Switch Pros 9100 install and BS thread
Discussion in '3rd Gen. Tacomas (2016-2023)' started by PNWTacoma, Feb 16, 2018.
  1. Nov 20, 2019 at 8:27 AM
    #661
    Shellshock
    Iowa
    They come with a 5 amp fuse. Just use that
    SAPR53[QUOTED] and cemented like this.
  2. Nov 20, 2019 at 10:17 AM
    #662
    SAPR53
    SAPR53 Well-Known Member
    2019 TRD Offroad
    King 2.5" Ext resi with compress adjust Front and Rear ICON RXT Leafs ICON Tubular Delta Joint UCAs Xenon HD LED Low Beam Swap Baja Sports Wide Cornering Fogs Interior LED AVS In-Channel Extang Solid Fold 2.0 Tonneau
    Awesome thanks guys
  3. Nov 20, 2019 at 12:58 PM
    #663
    TuRDLYFE
    TuRDLYFE Well-Known Member
    An over-taxed town, county, and state
    2020 AG TRD Pro 6MT
    They're just signal wires and the current draw is basically parasitic (on the order of mA). They're just looking for voltage on that specific vehicle circuit. I put 2A fuses in all three.
    cemented likes this.
  4. Nov 20, 2019 at 1:31 PM
    #664
    deuceb
    deuceb Well-Known Member
    Denver | Austin
    2018 Taco BBPDCLBTRDOR | 2004 MB SL55 | 86 VW GTI
    It's been a while since I had gotten back to checking on this but opening things up I realized I do actually have it wired correctly, or at least I don't have that constant 12v wired to anything so it has to be something else. I can hear the relay clicking but the screen just goes blank. Unplugging those harnesses and plugging the factory ones back in and the video works. It's gotta be something dumb I'm doing, but apparently I've out- dumbed myself this time.
    cemented[QUOTED] likes this.
  5. Nov 20, 2019 at 9:30 PM
    #665
    SAPR53
    2019 TRD Offroad
    im looking to make a wire harness for my s8. Did you use 12g wire and if so I saw the Delphi weather packs for 12g had blue terminal seals but you using red ones. I was planning to use 12g wire but was unable to fit the copper in the weather pack terminal that came with the light. Did you use 14gauge? Also it looks like you used red, red, black for the connector to the green, white, black that comes off the light. Is that right?
  6. Nov 21, 2019 at 4:58 PM
    #666
    SearArtist
    SearArtist GX poor
    NC
    GX470 & GX460
    Things
    Tag
    just bought mine, now to go back and catch up on this thread.
  7. Nov 21, 2019 at 6:45 PM
    #667
    TuRDLYFE
    2020 AG TRD Pro 6MT
    The wire color is neither here nor there. I pre-wired using 10ga wire for the 40" S8 I have coming my way. 12ga is fine. You can get Delphi terminal kits (like I did) that will fit 10/12ga wiring:
    https://www.amazon.com/gp/product/B005OS5F1C/ref=ppx_yo_dt_b_asin_title_o00?ie=UTF8&psc=1
    https://www.amazon.com/Delphi-Femal...inal+10+ga&qid=1574390583&s=automotive&sr=1-5
    https://www.amazon.com/Delphi-12-10...ack+10+ga&qid=1574390708&s=automotive&sr=1-10
    Honestly, I should have gone with the metri-pack setup, but I'm cheap and couldn't find a decent knock off.
    ca08tacoma likes this.
  8. Nov 22, 2019 at 12:52 PM
    #668
    3cTaco
    3cTaco Active Member
    '18 TRD Pro
    I like this set up. I assume you made the mounting plates for the terminal blocks yourself? Got some details on how this is put together?
  9. Nov 22, 2019 at 4:56 PM
    #669
    SAPR53
    2019 TRD Offroad
    Does anyone have a good shot of where the power trays leg attaches to the fender? It says the bracket the two differential hoses are attached to but that feels like a rubber plug not a bolt. Any guidance?
  10. Nov 23, 2019 at 5:28 AM
    #670
    SAPR53
    2019 TRD Offroad
    Figured it out
  11. Nov 23, 2019 at 10:01 AM
    #671
    SAPR53
    2019 TRD Offroad
    Just powered up truck got a red light on the power module? Normal or bad?
  12. Nov 23, 2019 at 10:16 AM
    #672
    crashdb
    crashdb I break chainsaws
    Dave
    Manassas, VA
    2008 Toyota Matrix
    Rollin' hydrocarbons!
    Think it's normal.
  13. Nov 23, 2019 at 10:27 AM
    #673
    Shellshock
    Iowa
    normal. The 3 lights tell you if that wire is active.
    IGN
    Lights
    Trigger
  14. Nov 23, 2019 at 11:14 AM
    #674
    SAPR53
    2019 TRD Offroad
    Awesome appreciate all the help this morning. Now if I can just get the dumb app to during the scan to pick something up
  15. Nov 23, 2019 at 11:21 AM
    #675
    crashdb
    Dave
    Manassas, VA
    2008 Toyota Matrix
    Connect outside the app first.
  16. Nov 23, 2019 at 12:59 PM
    #676
    Shellshock
    Iowa
    sometimes it doesn’t like to connect. Usually a power cycle solves the problem for me.
  17. Nov 24, 2019 at 12:33 PM
    #677
    SAPR53
    2019 TRD Offroad
    well i'm at a loss, last night i connected one of my ditch lights to the switch pros and it worked like a charm. This morning i went to attach that same harness and the light won't power on. I connected both ditch lights straight to the battery and they both work. I opened the fuse box, and the fuses for the white, pink and blue wires are all intact and didnt see anythihg else damaged. The switch pros switch panel back lights, the headlight dimmer works. I'm at a complete loss...
  18. Nov 24, 2019 at 12:48 PM
    #678
    crashdb
    Dave
    Manassas, VA
    2008 Toyota Matrix
    Did you try it on another output from the Switch Pro?
  19. Nov 24, 2019 at 12:48 PM
    #679
    SAPR53
    2019 TRD Offroad
    Ya I tried the first 4 options
  20. Nov 24, 2019 at 12:50 PM
    #680
    crashdb
    Dave
    Manassas, VA
    2008 Toyota Matrix
    Hmmmm. 12v coming out of the outputs?
