Switch-Pro 8 switch panel group buy!
Discussion in 'Automotive Group Buys' started by Spixelz, Sep 3, 2015.
  1. Mar 2, 2016 at 9:18 PM
    #61
    adio
    adio Well-Known Member
    HI
    2015 INFERNO TRD PRO
    X2. I want in on one also. I also got the kit but still haven't installed it yet because I have no clue where I want it. So it would be great to see where y'all be installing it to get some ideas.
  2. Mar 3, 2016 at 4:07 AM
    #62
    Joelev
    Joelev Well-Known Member
    I'd be very into a bezel, myself. I grabbed one on AutoAnything (it just shipped) and have been wanting mine in the sunglasses pocket of my '12, but haven't taken a look at how to make it so it won't pop open every time I hit a switch.
  3. Mar 3, 2016 at 5:15 AM
    #63
    reidbailey
    reidbailey Well-Known Member
    Reid
    Redondo Beach
    2011 4Runner
    You can have a button do different functions depending how you press it. Typical on/off, momentary, strobe or link to an "all on" for whatever outputs you preselect. It's really quite configurable.
    I'm looking forward to getting it installed too. Just don't want to rush the install and have it look like a wart on the dash. The underwood should be easy. I'll post pics along to way. I'll also be wrapping up my ACR install when I put the SwitchPros in.
    Thanks for seeing what you can do with a bezel for the controller. That may make all the difference!!!
  4. Mar 3, 2016 at 6:03 AM
    #64
    XPOTRPR
    XPOTRPR CNC Programmer/Machinist
    Josh
    Chandler, AZ
    > BUILD LINKS >
    yeah I've been eyeing these for a while now. If they are able to do what I'm looking for.. ill snag one for sure! Might need to reach out to them or get the manual somewhere.
  5. Mar 3, 2016 at 6:05 AM
    #65
    Joelev
    My main thing now is trying to think through how to run all my ground wires in a way that will keep everything clean. Was looking at a Blue Sea post with multiple screw-ends, but I might just end up crimping rings to everything and keeping a post clean.
  6. Mar 3, 2016 at 6:06 AM
    #66
    XPOTRPR
    Josh
    Chandler, AZ
    > BUILD LINKS >
    ground wires from the switch or the accessory/lighting?
  7. Mar 3, 2016 at 6:22 AM
    #67
    Joelev
    From the accessories.
  8. Mar 3, 2016 at 7:14 AM
    #68
    XPOTRPR
    Josh
    Chandler, AZ
    > BUILD LINKS >
    just run them to the nearest ground. no need to run long ground wires all the way back to the engine bay.
  9. Mar 3, 2016 at 8:22 AM
    #69
    reidbailey
    Reid
    Redondo Beach
    2011 4Runner
    +1 Exactly
  10. Mar 3, 2016 at 8:26 AM
    #70
    reidbailey
    Reid
    Redondo Beach
    2011 4Runner
    http://store.switchpros.com/content/SP8100 directions updated no SD drawing.pdf
    http://store.switchpros.com/content/Switch Pro Wiring page.pdf
    Hope this helps. Let me know if I can try to answer any questions.
    Edit: Not sure those links are working. If not, try scrolling to the bottom of this page. http://store.switchpros.com/sp-8100-8-switch-panel-power-system/
  11. Mar 3, 2016 at 8:31 AM
    #71
    XPOTRPR
    Josh
    Chandler, AZ
    > BUILD LINKS >
  12. Mar 3, 2016 at 8:34 AM
    #72
    reidbailey
    Reid
    Redondo Beach
    2011 4Runner
    What are you trying to do?
  13. Mar 3, 2016 at 8:49 AM
    #73
    XPOTRPR
    Josh
    Chandler, AZ
    > BUILD LINKS >
    just sent SwitchPro an email with my questions..
    Well.. I am in need of 3 pole switches.. I will be running LED pods that require them. currently, my only option are rocker switches, and to get what I'm trying to go for (individually controlled LEDs in the switch, constant emblem "on", etc) its turning into a bigger project than expected.
    The switchpro.. IF it could be programmed as a 3 position.. would make my life SOOOOOOO much easier. they would do what i want right out of the box in a small slim and clean design!
  14. Mar 3, 2016 at 8:52 AM
    #74
    Spixelz
    Spixelz [OP] Well-Known Member
    Jesse
    Forest Grove, Oregon
    2015 White 6spd DCSB OR
    Icon Stage 4 w/Dakar Leafs
    FYI if anyone is looking to buy one of these systems. They can be had on AutoAnything.com right now for $407 shipped using the 15% Code "TAX15"
  15. Mar 3, 2016 at 8:53 AM
    #75
    XPOTRPR
    Josh
    Chandler, AZ
    > BUILD LINKS >
    fuuuuu... so tempting if it could do what i want. :pout:
  16. Mar 3, 2016 at 8:55 AM
    #76
    Spixelz
    Jesse
    You could wait until the next 20% off sale and get it even cheaper. I paid 383 shipped for mine.
    scott96929 and reidbailey like this.
  17. Mar 3, 2016 at 8:55 AM
    #77
    reidbailey
    Reid
    Redondo Beach
    2011 4Runner
    Gotcha. You can do it with two outputs and a relay (even solidstate) but that kind of defeats the purpose of this streamlined package.
    It would be cool if they could add that functionality via a Bluetooth firmware update!
  18. Mar 3, 2016 at 8:58 AM
    #78
    XPOTRPR
    Josh
    Chandler, AZ
    > BUILD LINKS >
    Good to know! Thanks
    Exactly... Thats what I started getting into with the rockers.. Relays, more wire, less room, etc.
    I wonder if they could chnage the programming on their end? I can't imagine these things are mass produced to the point that they have no hands on with them. One off custom programmed?? :D high hopes I know..
  19. Mar 3, 2016 at 9:08 AM
    #79
    alphabravo
    alphabravo Well-Known Member
    Christopher
    Canada via FL
    2003 Tacoma TRD
    Supercharger AntiDark Hood Light Redline Tuning Hood Struts Morimoto Projectors Grey Wire Mod Tundra 13WL Brake Conversion EBC ED Pads and GD Rotors Mean Green Starter DC Power 250A Alternator Odyssey PC2150 Battery, Artec Cage ADS shocks Total Chaos UCA ComeUp Winch, Factor 55 Splicer Relentless bumpers OTRATTW Switches, Bussman 15304-2-2-4 RTMR, Paranoid Fabrication switch brackets Jensen JHD3630BT Morimoto XB LED Fogs Deaver Custom Springs Ivan Stewart TRD Wheels, Pro Series TRD Wheels
    I think it is a pretty small company. The owner is an engineer or something and they have their own in-house cad/cam. Not sure about the electronics and logic programming. @Moose1988
  20. Mar 3, 2016 at 9:11 AM
    #80
    XPOTRPR
    Josh
    Chandler, AZ
    > BUILD LINKS >
    Appreciate the input man. We shall see. Sent them an email explaining everything and asking if they could reprogram it. It can do it obviously.. I just dont want the flash or strobe.. Just a second constant on.. I dont think it would be that difficult to change from a flash to solid on. But who knows..
