Switch Pros 9100 install and BS thread
Discussion in '3rd Gen. Tacomas (2016-2023)' started by PNWTacoma, Feb 16, 2018.
  1. Aug 28, 2019 at 11:21 AM
    #581
    bestcoast91
    bestcoast91 Well-Known Member
    Concord, CA
    2018 OR 6MT
    Good to know, that's what I was hoping for. I was concerned it may be necessary to drop the headliner for install. I've got a couple other projects on the truck that are trying up funds, so I'm not quite ready to purchase yet.
  2. Aug 28, 2019 at 11:44 AM
    #582
    Shellshock
    Iowa
    Nope definitely don’t need to pull the headliner. It was super easy, as was routing the wire
    bestcoast91[QUOTED] likes this.
  3. Aug 31, 2019 at 6:59 PM
    #583
    blackohio
    blackohio Well-Known Member
    Cliche Guevara
    white mudflap
    not a 9100, grabbed a 8100 off someone here for inside my alucab canopy. matches up to the 8100 in my cab
    22138CB8-2E89-483D-B58A-FC0F916A4CBD.jpg 7373245D-621F-4F77-A73B-D9CD30D99F01.jpg
  4. Sep 3, 2019 at 7:17 PM
    #584
    pookguy
    pookguy New Member
    Can someone explain how to setup the output dimming? I see in the app there is a way to enable/disable. Once I enable it I don't see anywhere to actually set the dimming level??
  5. Sep 3, 2019 at 7:48 PM
    #585
    Shellshock
    Iowa
    Enable Output Dimming
    • Enables dimming of lights. All switch outputs are dimmable. The dimming function for each switch must be enabled in the App menu under settings/output dimming. When the dimming function is enabled, the switch will still function normal if pressed on/off. The dimming is actuated when pressing and holding the switch on for 1.5 seconds. The switch led indicator will start to flash fast for 1 second, indicating a 70% output. Then in 1 second increments the dimming will decrease to 50%, 30% and 10%. The switch led indicator flash rate will also decrease, indicating the level of dimming. When the desired dimming level is achieved, releasing the
    switch will lock in the dimming level. The level is not stored, and resets each time the switch is powered off. The next time the switch is turned on and dimmed, the level will start at 70% again.
    SaphiraTaco and pookguy[QUOTED] like this.
  6. Sep 12, 2019 at 8:05 AM
    #586
    ThatTacomaThough
    ThatTacomaThough Well-Known Member
    2017 White Tacoma TRD Off-road
    - SUSPENSION: - 6”BDS Full Suspension Lift w/ Fox Shocks - SPC Adjustable Control Arms RIMS AND TIRES: - Vision Off-Road 412 Rocker Satin Black Rims (20x13) - Hankook All Terrain Tires (35x12.5xR20 ) LIGHTING: - Custom headlights-Painted black and white on inside with products from TheRetrofitSource-Halos, Demon eyes, Custom DRL board (All on controller) - Meso Customs LED Side Markers (In headlight) - Meso Tacoma Puddle Pods - Meso Customs BD5 Brake Light Kit - YotaMafia 6 Piece Rock Light Kit (Turns On When Car Unlocked) - Unique Racing Style Switchback White/Amber LED Smoke Mirror Turn Signal Light - Vision Pro Led Bulbs F2 - VIPMOTOZ LED License Plate Lamp Assembly - Morimoto Type T XB LED Projector Fog Lights - FCKLight Bar RGB V-2 Series - Meso Custom Map & Dome Lights - Custom Made Raptor Lights From Step Bar LED Strips - Rough Country LED Ditch Lights 2” Square CREE (DRL Mode) PERFORMANCE: - S&B Filters 75-5096D Cold Air Intake - MBRP S5338P 3" Cat Back Single Side Aluminum (Cut slanted at 45” angle over axle) Exterior - Prinsu Roof Rack - TacomaBeast 8DX LED Tail Lights - TRD Pro Grill (W/ White Lettering) - GatorTrax Tonneau Cover - N-Fab Black Textured Wheel 