Switch for light bar
Discussion in '3rd Gen. Tacomas (2016+)' started by shwayne5, Jan 15, 2020.
  1. Jan 15, 2020 at 1:38 PM
    shwayne5
    shwayne5 [OP] Member
    Shane
    2017 Tacoma TRD Pro
    Frame sliders, OVTune
    I’m trying to find an oem switch which will fit the only open slot on the bottom left hand driver side bank of switches. The open spot is right next to the rear window and 110 V power switch. The dealer has ordered two different switches which do not fit and they really have no idea what size it is. I know, this is strange. Does anyone have the correct part number? This switch will be used to power a light bar.
    I can go the aftermarket switch route but I get a little concerned when people are posting pictures of their burned up switches made in China. Thanks for your help!
  2. Jan 15, 2020 at 1:44 PM
    BigBeej
    BigBeej Well-Known Member
    Bryan
    Vista, Ca
  3. Jan 15, 2020 at 1:46 PM
    snozberries
    snozberries is forever trying to find a campsite
    Cory
    Martinez, CA
    2016 Quicksand
    Tires, Rack, LED bar, RTT, etc.
  4. Jan 15, 2020 at 3:21 PM
    PhenixFord
    PhenixFord Well-Known Member
    Randy
    Arkansas
    2019 MGM SR5 4WD DCSB
    Most of the time, the switch isn't really to blame. Most switches are designed to only carry a specific amount of current (usually about 3 to 5 amps). So, depending on "what" you are switching, maybe you should use a relay?
