Switch Pro 9100 questions
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Sk8virt, Feb 10, 2018.
  1. Feb 10, 2018 at 12:45 PM
    Sk8virt
    Sk8virt [OP] Active Member
    Brian
    2015 4Door 4x4 TRD Off Road
    Icon Stage 6 Suspension w/Billet UCAs 17" Method NV wheels Falken WildPeak tires 285/75/17 Pelfreybilt bumpers Front and Rear Pelfreybilt Rocksliders and IFS Skid Matte Black Emblems Switch Pro 9100 Baja Designs 20" light bar Baja Designs flush mount rear floods Baja Designs Squadron Fogs Redline hood struts Rechelon Asthetics LED projectors K&N
    Hello all, new to TW
    And I needed some help/advice for wiring up this new SP 9100.
    I'm having 3 issues;
    1) Where to put the switch panel? I'm thinking the center consol would be best?
    2) I need to connect the three "control wires" and I need a good reference for finding an
    "ignition controlled" wire
    A Parking Light signal wire
    And a High beam signal wire
    These are the three control wires needed for the 9100 for external control of accessories and switch panel backlighting illumination.
    3) Possibly looking for a bracket to mount the Power Module next to the fuse box and thinking a bus bar might be the cleanest way to connect my accessories to ground.
    Any help/advice would be greatly appreciated
    CMScheid likes this.
  2. Feb 10, 2018 at 5:27 PM
    CMScheid
    CMScheid Well-Known Member
    Cody
    NorCal
    2017 Silver Tacoma TRD Off-Road
    front ADS 2.5 Coilovers with RR JD Fab LT 2.25" LCA Pivot Steering Slide Rack (pending) rear 2.5 RR smoothies Archive Shock Relocation TJM HD Leaf Pack BAMF Hangers & HD Shackles BAMF Bumpers BAMF Trilogy Skids
    I have similar questions! My SP9100 showed up early this week but I have so many questions to be answered. I like how @monkeyevil mounted his just below the sunroof, but I don’t know how to run my wires...
    One that I can answer for you on #3, PowerTrays! @Mr.PowerTrays
    https://www.tacomaworld.com/threads...ssories-and-more.518174/page-12#post-17115716
    I’ve been waiting for them to be back in-stock....
  3. Feb 10, 2018 at 5:47 PM
    Sk8virt
    Brian
    Thanks for telling me about the @mr.powertray...that's perfect!
  4. Feb 10, 2018 at 6:13 PM
    SoJersey
    SoJersey South Jersey Defense
    Brandon
    08302
    '12 DC Offroad
    Pelfrey Armor Baja Designs Lights 6112/Camburg/Dakar Suspension Method Wheels / BFG KO2 ARE Z-Series More coming soon...
    Doc V likes this.
  5. Feb 10, 2018 at 7:09 PM
    Sk8virt
    Brian
    That's a cool bracket too...are you able to close the sunglass holder or is it in the open position all the time?
    Thanks for sharing
  6. Feb 12, 2018 at 7:22 AM
    Zac of all trades
    Zac of all trades FWP Fabrication Vendor
    Zac
    fwpfab.com
    2013 4x4 Locked DCLB
    886/5100s/AAL/UCAs/360 armor/RTT/295 17s
    The directions will show you which wires to tap into. For the illumination wiring you will tap into one of the wires that plug into your headlight in the engine compartment.
    I ran my switch panel to my overhead console inside the sunglass holder. A YouTube video will show you how to remove the overhead console for access. It's clean and out of sight the way I like it.
    And I would suggest getting a bus bar. Easy to swap devices. Also it you want to rearrange then it's easier.
    I have an 8100 and can post a couple pics if needed.
  7. Feb 12, 2018 at 9:14 AM
    Sk8virt
    Brian
    The directions for the 9100 actually don't show you which wires to tap into.
    The 3 control wires that you have to splice into are:
    1) an ignition wire that's only getting a 12V signal when the ignition is on
    2) parking light/turn signal
    3) high beam or dome light.
    Everything else is pretty straight forward.
    Zac of all trades likes this.
  8. Feb 12, 2018 at 10:10 AM
    Zac of all trades
    Zac
    fwpfab.com
    I will grab some photos of what i did and see if that will help you out.
  9. Feb 17, 2018 at 8:53 AM
    CMScheid
    Cody
    NorCal
    Are those photos still able to happen?
  10. Feb 17, 2018 at 9:08 AM
    Doomsday
    Doomsday Well-Known Member
    Cypress, TX
    2017 TRD Sport 4x4 DCSB MGM
    Lights, Tires, Wheels,...more to come!
    I have a 3rd gen, but I'm guessing the fuse panel is similar. Just double check. Also, I picked up some more fuse taps from Amazon just like the one thats in the SP9100 box. As for the PINK wire, I just left it off. I only ran the WHITE & LT BLUE wires only, worked out perfect! I mounted the Switch Pro using the SDHQ mount both for switch panel and module mount.
    Here you go, used this to help me tap into. Keep in mind this is an SP8100, so the SP9100 will have different colored wires that need to be tapped. Otherwise, the same functions. See post #11.
    https://www.tacomaworld.com/threads/mr_ashs-3rd-gen-road-tripping-build.443263/
  11. Feb 17, 2018 at 5:44 PM
    Zac of all trades
    Zac
    fwpfab.com
    Here is where I tapped into the headlight.
  12. Jul 23, 2019 at 5:04 PM
    JHEAL77
    JHEAL77 "I love mom"
    Cincinnati, OH
    2015 Black Tacoma TRD Off Road
    I’d love to see where everyone is physically tying in for the connections. I was testing the under hood fuse box with a test light. I am still unsure of the proper connection points.
    HELP!!!!
  13. Jul 23, 2019 at 11:06 PM
    Coop68
    Coop68 Well-Known Member
    Coop
    Erie/Dacono, CO
    2014 TRD OR Magnetic Gray
    Method double standards 16" COOPER S/T MAXX 285/75/16 DEI clifford 2-way remote start with smart-start. Lift Kings with Dakar TC UCA extended brake lines Keyless POP-N-Lock tailgate lock,relentless tailgate reinforcement, Weather Tech Mats all around, pelfreybilt front bumper steel with middle hoop warn VR-8000s switch Pro lights coming soon see build thread
    I have some info in my build thread. I have 8100 I just used add a fuse for mine.
    Main thing you need to find is a 12v source that is hot when the tuck turns on and 12v source when you turn your lights on most wire to the marker shown above.