2 Wheel Step Bars 3’ Tube AUDIO: - PIONEER TS-SW2502S4 10-Inch, 1.200 Watts Shallow-Mount Subwoofer X 2 - Pioneer GM-D1004 400W 4-Channel GM Digital Series Class FD Amplifier (For Door Speakers) - Kicker 46CSC674 6-3/4" 2-way car speakers (Front Speakers) - Kicker 43CSC6934 CSC693 6x9 3-Way Speaker Pair (Read Speakers) - Genuine Subaru H631SFJ101 Tweeter Kit - Rockford Fosgate R400-4D Prime 400 Watt Full Range Class-D 4-Channel Amplifier (For Pioneer Subs) ACCESSORIES - Black Inlays For Chrome Vent Rings - JDMCAR Center Console Organizer - TuffSkinz Coaster (White Inserts) - Black Tacoma Lettering Tailgate - White “Toyota” Lettering on tailgate by camera - Steering Wheel White Lettering (Over Tacoma Logo on Steering Wheel) - Painted Brake Calipers White - Door Sill White Lettering - Runnin4tacos 3/4” D-Ring Shackle (Buddy White) - Tacovinyl Grille Badge - AJT Key Fob - Remote Start - MICTUNING MIC-FB-202 Blade Block,12-Way Fuse Box Holder - Rockford Fosgate Single In-Line AGU Fuse Holder for 4 AWG or 8 AWG Wire
    So I recently ordered
    SP9100 Switch Pros-549$
    Switch Pro power tray -102$
    Blue sea systems blade ATO/ATC fuse block -39$
    Blue sea systems common Busbars 150a, 10 screw w/ Cvr-20$
    Blue sea systems 30a- 8 circuit terminal block-7.76$
    1. My truck is a manual so my first question is,
    Has anyone relocated the clutch fluid reservoir for the power trays
    2. How easy is it to install the switch pros? I know electrical work pretty well but I haven’t really seen an install video / people install it so many ways- that being said is there a best way to do the install?
    Thanks for your replies and time in reading this post.
  7. Sep 12, 2019 at 8:10 AM
    #587
    Shellshock
    Iowa
    I didn’t relocate mine. I used an SDHQ mount for the switch pro. I believe there is a power tray for MT that has a cutout for the reservoir. Not sure I’ve seen anyone do a relocation.
    Installation is pretty easy. I’ve posted a bunch of pics of my install in this thread. I’d definitely recommend coming into the fuse box following the factory harness and using the add a fuse / fuse tap. Makes for a very clean install and easy to change / disconnect / etc if necessary down the road.
  8. Sep 12, 2019 at 8:13 AM
    #588
    ThatTacomaThough
    Yeah I’ve see it on the SDHQ but haven’t seen it on power trays so I’ll let you know how that turns out I’m making a YouTube channel and we’re going to be doing install video on that and switch pros I can’t imagine that it’ll be too hard! Just never see videos for anything like that!
    If you could tag me in the threads you’ve posted with pictures I would really appreciate that! Also if you could inbox me I would love to ask you some more questions( I don’t know how to message people in here I’m new) thanks for your time brotha!
  9. Sep 12, 2019 at 8:23 AM
    #589
    ThatTacomaThough
    Did y’all powder coat your power trays? Looks really good!
  10. Sep 12, 2019 at 10:07 AM
    #590
    Bunk Moreland
    Bunk Moreland Well-Known Member
    Bunk
    It's complicated.
    Since you said that you're going to be making an install video; mind if I make a request/suggestion? Please, can you not add music to the narrated/instructional portions of your video? I see so many narrated, tutorial/instructional videos, where the creator adds background music, and the music is either too loud, or it's distracting, which makes it difficult to hear & listen to what the person is saying. It's like everything is a music video these days.
