Switch Pros 9100 install and BS thread
Discussion in '3rd Gen. Tacomas (2016-2023)' started by PNWTacoma, Feb 16, 2018.
  1. Jun 20, 2019 at 10:57 AM
    #481
    sagexp
    sagexp Well-Known Member
    Back home, AZ
    2002 Tacoma DC 4X4 2017 Tacoma DC 4X4
    I have not. The SP control panel shuts down and lights enabled by the ignition trigger turn off when the truck is turned off.
  2. Jun 20, 2019 at 12:31 PM
    #482
    caribe makaira
    Caribbean, Puerto Rico
    #4 White run wire to interior fuse (add-a-fuse/circuit) panel 2 choices:
  3. Jun 20, 2019 at 1:27 PM
    #483
    nvnv
    nvnv Stop geotagging
    Connor
    2016 Tacoma TRD OFF ROAD
    I might try the fuse you used then. I tried a different 10a injector fuse but found it was always hot. So I used a 15a inj fuse which works but like I said it stays on for 10 or 15 seconds after the truck is shut off.
  4. Jun 20, 2019 at 3:44 PM
    #484
    nvnv
    Connor
    Moved my ignition trigger wire to the same one you used and it shuts off immediately now. I didn’t see that fuse when I installed, its kinda hidden away from the other fuses.
  5. Jun 21, 2019 at 9:55 AM
    #485
    Lunchmeat79
    Lunchmeat79 Well-Known Member
    Kansas
    '18 Off Road
    Doing a little bench pre-assembly. Bent a couple brackets to mount it vertically. Not sure if the positives are ok this way or if I should go with a shorter cable and flip the module over. Also should positive go to module first then to fuse block? Let e know if you see any potential future issues.
    *edit* started going back through this thread and reading the 9100 instructions and have spotted a couple small changes already. Edit #2 ran into clearance issues running it vertically and had to lose the brackets and lay it flat. I'll try and make a cover when time allows.
    solscooter likes this.
  6. Jun 21, 2019 at 8:22 PM
    #486
    pop.tremuloides
    pop.tremuloides Well-Known Member
    Colorado
    2019 TRD OR DCSB
    DBACK HD, Armor, SP9100, lights...etc
    Pre-wiring questions....
    Hi folks, so I have just about all I need but have some questions for you wiring gurus. I will be the first to admit I am not the greatest at wiring so here goes....
    I’ll be installing Baja Design rock lights for my third brake lights and will be using the existing Taco wiring for the bed and brakes. What I will also be doing is using two amber rock lights as well wired to the 9100 (these will be in the Meso 3rd brake light housing).
    In the future, I will be putting in some rear ditch lights not sure what type yet.
    What I was wondering is just what type of wire (guage, brand, etc) to use so that I can pre-run the wires as I have panels and such pulled.
    Thoughts...again I am not the most educated on electrical issues so any and all suggestions would be appreciated.
    Thanks!
  7. Jun 26, 2019 at 11:02 AM
    #487
    SaphiraTaco
    SaphiraTaco Well-Known Member
    Sean
    Seattle WA
    2013 DCLB TRD Sport
    About halfway done...
    Looks good!:thumbsup: I drilled a hole and routed the SP power through the bottom plate. Just a little cleaner look IMO. I used a step drill which chewed through the aluminum like butter...
  8. Jun 26, 2019 at 12:17 PM
    #488
    caribe makaira
    The repetitive ilk...horizontal and uncovered...
  9. Jun 26, 2019 at 3:42 PM
    #489
    SaphiraTaco
    Sean
    Seattle WA
    2013 DCLB TRD Sport
    Not so fast Mr. Negative...
    I can sew
    Jeff Dartfrog likes this.
  10. Jun 26, 2019 at 6:17 PM
    #490
    caribe makaira
    :rofl:
  11. Jun 26, 2019 at 6:36 PM
    #491
    MGMSangTaco
    MGMSangTaco Colorado Toyota Tuning
    Denver, CO
    2017 TRD OR MGM DCLB
    Did you make that bracket to let the Sp9100 sit horizontally on the power tray or did you buy it? That’s awesome
  12. Jun 26, 2019 at 6:39 PM
    #492
    caribe makaira
  13. Jun 26, 2019 at 6:43 PM
    #493
    MGMSangTaco
    Denver, CO
  14. Jun 26, 2019 at 9:51 PM
    #494
    Lunchmeat79
    Kansas
    '18 Off Road
    @MGMSangTaco i used a piece of 1/8" x 3/4" aluminum from the hardware store. I scribed lines for the holes and drilled them before bending them side by side in my metal vice.
    MGMSangTaco likes this.
  15. Jun 26, 2019 at 11:36 PM
    #495
    nvnv
    Connor
    I use Ancor marine grade wire. You can get it on Amazon. The rock lights you can probably use 16ga wire since they only draw .4 amps each. Rear ditch lights I would use at least 14ga.
    For my Baja Designs Squadrons I used 14ga and for my 20” S8 bar I used 12ga.
  16. Jun 27, 2019 at 3:53 PM
    #496
    Wengel21
    Wengel21 Well-Known Member
    Ben
    SoCal
    2017 DC LB TRD OR
    Just use Liquid electrical tape spray after you’ve made your connections. Problem solved.
  17. Jun 29, 2019 at 5:13 PM
    #497
    Lunchmeat79
    Kansas
    '18 Off Road
    I finally got a chance to go out in the garage today and mess around a bit. I installed my sdhq battery terminals and leaned up my wiring. Can battery shops make custom cables? The short jumper has more torque on it than I think I want. Would like an end that is 90 degrees opposed from the other to eliminate the twist. 20190629_182434.jpg
    Bunk Moreland likes this.
  18. Jun 30, 2019 at 12:32 AM
    #498
    Wengel21
    Ben
    SoCal
    2017 DC LB TRD OR
    Finally had time to prefab my switch pro. This thread had a bunch of good ideas that I was able to apply.
    I have a few finishing touches to do like cleaning up the liquid tape around the terminals. I used it to seal all the locations that could get water (but most likely wouldn’t) like the switch pro plug, and the bust bar.
    I pre wired the bus with all weather connectors so when I add anything like a light bar or ditch lights, I’ll only need to wire up the male ends to the connector and I’m good to go. And with that sweet heat shrink label maker, organizing all this will be a breeze!
  19. Jun 30, 2019 at 12:36 AM
    #499
    Wengel21
    Ben
    SoCal
    2017 DC LB TRD OR
    Btw the best thing to get, is the 3:1 heat shrink with glue lining! Seals it tight and keeps the heat shrink from moving. Plus since it’s the 3:1 vs the Home Depot one that’s 2:1, it makes it way easy to put over the rings or crimps.
  20. Jun 30, 2019 at 12:43 AM
    #500
    caribe makaira
    My .02$ - if you have connectors to the "future" accessories, why this:
    Also, since the Tacoma is not fiberglass like a '70 VW Buggy or a pleasure boat, running the accessories grounds to a buss bar is so retro.
    ca08tacoma and Shellshock like this.
