Switch-Pros 8100
Discussion in '3rd Gen. Tacomas (2016-2023)' started by qxrtz4321, Jul 11, 2016.
  1. Apr 11, 2017 at 3:10 PM
    BarberRider
    BarberRider Merit Badges: Scuba Cliff diving Mirror Awareness
    Fletch F. Fletch
    Trussville, AL
    1974 Dodge Monaco
    It's got a cop motor, a 440-cubic-inch plant. It's got cop tires, cop suspension, cop shocks. It's a model made before catalytic converters so it'll run good on regular gas.
    You don't need anything, just slightly enlarge the hole thats already there from the cubby and install it.
    I wish they had other colors when I got mine.
  2. Apr 11, 2017 at 3:14 PM
    JoeCOVA
    JoeCOVA Well-Known Member
    Joe
    Colorado Springs
    PM sent. I'll clarify that it's a bezel piece that mounts into the stock panel. Looks like SDHQ completely replaces it so they are different.
  3. Apr 11, 2017 at 3:15 PM
    aaen
    aaen Well-Known Member
    Northern Alberta
    2016 DCLB 4x4 TRD Sport BBP
    Kings, ARB Summit Bumper, SMittybilt Winch, vagabond Drifter, Prinsu Cabrac, Crusinoffroad slidersand rear bumper
    I know I need to just enlarge the cubby, just saying is there is a member that is making a replacement panel for the 3rd gens, I'd gladly buy it instead of cutting up my panelings. Toyota here in Canada charges a bloody fortune for parts, 400 dollars for weather stripping and a few other parts i've priced out were nearly double the US pricing (even with the conversion), just means when I need anything I go south of the border buy it and bring it back as per usual.
    Zulupapa likes this.
  4. Apr 11, 2017 at 3:23 PM
    BarberRider
    Fletch F. Fletch
    Trussville, AL
    1974 Dodge Monaco
    I havnt seen anyone offer that. I've seen 3D pronted trim pieces.
  5. Apr 11, 2017 at 3:24 PM
    aaen
    Northern Alberta
    Have one of thos eon order. The post above is a replacement panel which is pretty slick. But pricey.
  6. Apr 11, 2017 at 3:33 PM
    tubbsisland
    tubbsisland I took snowtanks beer
    Cliff
    Arizona
    SDHQ purchases a complete OEM panel from Toyota (which are different between 16 and 17+) then laser cuts them to precise dimensions to fit a switch pros with hidden hardware. Takes a lot of the headache out of installing them since some people lack the patience or Dremel skills to get the panel perfect.
  7. Apr 11, 2017 at 9:53 PM
    ColfaxKP
    ColfaxKP Active Member
    Kevin
    2016 DC Limited 4x4 Metallic Grey
    Sweet mod
  8. Apr 19, 2017 at 3:09 PM
    riz_atx
    riz_atx #bigpermtaco #teamBP
    Sohail
    Spicewood Texas
    ‘16 4x4 DCLB GFC Locked, Geared, Tuned
    C4Fab/RCI/BAMF, ADS, 4.88, Lockers, OVTune
    So where did you end up connecting the blue and yellow leads? Im leaning to running them into the cab and using a the Tail Light fuse for yellow and the Ign No1 for blue. I read this on a post from @mr_ash's build thread on his 3rd gen.
  9. Apr 19, 2017 at 4:25 PM
    qxrtz4321
    qxrtz4321 [OP] Well-Known Member
    Mitch
    Montana / Washington
    That what I used
    riz_atx[QUOTED] likes this.
  10. Apr 19, 2017 at 4:43 PM
    riz_atx
    Sohail
    Spicewood Texas
    Awesome. Thanks for the confirmation!
  11. Jun 28, 2017 at 4:53 AM
    I_Am_kasc0
    I_Am_kasc0 Well-Known Member
    Darren
    '17 Tacoma TRD Pro
    I used the tail and ign2 with tap a fuses, this was a super simple install...BUT... it seems I don't have a good connection on ign2 (I think). Right now my AC system, backup monitor and outside temperature display are not working. I've only installed ditch lights so far. Has anyone else had this issue with this setup?
    I'm hoping it is just that I didn't secure the tap a fuse but the ditch lights and switch are working as expected.
    Secondary question, hooking up the ditch lights...I got the CaliRaisedLED lights with harness..I cut into the red, white and black wires that go towards the switch, brought the red and white wires together and hooked those to the switch pro. Anyone see an issue with this?
  12. Jun 28, 2017 at 7:35 AM
    riz_atx
    Sohail
    Spicewood Texas
    Are you using the switch in the harness that came with those LEDs? I cut my rigid harnesses to basically be the deutch connectors and red and black wires both run to the switch pro. No other switches or anything needed.
  13. Jun 28, 2017 at 7:53 AM
    I_Am_kasc0
    Darren
    '17 Tacoma TRD Pro
    No, not using any additional switches... only the switch pro. I just disconnected the harness supplied switch from the harness and the cut the red, black and white wires below the connector. Combined red and white to switch pro red wire and grounded the black wire. From the harness, the red line with the fuse and the ground wire with the hoop connector are not connected.
