Swimgood's ‘23 TRD Pro Tundra Build
Discussion in '4Runner Builds' started by Slimwood Shady, Apr 19, 2011.
  1. Jul 12, 2012 at 4:16 PM
    #321
    Slimwood Shady
    Slimwood Shady [OP] I love your mom!
    Linwood
    San Antonio, TX
    '23 TRD Pro Tundra; 996TT; '16 Odyssey
    #nomods
    Thin lipped homersoschi grill.....
  2. Jul 12, 2012 at 4:17 PM
    #322
    Slimwood Shady
    Linwood
    San Antonio, TX
    #nomods
    Yeah that was with the 3.73's....I got 17.8 with the 4.56 on my first tank though :D these are also uncorrected for the tars....
  3. Jul 12, 2012 at 4:19 PM
    #323
    AlphaEcho2k5
    AlphaEcho2k5 Well-Known Member
    Adam
    Hurlburt Field, FL
    '02 4Runner
    Looks good. :cheers:
  4. Jul 12, 2012 at 4:45 PM
    #324
    SWB Chick
    SWB Chick Mrs. EL TACOROJO
    Dawn
    South Mills, NC
    09 DCab LB Sport 4X4
    Looks good Slim
  5. Jul 12, 2012 at 5:28 PM
    #325
    superwhite10
    superwhite10 Well-Known Member
    Garner, NC
    ahh looks good mang! it didnt hit me until just now that this is why you were selling your grill :rolleyes:
  6. Jul 12, 2012 at 6:35 PM
    #326
    FrustrationFabTaco
    FrustrationFabTaco Well-Known Member
    Luke
    Lexington, VA
    11 Duramax Grandpa Truck Special
    :spy:
    i just did a thin lip myself. looks good. :thumbsup:
  7. Jul 14, 2012 at 9:48 AM
    #327
    Slimwood Shady
    Linwood
    San Antonio, TX
    #nomods
    So while changing my diff fluids today, first off, ECGS needs to learn how to use a fawking torque wrench :smack: My drain plug on my front diff was tighter than Hellen Keller...smh I also noticed a bit of gear oil on the pass side of the diff next to where the cv goes in. There was also moisture on my skid in this location. Is it possible that this is just from the fill, or could it be a leak? :goingcrazy:
  8. Jul 14, 2012 at 9:53 AM
    #328
    YotaMan2007
    YotaMan2007 Well-Known Member
    Brian
    where my boots and ruck lay
    07 Tacoma 2wd
    K&N Drop-in airfilter, secondary airfilter removed, Satoshi Mod, Kenwood Stereo System, Gibson catback system , Painted Steelies, Offroad Lights, Fatbob's spacer lift
    I'd clean the spot up (brake cleaner and shop rags work great) and inspect it daily to see if the moisture shows up again.
  9. Jul 14, 2012 at 9:58 AM
    #329
    Slimwood Shady
    Linwood
    San Antonio, TX
    #nomods
    Oh, absolutely...this is my plan. I was just curious..
  10. Jul 14, 2012 at 10:05 AM
    #330
    YotaMan2007
    Brian
    07 Tacoma 2wd
    One of my intructors suggested that when i was learning to be a 91S
  11. Jul 14, 2012 at 10:17 AM
    #331
    jandrews
    '09 FourDubDee TRD OR
    There'll probably be a little fluid laying around from disassembly/re-install. Just clean it up and see if it comes back. If it does come back, keep an eye on it to determine if it's enough to care about yet, or if you wanna wait til it gets worse.
  12. Jul 14, 2012 at 2:51 PM
    #332
    Slimwood Shady
    Linwood
    San Antonio, TX
    #nomods
    Yeah I am going to keep my eye on it, but if that shit is still leaking, ECGS will be getting a call. When you changed your fluids, was your fill plug on your front diff over torqued?
  13. Jul 14, 2012 at 3:00 PM
    #333
    jandrews
    Nah, it was in there solid, but I wouldn't say overtorqued.
