Switch help
Discussion in 'Lighting' started by primer, Feb 6, 2011.
  1. Feb 6, 2011 at 1:12 PM
    primer
    primer [OP] Well-Known Member
    T
    OK
    06 SS Mica AC 4x4 TRD Off-Road
    (Mostly) debadged, Homelink mirror, Elevated rear diff breather, LED illuminated 4x4 switch, Color matched grill surround, Bed cover, Ivan Stewart wheels, Bridgestone 265/75 Dueler AT Revo 2 tires
    I'm planning to do the DTRL off switch (stealth mode) mod.
    http://www.tacomaworld.com/forum/lighting/85326-dtrl-toggle-switch-mod-stealth-mode.html
    I'd like more of a flush mount switch. Something like this:
    http://www.parts-express.com/pe/showdetl.cfm?Partnumber=060-662
    Unfortunately, while this switch has the look I'd like I don't think it is suited to this application. I need a switch that you press and release to open the circuit - then it stays open until you press and release again to close it.
    This (The switch I linked to above) is a momentary n.o. switch. I think that means unless you press it the switch is normally open (DRTL would be off), then when you press the button they would come on only as long as you were pressing the button to close the circuit. As soon as you let go the lights would go off again. Someone correct me if I'm wrong.
    I can't find a flush switch like this that clicks on and off. Can anyone tell me where I might find this?
    This could work:
    http://www.amazon.com/JT-Products-2..._4?s=automotive&ie=UTF8&qid=1297026418&sr=1-4
    They also have them with a little LED indicator:
    http://www.amazon.com/JT-Products-2...7?s=automotive&ie=UTF8&qid=1297026480&sr=1-17
    I don't know how complex it would be to wire it so that the LED came on when the DTRL were off.
    These are some cool switches, but I can't tell if they would work:
    http://www.apem.com/pdf/LPI_series.pdf
    Any help would be appreciated.
    TL
  2. Feb 8, 2011 at 7:07 PM
    primer
    T
    OK
    Bump?
  3. Feb 9, 2011 at 7:00 AM
    primer
    T
    OK
    Hey - thanks for the reply.
    I assume you mean this one:
    http://www.amazon.com/JT-Products-27...026480&sr=1-17
    I'll probably go ahead an order it. Does anyone know where I can find a diagram of how to wire this though? I'm not an electronics guy. In my defense - I can follow instructions. I put LEDs in my 4X4 switch back when you had to do it all yourself. Took me a week of trial and error, but finally added a variable resistor that allowed me to get the color match just right.
    Thanks
  4. Mar 15, 2011 at 7:03 PM
    primer
    T
    OK
    Been working (slowly) on my Satoshi instead. But this too will get done.
    TL
  5. Mar 27, 2011 at 8:35 AM
    primer
    T
    OK
  6. Mar 27, 2011 at 9:17 AM
    primer
    T
    OK
    Thanks a ton for the quick reply.
    I saw the diagram - but I wasn't sure I understood it. Better said - I was sure I didn't understand it.
    Tell me if I have this correct:
    There is a row of three contacts that run vertically in the center. I use the center and the lower one (shouldn't matter which wire toes to which). Correct?
    If so - why even have the third (upper) contact. On the left diagram it looks like perhaps you use that. Clearly I don't understand.
    I assume the other contacts on the left and right are just for the LED.
    Thanks again.
    TL
  7. Mar 27, 2011 at 9:44 AM
    primer
    T
    OK
    Makes sense now. If I understand you correctly you could also connect to the top and bottom contacts and it would be closed (on) until you pressed the button.
    I'm excited to do this now.
    TL
  8. Mar 27, 2011 at 4:38 PM
    primer
    T
    OK
    Perfect. Thanks again.
    TL
  9. Mar 27, 2011 at 5:12 PM
    primer
    T
    OK
    You're over my head. I think I understand what you're saying. This would be a way to easily bypass the switch and close the circuit if I remove the switch.
    This is the fuse tap?
    http://www.amazon.com/3M-Scotchlok-..._1?ie=UTF8&s=industrial&qid=1301270621&sr=8-1
    The way I see it you'd need a fuse tap on both sides of where you cut the wire. Then you put a jumper b/n the two fuse taps. Correct?
  10. Mar 27, 2011 at 6:18 PM
    primer
    T
    OK
    Is this it:
    Put the fuse tap on the wire and close it. That will cut the wire and break the circuit. To the terminals of my switch I'll connect short lengths of wire with male spade connectors attached. The spade connectors will go in the fuse holder - allowing the switch to close and open the circuit.
    If I remove the switch I can just put a fuse in the holder and that will close the circuit - unless the fuse blows. (10a fuse ok?)
    That it?
  11. Mar 28, 2011 at 6:26 AM
    primer
    T
    OK
    Got it. Thanks. I assumed the fuse holder would cut the wire itself. Hopefully I'd have figured that out - but I'm glad you clarified just in case.
    Do you know what gauge wires these are so I can get the right size fuse tap?
    Thanks again.
  12. Mar 28, 2011 at 1:15 PM
    primer
    T
    OK
    Thanks
    TL
  13. Mar 28, 2011 at 6:42 PM
    primer
    T
    OK
  14. Mar 29, 2011 at 5:22 PM
    primer
    T
    OK
    Actually - I think I want this button to be kinda stealth anyhow. My not light it at all. If I did I think I would want it on only when the DTRL are off. I'm not sure that is possible.
    TL
  15. Mar 30, 2011 at 8:08 PM
    primer
    T
    OK
    Hey thanks.
    Am I correct that in the second pic when I press the button the DTRL will be off, but the switch light will be on - then I press again and the DTRL will come back on but the switch light will go off?
    Thats what I'm after.
    TL
  16. Mar 31, 2011 at 7:32 PM
    primer
    T
    OK
    Great, thanks.
    The ground wire can go to the frame or steering column or something can't it?
  17. Apr 1, 2011 at 8:13 PM
    primer
    T
    OK
    Thanks.
    Looked for the fuse taps at Home Depot and Pep Boys without success. I'm going to try Radio Shack this weekend.
    I can order from Amazon or a few other places. Any idea who might carry them locally?
  18. Apr 10, 2011 at 5:40 PM
    primer
    T
    OK
    A few roadblocks today. Biggest one was my soldering iron died. I've got most of it done but realized my switch doesn't look like the pics. I'm not sure how to wire it.
    I'm assuming the + and - are for the illumination like in the other terminal pattern. The group of 3 aren't labeled. Should I assume they are the same?
    Thanks
    TL
  19. Apr 10, 2011 at 7:16 PM
    primer
    T
    OK
    WHAT?! No spoonfeeding?
    Just kidding. You've spoiled me up to now.
    I think I understand what you're saying. I set up a small 12v battery with an LED in a simple circuit so that I could test a variable resistor when I lit my 4x4 switch. Here I just need to insert the switch in the circuit and see what arrangement works.
    Do I need to put a resistor in the circuit to prevent damage to the LED in the switch? I assume there's nothing else I can damage.
    Thanks again.
    TL
  20. Apr 10, 2011 at 8:07 PM
    primer
    T
    OK
