Switch Pros 9100 install and BS thread
Discussion in '3rd Gen. Tacomas (2016-2023)' started by PNWTacoma, Feb 16, 2018.
  1. Sep 2, 2020 at 8:54 PM
    #1081
    Skydvrr
    Skydvrr IG: @kalopsianick
    Nick
    YMH
    Black '17 OR
    Pretty shoddy stuff
    Shellshock likes this.
  2. Sep 2, 2020 at 8:56 PM
    #1082
    AY_ARONTRD
    AY_ARONTRD Well-Known Member
    Aaron
    Murrieta ,CA
    2019 DCLB Cement OR 4x4
    Very busy section and don’t believe that’s the safest location for your switchpro. Responded to your PM. Let’s see if we can fix this :thumbsup:
    Shellshock and Adoan[QUOTED] like this.
  3. Sep 4, 2020 at 2:52 AM
    #1083
    JasonT87
    JasonT87 Well-Known Member
    Southern California
    '16 TRD Sport DCSB
    Total Chaos mid-travel front. JD Fab SUA rear.
    Soooo, I just installed an ARB twin with a Switch Pro (on a Rago tray) for a 3G taco. Didn't do a step by step but I will be putting together a Youtube video going over the install.
    BOMBS and Frsh2df like this.
  4. Sep 4, 2020 at 4:18 PM
    #1084
    sagexp
    sagexp Well-Known Member
    Back home, AZ
    2002 Tacoma DC 4X4 2017 Tacoma DC 4X4
    Yeah, that's just shitty work, even were one an amateur. Good example of why ya just need to find the time to teach yourself, and do it yourself. Buy some wire, loom, heat shrink, connectors, etc., etc., and take a day to practice. Then get it done.
    I'm a bit anal about such things, but I Hate....HATE seeing uncovered wire under the hood. Multi colored spaghetti, and not well protected against chafing. Not sure if you have a recourse if you didn't tell them how you wanted it, but I'd rip that mess out and start over. I'll bet ya $100 right now any connections they made were not soldered and heat shrunk. Which of course at some point down the line may result in corrosion, bad connections, and trying to track down lighting / equipment failures, blown fuses, etc. Plus it just looks bad.
    Solder, flux, cheapie solder gun, un-insulated connectors, heat shrink, and braided loom or plastic wire tubing, and zip ties don't cost a lot, protect your wire and connections, and will make it look like a pro did it. Or at least someone who cared.
    And honestly, if you're not good at it, even your first attempt likely won't look anywhere near that bad if you just do some of the above. Even if you don't solder, ditch the insulated connectors, go un-insulated and cover them with heat shrink. But make sure you get a good solid crimp on the connections.
    Adoan[QUOTED] and Shellshock like this.
  5. Sep 4, 2020 at 4:55 PM
    #1085
    JasonT87
    Southern California
    '16 TRD Sport DCSB
    I mean... it’s not 100% wrong. But not 100% right either. I just did this yesterday. If you need help, DM.
  6. Sep 5, 2020 at 9:26 PM
    #1086
    StOrMyThEtAcO
    StOrMyThEtAcO @stormythetaco
    Cody
    CO
    18 TRD Sport mom bus
    All of them
    Hey guys, have an issue with my 9100 unit. The other night I ran some of the lights. Shut them off got home locked the truck an then the fog lights turned on. Lost control of the switch pannel as in I can’t turn on any other lights at all an the fogs are not on full power they are very dim.
    Unplugged it all left it for a few days plugged it back in but its still messed up. Any ideas!?!