    I would only call 'em if it's a massive leak. I noticed a couple weeks ago my pinion seal let out a trickle of diff oil that ran down the housing after a long highway trip ~2 hrs. It was never a big enough leak to drip on the ground, and it only happened that once. I think it's just the heavier weight oil and a little extra heat from the gear break-in process expanding everything.
  14. Jul 14, 2012 at 5:51 PM
    #334
    Slimwood Shady
    Linwood
    San Antonio, TX
    #nomods
    So, after finally getting the fluids changed and driving normally, HOLY JESUS!!!!! I finally remember what it was like to drive the truck off the lot again! So much torque and power back. This is without a doubt worth every penny. If you have 33"+ tires and you don't have this mod, you are doing yourself an injustice! Damn I am glad I copied JA!
  15. Jul 16, 2012 at 11:45 AM
    #335
    Slimwood Shady
    Linwood
    San Antonio, TX
    #nomods
    Yeah that is what i torqued mine to. But i almost had to put a pipe on the breaker bar to break free the drain plug :rolleyes:
  16. Jul 16, 2012 at 12:16 PM
    #336
    Slimwood Shady
    Linwood
    San Antonio, TX
    #nomods
    That is funny because that is all i could think about when I was struggling to get mine to break free. :eek: maybe boyd needs to put his on a lift and put a pipe on a breaker bar to get his off.:notsure: the impact is good and all, but sometimes that is what it takes
  17. Jul 17, 2012 at 5:00 PM
    #337
    jandrews
    I seriously wouldn't worry about it. What's probably happening is when the diff heats up, some things expand and the seal loses a teensy tiny bit of contact and drips a couple drops. Then it goes away again when the diff cools.
    Remember, you just put in a new fill of gear oil, so you're way topped off and pressure in the diff is going to be the highest it ever is.
    I wouldn't fuck with it. There's always the chance when messing with seals that you can ding up the mounting location, break hardware, etc. that makes remounting hard to impossible. If it's only leaking a drop or two after each drive, just top it off once a year and forget about it.
    Better yet, with the kind of wheeling we're doing, change it annually. It'll need it that often after fighting with all the dust, water, etc. on the trails, not to mention the breakdown in the oil from hard use...especially all the water you mess with up there in Joizy.
  18. Jul 18, 2012 at 5:28 AM
    #338
    Slimwood Shady
    Linwood
    San Antonio, TX
    #nomods
    Yeah, I haven't put my skid on yet still. I check it everytime I drive it and no issues so far. I really didn't want to have to make that drive down to Raleigh again...
  19. Jul 19, 2012 at 9:08 PM
    #339
    jeverich
    jeverich Well-Known Member
    Jake
    PNW/Kodiak
    07 2.7 4x4
    OME 886/Old Man Doug Suspension Lift, ARB Bumper, Bruteforce High Clearance w/Swing Out, De-badge, Block Heater, Homemade IFS Skid, 7" Kragens, Blue Seas Fuse Block, BlitzPro Fogs, 12k BadLands Winch, BAMF Sliders, ARB Locker, 4.88s Yaesu FT-1900R, Larsen 150B NMO Mount Antenna
    Just found yer build...
    Evil twin.
    Where'd you get your ARB fogs from? Been thinking about doing mine for awhile - got some $ in my PayPal that's going towards mods.
  20. Jul 31, 2012 at 6:50 PM
    #340
    hard2kill
    hard2kill Well-Known Member
    Rhinebeck NY
    06 4door trd sport white 6spd
    ...315's,2in bora wheel spacers,safari snorkel,wheel spacers,bruteforcefab rear bumper and sliders,afe filter,hi-lift jack,5100 with OME 886 & 1/2in spacer,allpro expo's,icon 10in rear shox,flip kit,ss brake lines,cobra cb,fog light mod,yellow fogs,weathertech mats,fullsize spare tire and extra sport rim,tinted windows,aeroturbine 2525 muffler dumped over axle...rear diff breather mod...removed factory spare...removed 2nd air filter...THULE roof rack and fairing....bud builts front to back,allpoo front bumper,BAMF lca skids,overland Offroad roof and bed racks,
    trucks looking good mr.shaddy ;) i cant wait to get my 4.56's
