite on the threads of end link side connected to spindle
  10. Mar 15, 2017 at 7:47 AM
    #230
    yodatoyota
    yodatoyota Scrub
    tim
    Barrie Ont. Can
    2021 TRD OR 4x4 sb
    Empty wallet mod
    for some one with very little mechanical stills, I've always thought it was super hard to remove on ones own. I also didnt think any mechanic in my area would remove it for me since "its there for a reason blah blah". but apparently its a pretty simple job. Thats the only reason why I havent tried it yet. I still plan on posting a video with it on for comparison reasons for this thread. Once it stops snowing.....and isnt -20 out:goingcrazy:
  11. Mar 15, 2017 at 7:55 AM
    #231
    danbow
    danbow Member
    Daniel
    Texas
    18 F150 Crew 4x4
    It's super easy... should only take 15 or 20 minutes unless you have to remove an aftermarket skid plate coated in mud like I did.
  12. Mar 15, 2017 at 11:06 AM
    #232
    Kyitty
    Kyitty Mr. Beard
    Bozeman, MT
    See Build Page
    My custom shop told me several times I'd hate my truck without the sway bar.
    Eventually I insisted they remove it.
    Guess what! I don't hate it!
    Heavier aftermarket coils is the key though.
  13. Mar 15, 2017 at 3:41 PM
    #233
    wolftree21
    wolftree21 Active Member
    Rick
    Ohio
    2011 Regular Cab 4 Cylinder
    Bilstien 5100s. Toyota rear spring TSB upgrade. 5th rear spring added. Michelin LTX/MS-2 265-70x16 Addco rear anti-sway bar.
    Unlike most here, I use my truck for work and equip it accordingly. I have 5 leaf rear springs, Bilstein shocks all around and Michelin 265X70-16 LTX M/S2 tires. I was still unsatisfied with the way it handled and added a ADDCO rear anti-sway bar.
    We each have different needs from our trucks and there is no one way that is perfect for all.
    Torspd likes this.
  14. Mar 15, 2017 at 6:10 PM
    #234
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    MMVI 4.4L 4x4 Access Cab
    I have the Addco's front and rear. :thumbsup:
  15. Mar 15, 2017 at 6:52 PM
    #235
    Pigpen
    Dan
    Northwest Montana
    Love your rig with the topper!
    Kyitty[QUOTED] likes this.
  16. Mar 15, 2017 at 8:22 PM
    #236
    TYetti
    TYetti 4cylinders of awesomeness
    Mat
    Abbotsford, BC, Canada
    09 Tacoma AC 2.7L 5spd 4x4
    I deleted my away bar when the truck was still stock legitimately one of the first 10 things I did. That was in 2014 I have not looked back since. That being said my truck is meant for off road performance being on pavement is just a nuisance
    Maggot61 likes this.
  17. Mar 18, 2017 at 1:13 PM
    #237
    yodatoyota
    yodatoyota Scrub
    tim
    Barrie Ont. Can
    2021 TRD OR 4x4 sb
    Empty wallet mod
    Sway bar on
    OME 886 up front
    ARB bumper
    285/70 rubber
  18. Mar 18, 2017 at 1:17 PM
    #238
    EatSleepTacos
    Randy
    West Valley, AZ
    2017 4Runner
    Nicely done!! Your truck didn't even budge.
    GreyComa likes this.
  19. Mar 18, 2017 at 1:58 PM
    #239
    danbow
    danbow Member
    Daniel
    Texas
    18 F150 Crew 4x4
    You may want to check on your CV boots.
  20. Mar 18, 2017 at 10:14 PM
    #240
    scollins
    scollins Well-Known Member
    Scott
    Renton WA
    2019 Ford F450 STX 6.7L Powerstroke
    First run at 16-19 MPH (25-30KPH), and the second at 19-22 MPH (30-35KPH), not surprised it didn't budge. Wasn't going fast enough. 25MPH would be more like 40-41 KPH.
    Torspd likes this.