    I do look forward to seeing what you do. I have yet to install my SP9100; trying to decide how to best install it, ONE TIME, so that I don't have to mess with it over & over.
    Just my $0.02
    Thanks.
  11. Sep 12, 2019 at 10:32 AM
    #591
    ThatTacomaThough
    You already know brotha I got you
    Gunshot-6A and Bunk Moreland like this.
  12. Sep 12, 2019 at 1:41 PM
    #592
    Lunchmeat79
    Lunchmeat79 Well-Known Member
    Kansas
    '18 Off Road
    @ThatTacomaThough I did the same setup you are going with. I posted some pics a few months back. On a totally unrelated note I have developed a squeak in the clutch pedal. Dealer is going to warranty it all from the master cylinder down. I'm thinking I'm going to have to temporarily uninstall when I take it in, mainly bc i dont want them messing up my install.
  13. Sep 12, 2019 at 2:11 PM
    #593
    ThatTacomaThough
    I feel you could you tag me in the thread! Did you need any other materials other than what’s supplied from the switch pros and the other components that’s mount onto the power tray?
  14. Sep 12, 2019 at 3:16 PM
    #594
    Shellshock
    Iowa
    I’d recommend split loom or braided cable sleeve to protect your wire.
    A pile of connectors make life easier, in addition to heat shrink and zip ties.
    ceedless likes this.
  15. Sep 12, 2019 at 3:42 PM
    #595
    Citizen Rob
    Citizen Rob Well-Known Member
    Sacramento, CA
    2016 Tacoma TRD OR DCSB 4x4
    How in the hell is your engine compartment so clean?
  16. Sep 13, 2019 at 3:09 AM
    #596
    squarenone
    squarenone Well-Known Member
    SoCal
    2018 TRD OR 4x4 6sp-mt
    Check out my post a few pages back, I purchased the full powertrays setup with every option. Their stubby cables and ground cable made the install much easier. The clutch reservoir relocation is really simple and relocates it next to the brake reservoir and mounts to the powertray with a bracket, you'll see how it goes once you have it in your hands. I did have to trim the hose going into the firewall since the new position will cause the stock length hose to kink, I had to cut off about 2 to 3 inches.
    pop.tremuloides and Gunshot-6A like this.
  17. Sep 13, 2019 at 3:31 AM
    #597
    squarenone
    SoCal
    I wipe down everything that I can see and fit my hand into when I wash it every other week. My car wash takes about 4 hours though.
    This is my routine everytime I do a car wash:
    Thorough pre rinse including underframe and any areas where dirt accumulates, wash, clean doorjambs, spray wax, dry wheels, vacuum interior, wipe down interior, clean windows, clean underhood, underhood visual inspection, check oil level and consumption, lube UCA uniballs and a final visual inspection of the entire truck top to bottom.
  18. Sep 14, 2019 at 2:38 PM
    #598
    ceedless
    ceedless Well-Known Member
    Los Angeles, CA
    2018 Super White DC TRD OR
    Gear/Plan:
    Rigid Industries 50” straight LED light bar (Purchased, just need mounting brackets and wiring harness to arrive)
    Baja Designs Squadron Sport Amber ditch lights (pending)
    Baja Designs Squadron Sport Amber dust lights (pending)
    *** Pending - there is a huge OffRoad Show coming up at the end of Sept here in L.A. and I’m debating on whether I pull the trigger now or hope that BD will offer some discounts at this event to save some $$.
    Undecided:
    - Factory bumper is coming off and a custom tube bumper will be installed in a few months, hopefully. I’ll most likely have another set of Squadron Sports installed on the bumper by adding mounting tabs the custom bumper, to replace the loss of the stock fog lights from the factory bumper removal. A 30” LED light bar may also get installed into the custom tube bumper at some point down the road.
