Switch blank removal on 2009 center dash helpers
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Outback, Oct 26, 2011.
  1. Oct 26, 2011 at 6:36 AM
    Outback
    Outback [OP] Well-Known Member
    Hi. Im stuck. I searched and can't find an answer so I am posting it here. In the center of the dash, under the heater controlls, between the cig lighter and aux stereo port there are 2 switch blanks (fillers) installed. I would like to use them. I can't find a way to access to remove them from behind. I do not want to try a way that might break the labeled. Just looking for the right way. There are plenty of posts about the switch blank removal for the left side of the driver but none I can find on the center dash area. Any experienced help would be appreciated. I am not looking for alternate area switch locations or guesses.
    Thank you in advance!
  2. Oct 26, 2011 at 6:59 AM
    darrmill
    darrmill Well-Known Member
    MA
    11 MGM DC SB
    Pop N Lock, Weathertechs, Viper remote starter, Intermittent wiper switch, devil horns, Access rollup tonneau, Wet Okoles, Rocky Mounts, EGR vent guards
    When I replaced my HU, I was able to get at those from above. Try removing the heater controls. You'll have to squeeze them to get them out, they have those side-type clips.
  3. Oct 26, 2011 at 7:05 AM
    Outback
    The heater unit has side clips or the blanks? I don't know how to remove the heater unit. I saw something in another post about removing the console the whole way up to the dash. Seemed like a lot of work and you know how it never goes back just right....
  4. Oct 26, 2011 at 9:58 AM
    Lurkin
    Lurkin Well-Known Member
    Rod
    Pearland, TX
    09 PreRunner SR5 DC
    If you truely need to get behind the switch blanks there, then the whole buttload of panels above it do need to come out first. But, you probably don't need to access the back. What I did when I put a switch in there; the switch blank can be pried out with a small screwdriver, just be careful not to scratch up the grey/tan panel as it is soft, just like all the rest of the dash panels. Once that is out you can feed wires into that area from the top and/or sides as you see fit. You can also trim the switch slot as needed for whatever switch you want in there, then wire it up, and push the switch into the slot.
  5. Oct 26, 2011 at 10:10 AM
    t4daddy
    t4daddy Well-Known Member
    North Alabama
    2008 PreRunner Double Cab
    A butter knife tip wrapped in black tape, (to help prevent marring).
  6. Oct 26, 2011 at 10:46 AM
    Outback
    Yea, I might have to resort to that, just worried about cracking plastic. Did you take out those particular covers?
  7. Oct 26, 2011 at 10:53 AM
    Outback
    Lurkin. Thank you for the advise, between a butter knife w tape and nerves, I should be able to do it...I hope
  8. Oct 26, 2011 at 11:04 AM
    xJuice
    xJuice My spoon is too Big!
    Josh
    N. Texas
    19 Tundra MGM
    TRD Front & Rear Sway Bar, TRD Pro LED Headlights, Undercover SE, Rear diff. Relocate, console organizer, debadged, color matched handles, mirror caps, and grill
  9. Oct 26, 2011 at 12:48 PM
    Outback
    Are you sure o would be able to reach down to push the covers off? Looks blocked...
  10. Oct 26, 2011 at 12:50 PM
    Outback
    Ok...I see. I will try that. It does not look too rough. Thanks!
