Swaybar
Discussion in 'Bay Area Metal Fabrication' started by bjmoose, May 11, 2012.
  1. Nov 24, 2012 at 7:22 AM
    bjmoose
    bjmoose [OP] Bullwinkle J. Moose
    San Jose CA
    '11 Std Cab 4x4 5sp
    There's not a lot of space there because of clearance for the tire at full lock. The swaybar is not a round tube where you want to cut it - rather it's flattened.
  2. Nov 24, 2012 at 11:33 AM
    bjmoose
    San Jose CA
    '11 Std Cab 4x4 5sp
    That's an FJ Cruiser bar made by a guy who no longer makes or sells them.
    The entire "red" section is removed - you have to remove two nuts from the bar and the "pin" in the link end.
    Try it out, man! I'll be a cheerleader for anyone who can make this work. As far as tire clearance goes - you can measure more easily than I can tell you. But basically with any mod you want to be aware of the need to preserve maximum tire clearance, because TW owners are *always* running oversize tires and *always* running rims with more-than-factory negative offset.
  3. Nov 24, 2012 at 8:09 PM
    Ghost848
    Ghost848 Well-Known Member
    Tony
    Alberta,Canada
    09 V6 TRD OR Silver M6
    OME + Dakers, 285/75R16 Nitto Trail Grapplers, ARB Bumper, Columbia overland Dual battery, Super winch,CC stage 4 clutch, bestop supertop, URD TO bearing, BHLM headlights, Cruisin offroad rear bumper, Harrop front E-locker.
    Oh god please!
  4. Nov 29, 2012 at 8:47 AM
    GP3
    GP3 Well-Known Member
    California
    4X4 TRD Off Road
    Front: stock suspension, 12" wide fiberglass fenders Rear: stock suspension, 10" wide fiberglass fenders
    Bummer. Idea is squashed.
  5. Nov 29, 2012 at 8:50 AM
    HBMurphy
    HBMurphy Ban Pending
    Paul
    So California Coast
    09 Off Road Delete Model
    None
    Talk with FJ FunJunkie in the Blue Room - He had this on his FJ - more than likely it's off by now but you never know.
  6. Nov 29, 2012 at 8:58 AM
    Enders Taco
    Enders Taco Well-Known Member
    Ben
    Hampton Roads VA
    DCSB 4x4 6SP
    All Pro APEX Front Bumper, All Pro Sliders, Icon Coilovers with rear shocks and add a leaf pack, URD short shifter, Pioneer X930BT Nav with Polk speakers
    I think from a structure standpoint, this is a bad idea to have the bolts lined up vertically. The sway bar transfers force on the vertical axis. This would put all the stress on the two bolts and would provide a weak point in the design. In the original design the two sway bay pieces are channeled together to give the sway bar more points to spread the stress load with the primary function of the bolts to simply keep the two pieces together. So you cannot simply take the original design and rotate it 90 degrees and maintain better tire clearance.
    It may be possible to maintain the linkage design but move the bolts to the vertical, however I fear that would rob the design of strength and it would give the appearance of a weakened part and therefore scare some folks off.
    I would remain with the original design. Tires can be moved away from the sway bar using different back spacing wheel and/or wheel spacers/UCA etc.
  7. Nov 29, 2012 at 9:03 AM
    JLee
    JLee The Man! Vendor
    Jerry
    Benicia, CA
    02 Extra cab SAS Linked front and rear
    I lost track thousands of dollars ago.
    So I've talked this over with my insurance agent and It's not going to happen guys the insurance alone will cost me over $7,000 to $10,000 a year this is considered a vehicle safety device. And with the liabilities involved with sway bars I will not build them without the coverage.
  8. Nov 29, 2012 at 9:13 AM
    WILLIAM ROBERT
    WILLIAM ROBERT Well-Known Member
    Edmonton
    it's blue
    why not just leave the factory sway bar in place and make quick disconnects for the little bar that connects the sway bar to the spindle? Drill holes in the shaft of the ball joint. Put castle nuts on the end of the ball joints and use cotter pins to ensure that they stay on while daily driving. It would look just like your upper ball joint, except they don't have to be so tight. Then you could easily remove that little bar every time that you go wheeling. Removal and install could be done while you are airing up and down. The only problem is that you have to leave your cab, and reach around a muddy tire.....