    - under the hood mounted onboard air compressor
    - winch
    I’m an admitted electrical wiring and install novice. But, I’m not an idiot, I can follow instructions and thoroughly enjoy that learning process. I also like to plan for project installs as much as possible. Putting together a parts list, for me at least, is a necessity to mitigate starts and stops during the install. I HATE not finishing a project because I forgot a fuse or harness or properly sized termination connections. Planning for future/potential additions, is also something I like to factor in, so that minimal effort is required when adding gear that I either didn’t have the funds for or need for, at the time of original install.
    I’ve installed the stereo systems in my last two trucks but, frankly, that doesn’t require much electrical knowledge in my opinion. I do like to DIY as much as possible, not just for $$$ saving but, more importantly, for learning and knowledge gains.
    Decisions, decisions:
    I understand some of the benefits for the Switch-Pros SP9100, I just don’t know if I can justify the cost. However, I also like to live by the mindset of, “do it once, spend $$$ smartly and do it the right way”. I’m also of the mindset, “I’ve got a 2018 truck, install new hardware/technology and keep it current and future proof”. I’ve also seen similar lighting installs that I’m planning to do, without the 9100.
    Without the 9100, is the install of all the under the hood hardware THAT MUCH more difficult?
    Do the benefits of the 9100, both install and day-to-day functionality, make the decision a no-brainer?
    If you don’t go the 9100 route, is your experience simply that, the entire install process and operation of the switches feels more “manual”?
    Are additional relays and terminal plates really necessary for what I’m planning to do?
    For an electrical noob, PowerTrays’ website appears to have almost everything required to complete a clean install...thoughts?
    Looking forward to hearing all of your experiences, thoughts and advice. TIA.
  19. Sep 14, 2019 at 3:02 PM
    #599
    Shellshock
    Iowa
    I started out without a Switch pro but after the first thing I decided it was probably worth the cost of one due to no longer having to fish wires through the firewall and having to find places to mount additional switches.
    The other thing is the switch pro has a ton of configuration options so you can have things keyed off the ignition, use a trigger wire, etc. I figured it was only a matter of time before I accidentally left something on and killed my battery. Some places that isn’t a big deal, others a dead battery could mean a long hike back to civilization. Definitely worth the peace of mind for me.
    With the switch pro, you run one set of wires through the firewall to mount the switch panel in the cab, then everything else can be done under the hood. Makes adding something new very quick and easy, just connect it or the switch pro leads under the hood, configure your switch and you are done.
    I have a trigger wire off my high beams so I have my ditch lights turn on and off with them. There’s also a hot key to enable / disable this (on vs off road) when desired.
    You don’t need any additional fuses or relays. All of that is part of the switch pro unit. You may need a relay for a compressor depending on the draw but that’s it.
    My switch pro is mounted on a SDHQ bracket under the hood. All my leads are connected via weathertight connectors. The power trays setups look pretty but take up a lot of room and leave your positive leads exposed to the elements which isn’t good. All my working is in split loom or cable sleeve.
  20. Sep 14, 2019 at 3:30 PM
    #600
    ceedless
    Los Angeles, CA
    Have any pics of your under the hood setup? Trying to figure out all of the hardware required as well. The 9100 unit is obvious but, then comes the possible mounting solutions for both under the hood and the cubby replacement. If you haven’t swapped out the SDHQ bracket, I’m assuming you’re satisfied? The Powertrays setup does look clean, which I thoroughly enjoy seeing...I’m anal when it comes to the cleanliness of the wiring. But, if the terminals and Blue Sea gear isn’t necessary, I don’t want to waste money purely for aesthetics, it needs to be functional as well.
    I haven’t read through the entire list of optional programming but, it would be nice to take advantage of the trigger option...I’d like to do something similar to how you wired your high beams to activate the ditch lights as well. If possible, tie in the 50” light bar to that trigger. That’s what has me on the fence, the optional programming of this unit is enticing.
