Switch-Pro 8 switch panel group buy!
Discussion in 'Automotive Group Buys' started by Spixelz, Sep 3, 2015.
  1. Aug 9, 2016 at 12:41 PM
    #701
    HABOOBS
    HABOOBS Well-Known Member
    Bill
    Phoenix AZ
    2008 AZ-BASED DCSB
    Thanks for the heads up! I'll keep this in mind.
    MoQS[QUOTED] likes this.
  2. Aug 9, 2016 at 12:43 PM
    #702
    IronPeak
    IronPeak PermaLurker
    AuggieX
    Back to Back
    2007 sr5 4x4 DCLB/2015 TRD sport 4x4 DCLB sold
    Bigger Taller Slower
    Great now instead of torturing myself here and there when there is a 20% off sale ( I spent enough money on mods this year!!) I can be in constant state of when when when can I get my switchpro!!!
  3. Aug 9, 2016 at 7:11 PM
    #703
    MoQS
    MoQS Well-Known Member
    Merel
    Missouri
    MGM OR DCSB
    I may have missed it in the thread, has anyone here printed any custom switch labels?
    MadeInMaine likes this.
  4. Aug 17, 2016 at 4:52 PM
    #704
    Acerwin
    Acerwin The unNORM NORM
    Andrew
    South Carolina
    Toyota Tundra
    Anymore 20% off deals coming up soon?
  5. Aug 17, 2016 at 5:31 PM
    #705
    HABOOBS
    Bill
    Phoenix AZ
    2008 AZ-BASED DCSB
    If you don't already subscribe to AutoAnything's email for promotions, do so and you get 20% off of your first purchase. It would be a switch-pro for $383.20 with free shipping.
    That's what I plan on doing in the next month or so. Still not 100% sure I wanna do switch pros over spod though...
    Acerwin[QUOTED] likes this.
  6. Aug 17, 2016 at 5:31 PM
    #706
    Acerwin
    Andrew
    South Carolina
    Toyota Tundra
    Thanks buddy
  7. Aug 18, 2016 at 5:39 PM
    #707
    the dashing ham
    the dashing ham Taco n00b
    Scotty
    Los Angeles
    '12 DCLB rattle can
    yes, I have done the mods
    I got an email from Autoanything this morning telling me that the code VIP20 will give you 20% off any order over $79, lasts through today.
    Acerwin likes this.
  8. Aug 24, 2016 at 2:50 PM
    #708
    HABOOBS
    Bill
    Phoenix AZ
    2008 AZ-BASED DCSB
    Hey Guys,
    I'm about ready to pull the trigger on this set up... But I am so out of my comfort zone when it comes to electrical stuff... From what I understand, each accessory positive cable connects to the positive cable on the switchpro power module, but then each accessory negative needs to be ground somewhere.. I was wondering what you guys are using to ground each of your accessories? Bus Bar? If so, any particular model/brand?
    If it makes a difference, I'll be using all 8 outputs on the power module.
    Just wanting to make sure I'm doing this the right way.
  9. Aug 24, 2016 at 2:54 PM
    #709
    Acerwin
    Andrew
    South Carolina
    Toyota Tundra
    Ordered mine yesterday
    XPOTRPR likes this.
  10. Aug 24, 2016 at 3:39 PM
    #710
    XPOTRPR
    XPOTRPR CNC Programmer/Machinist
    Josh
    Chandler, AZ
    > BUILD LINKS >
    just ground to the nearest possible point. you want your grounds as short as possible anyways. all my accessories are ground to the truck. either the frame or a bolt. and I use all of mine as well.
  11. Aug 24, 2016 at 4:36 PM
    #711
    HABOOBS
    Bill
    Phoenix AZ
    2008 AZ-BASED DCSB
    So people using the bus bars... what are they using em for? Other things not related to the switchpros in most cases?
  12. Aug 24, 2016 at 4:46 PM
    #712
    HABOOBS
    Bill
    Phoenix AZ
    2008 AZ-BASED DCSB
    Also, what sort of range are you guys getting out of your blue tooth signal? Wondering how far away from the truck I'll be able to control the switchpros via my phone.
  13. Aug 24, 2016 at 4:58 PM
    #713
    XPOTRPR
    Josh
    Chandler, AZ
    > BUILD LINKS >
    I think they are using those in conjunction with a regular rocker switch panel. The Switchpro really is that easy. plug it in to power, tap into ignition, etc.. then just start connecting your power leads.
    I havent tried it.. I never use the bluetooth. its more of a pain than just hitting the switch.
    scott96929 likes this.
  14. Aug 24, 2016 at 5:00 PM
    #714
    Acerwin
    Andrew
    South Carolina
    Toyota Tundra
    So everything needed to get started comes with the switch pro kit I ordered? I ask cause I see a lot of people having other things hooked up to it also
  15. Aug 24, 2016 at 5:01 PM
    #715
    XPOTRPR
    Josh
    Chandler, AZ
    > BUILD LINKS >
    like what?
    and yes.. everything you need comes with it.
  16. Aug 24, 2016 at 5:02 PM
    #716
    Acerwin
    Andrew
    South Carolina
    Toyota Tundra
    I've seen a bussman hooked to one somewhere on here. Also did you just call or email switch pros for the vertical switches?
  17. Aug 24, 2016 at 5:08 PM
    #717
    HABOOBS
    Bill
    Phoenix AZ
    2008 AZ-BASED DCSB
    Got cha... just did the read up on TCT Magazine on the switch pros and they use the 150A Blue Sea Terminal Bus to help with grounding and to keep things simplified even further. It's a clean set up.
    As for the bluetooth... if anyone has any experience, please share. I have a feeling that I'll use it while camping quite a bit, especially for when nature calls in the middle of the night.
    Acerwin likes this.
  18. Aug 24, 2016 at 5:18 PM
    #718
    Acerwin
    Andrew
    South Carolina
    Toyota Tundra
    I think I may need one of those 150A blue sea terminal bus....got a pic of it installed with the switch pro?
  19. Aug 24, 2016 at 5:39 PM
    #719
    XPOTRPR
    Josh
    Chandler, AZ
    > BUILD LINKS >
    Interesting. I don't think I've seen that.
    Yeah I just emailed them. They sell them, but they sent me a pack for free.
    I dont see a need for anything more than the switchpros.. I havent had any issues and it's just more shit to install, take up real estate, and worry about.
  20. Aug 24, 2016 at 5:39 PM
    #720
    HABOOBS
    Bill
    Phoenix AZ
    2008 AZ-BASED DCSB
    blackradon and Acerwin[QUOTED] like this.
