Switch Pros 9100 install and BS thread
Discussion in '3rd Gen. Tacomas (2016-2023)' started by PNWTacoma, Feb 16, 2018.
  1. Dec 10, 2018 at 4:23 PM
    #261
    Parker315
    Parker315 Modding on a Budget | TTC Member #0127
    Brett
    Cypress Texas
    17 Tacoma TRD Sport DCSB MGM
    TTC (Texas Toyota Coalition) Member #127
    Well look there. I came to Lowe's and look what I found
    JoeCOVA[QUOTED] likes this.
  2. Dec 10, 2018 at 5:11 PM
    #262
    DSIM
    DSIM Well-Known Member
    Daniel
    Raleigh, NC
    2017 MGM Tacoma TRD Off-Road
    Ummm this wasnt expensive at all guys...
    Dymo LabelManager 160 - AMAZON - $18
    Heat Shrink Tape - AMAZON - $11
    The 1/2 inch works perfectly you can crimp your terminals and its large enough to slip over... I wanted a label maker anyways to be able to label my toolboxes in the garage, the heat shrink is icing on the cake.
  3. Dec 10, 2018 at 5:38 PM
    #263
    Parker315
    Brett
    Cypress Texas
    What!!! That label maker will print onto the heat shrink? I just saw it a Lowes and it was $80 for the printer. I never saw one that cheap.
    @JoeCOVA problem solved maybe :thumbsup:
    DSIM[QUOTED] and JoeCOVA like this.
  4. Dec 10, 2018 at 5:44 PM
    #264
    DSIM
    Daniel
    Raleigh, NC
    Worked like a charm for me.
  5. Dec 10, 2018 at 6:00 PM
    #265
    Parker315
    Brett
    Cypress Texas
    Damnit!!! Thanks for sharing man :thumbsup::cheers:
  6. Dec 10, 2018 at 6:05 PM
    #266
    JoeCOVA
    JoeCOVA Well-Known Member
    Joe
    Colorado Springs
    Oh nice. I thought those only printed to paper.
    DSIM and Parker315 like this.
  7. Dec 10, 2018 at 6:50 PM
    #267
    Sub_Par
    Sub_Par Well-Known Member
    Buffalo NY
    2011 TRD Off Road
    When I did my aux relay setup, I just used a cheap dymo label maker and clear heat shrink. Put the label under the heat shrink and it worked out great.
  8. Dec 10, 2018 at 6:53 PM
    #268
    PNWTacoma
    PNWTacoma [OP] Well-Known Member
    Paul
    PDX 3rd party OV Tuner
    2025 TRD Pro | Mudbath // 2017 Offroad DCLB OG
    PNW Adventures & PNW Tuning
    Are the dymo labels heat resistant? I only ask cause I used a regular label maker and it melted when the heat gun was used on my heat shrink.
    Parker315 likes this.
  9. Dec 10, 2018 at 6:57 PM
    #269
    Sub_Par
    Buffalo NY
    2011 TRD Off Road
    They didn’t melt when I used them, and I used a lighter on the heat shrink. It was a dymo 160 and whatever labels came with it.
    PNWTacoma[QUOTED][OP] likes this.
  10. Dec 10, 2018 at 7:09 PM
    #270
    DSIM
    Daniel
    Raleigh, NC
    I accidentally put the shrink on and heat it up before shrinking the shrink on the terminal on one wire. So I put a TON of heat on it installed on the terminal block with the heat shrink on top. I melted part of the fin of the terminal block but the heat shrink was fine.
  11. Dec 10, 2018 at 7:46 PM
    #271
    cemented
    cemented Well-Known Member
    Cole
    Portland, OR
    2017 TRD PRO Cement AT Maggy 84mm OTT
    It prints it directly on to the heat shrink, not just a label. This would work for what you wanted to do. I'll go halvesies with you. Lol
  12. Dec 10, 2018 at 8:28 PM
    #272
    PNWTacoma
    Paul
    Let's do it and charge $10 per use
  13. Dec 10, 2018 at 8:29 PM
    #273
    cemented
    Cole
    Portland, OR
    I like where your head is at!
  14. Dec 10, 2018 at 8:30 PM
    #274
    PNWTacoma
    Paul
    #Janitorlife
    cemented[QUOTED] likes this.
  15. Dec 16, 2018 at 5:44 PM
    #275
    ACTaco4me
    ACTaco4me Active Member
    2019 Tacoma OR 4x4 DCSB
    I just installed this switch and like it so far, except the app that seems very slow. I only have the Raptor-like lights hooked up, but will be adding other lights soon.
    Quick question, is everyone getting the “loading” delay on the Switch Pro App every time you click on something (whether you click on an option, back, or exit the app)?
  16. Dec 16, 2018 at 5:52 PM
    #276
    Hextall
    Hextall Well-Known Member
    NH
    17 Inferno OR DCSB
    The app is pretty slow when in the setup type menus but is fast when operating switches..
    I did just get an update on the app on Android tonight. Haven't tried it yet since the update though.
  17. Dec 16, 2018 at 5:56 PM
    #277
    ACTaco4me
    I get that annoying loading page for a few seconds every time a click on anything on the app on my iPhone X.
  18. Dec 16, 2018 at 7:06 PM
    #278
    blackohio
    blackohio Well-Known Member
    Cliche Guevara
    white mudflap
    8100 unit.
    when i turn switch 4 on, it shuts back off and the switch blinks.
    if i swap switch 1’s wire out of the harness to position 4 on my bus strip the light works.
    sound like an issue with the 8100 unit itself? anyone had anything like this happen?
  19. Dec 16, 2018 at 9:24 PM
    #279
    h5863emtmatt
    h5863emtmatt Well-Known Member
    San Diego
    17' TRD OR 4x4 DCSB
    Method Vex311, Toyo Open Country AT, 2.0 Fox Performance Coilovers/Reservoir, Total Chaos UCA, Pelfreybilt, Prinsu Cabrac
    The app sucks on this. Have to wait for the load screen after every command. Well made unit bu not worth the $550 though. Should of gone with S-Tech.
  20. Dec 17, 2018 at 6:08 AM
    #280
    ACTaco4me
    I sent the vendor an email about this. Hope the could fix this.
    Let’s see if they reply back.