    Billy-Bob
    CMScheid likes this.
  9. Nov 29, 2012 at 9:15 AM
    GP3
    California
    4X4 TRD Off Road
    The disconnected sway bar will hit the coilover and/or tie-rod.
  10. Nov 29, 2012 at 9:21 AM
    WILLIAM ROBERT
    Edmonton
    it's blue
    ^^^^ ah ha. I knew it was too easy.
  11. Nov 29, 2012 at 11:30 AM
    bjmoose
    San Jose CA
    '11 Std Cab 4x4 5sp
    OK - thanks for checking.
  12. Jan 12, 2013 at 8:29 PM
    rmarqu2
    rmarqu2 YES... i am a murse....
    Roger
    Baton Rouge
    09 Black 4x4
    FOX 2.5 coilovers, FOX 14" rears, AP expos, AP front plate bumper and skid, lightforce 240 blitz, warn m8000, 3/8 amsteel, BAMF sliders, cheap Chinese rock lights, ARB lockers all around
    What about a piston like device?
  13. Jan 12, 2013 at 10:14 PM
    bjmoose
    San Jose CA
    '11 Std Cab 4x4 5sp
    The risk is the same as if you completely removed the end link:
    The disconnected sway bar end is "out of sync" with the disconnected spindle and there's now the possibility the sway bar end can contact and tear the CV boot.
  14. Jan 12, 2013 at 11:24 PM
    rmarqu2
    Roger
    Baton Rouge
    09 Black 4x4
    I think it would be more practical and cheaper to just develope an easier and quicker way to just remove the whole sway system for offroading and then reassemble before getting back on the road. I guess it's relatively simple already, but I want FASTER!!!
  15. Jan 13, 2013 at 12:17 AM
    #35
    rmarqu2
    Roger
    Baton Rouge
    09 Black 4x4
    That's what they make friends with 4runners for!
  16. May 1, 2013 at 4:15 PM
    #36
    Slesse
    Slesse Tacoma level 27
    Kyle
    Port Coquitlam
    08 Tacoma
    Pro Comp Rims;32" Duratrack Tires; OME heavy duty lift in rear; 2" spacer lift in front; custom raised bed in box; Lear canopy; grillcraft grill; Rosen Head unit; Trail gear sliders; Tinted windows all around; Intermittent Wipers; White LED dash; Deactivated seat belt buzzer; Blue Sea Fuse panel; BAMF light bar running 4 Lightforce 170's (2 HID); FX-R retro HID's 4300k, with amber halo's, BHLM with black reflector bowl; stealth mode; Fenix Hide-a-way flashers as DTRL's; VIAIR OBA kit with 2.5 gal tank; 14" Magnaflow stainless steel cat back exhaust; de-badged; Hybrid badge applied; seasonal 4wheel camper "Fleet"
    Can't you just call it an "off road" only type device and "not for highway use"
  17. Jul 6, 2013 at 11:02 PM
    #37
    bjmoose
    San Jose CA
    '11 Std Cab 4x4 5sp
  18. Oct 23, 2018 at 2:44 PM
    #38
    dkg
    dkg Active Member
    Is there a reason you can't do something like this...
    http://www.rubiconexpress.com/Suspe...EROKEE+(ZJ)+LAREDO&Engine=4.0L+L6+242+CID+GAS
    You could bolt the bottom of the link in place. Adjust the length and spin the top 90 degrees from the bottom position. Then use the pin connection point at the top as the disconnect point. Then you could just swing the top of the arm down when disconnected and use a velcro strap to hold it out of the way when you're wheeling.
  19. Oct 23, 2018 at 8:12 PM
    #39
    bjmoose
    San Jose CA
    '11 Std Cab 4x4 5sp
    I think if you disconnect both ends and attempt to swing them down, you'll strike the tie rod ends. But as I mentioned - try it out! An experiment is worth more than the opinion of some dude on the Internet. :)