    next step is to contact switch pro but figured I would ask here
  7. Sep 6, 2020 at 8:41 AM
    #1087
    CBChief
    CBChief Chief
    Fredericksburg VA
    2018 Black Tacoma TRD SPORT DCSB
    The list has only just begun! Bob's mirrors Homelink mirror N2design Remote Starter Empyre OffRoad Door Sill Decals BDtrims Domed Tailgate Letters Thin Red Line Reflective(Custom made) KTJO 4x4 3rd Gen Plug-N-Play Tailgate Bolt-N-Lock & Tailgate Bolt-N-Open Switch Pro SP9100 Expedition Essentials Sunglass holder for the SP9100 PowerTray Vertical Mount with accessory bundle Anytime Backup Camera Front Camera Old Coots 1 inch Seat Spacers MESOCustoms COIN TRAY CaliraisedLED LOWER BUMPER HIDDEN LED LIGHT BAR BRACKETS LEDOutfitters 30 LED DUAL COLOR COMBO SPOT AND FLOOD LIGHT SINGLE ROW Auto Ventshade Low Profile Matte Black Ventvisor Side Window Deflectors Rogue River Tactical Subdued Thin Red Line Flag Trailer Hitch Cover Redline Tuning 21-27015-02 Hood QuickLIFT PLUS System Tacos4cheap Toyota Tacoma 3rd Gen Glove Box Inserts URPOWER Dog Seat Cover Car Seat Hammock Kavaca REGENERATING PAINT PROTECTION FILM Ceramic Pro Coating 20% Tint on all legal glass 303 Protectant Coated Tonneau cover The Last Coat TLC2/AMP Protected over CP OEM BedMat OEM Truck Bed Header Rail OEM Bed Cleats +4
    Here is my DIY install.
  8. Sep 6, 2020 at 9:01 AM
    #1088
    sagexp
    Back home, AZ
    Pull the main plug on the unit and see if there is water / corrosion in there.
    Check to make sure your ground for the controller and hot leads are making good contact, not corroded, and tight.
  9. Sep 6, 2020 at 11:32 AM
    #1089
    ponts
    ponts Well-Known Member
    Same thing happened to my 8100. Maybe water damage? Is it mounted on its side or facing up?
  10. Sep 7, 2020 at 8:06 AM
    #1090
    StOrMyThEtAcO
    Cody
    CO
    All of them
    It is on its back. It been that way for quite awhile an no issues an if I remember correctly it wasn’t wet outside the day we had issues.
    What was your fix when you had the issue?
  11. Sep 7, 2020 at 8:10 AM
    #1091
    Shellshock
    Iowa
    Pull the plug out and look for corrosion in the connector on the switch pro
  12. Sep 7, 2020 at 8:29 AM
    #1092
    SearArtist
    SearArtist GX poor
    NC
    GX470 & GX460
    Things
    It’s pretty simple if you look at the wiring diagram for the twin. The purple wire is the positive trigger and black is ground. Not sure why it is so complicated to figure out. I wouldn’t be going back to that shop if I were you.
    BOMBS likes this.
  13. Sep 7, 2020 at 8:32 AM
    #1093
    SearArtist
    SearArtist GX poor
    NC
    GX470 & GX460
    Things
    circling back to this - is there a place to tap the fog circuit that is closer to the fuse box?
    I already ran both my trigger wires in the fuse box and don’t want to take one of them out to run just a single wire to the middle of the crossmember :anonymous:
  14. Sep 7, 2020 at 8:35 AM
    #1094
    caribe makaira
    Caribbean, Puerto Rico
    Inside the engine relay/fuse box is the fog relay...ingenuity to tap the pins you need, or come from below the relay (inside the box), since you want to keep it in the engine area...
  15. Sep 7, 2020 at 8:46 AM
    #1095
    SearArtist
    SearArtist GX poor
    NC
    GX470 & GX460
    Things
    Thanks. I’ll see if I can figure out which pin on the relay is the one I need and see if I can figure out how to tap it from the top side of the fuse box.
  16. Sep 7, 2020 at 8:52 AM
    #1096
    caribe makaira
    What input of the fog relay do you need?
  17. Sep 7, 2020 at 8:55 AM
    #1097
    SearArtist
    SearArtist GX poor
    NC
    GX470 & GX460
    Things
    I’m embarrassed to say this, but electrical diagrams to me are like trying to read something that’s written in Chinese :anonymous:
    5 is the output wire to the fog lights?! If I think I’m looking at it correctly
    hrivera007 and BOMBS like this.
  18. Sep 7, 2020 at 9:00 AM
    #1098
    caribe makaira
    Yes
  19. Sep 7, 2020 at 9:00 AM
    #1099
    SearArtist
    SearArtist GX poor
    NC
    GX470 & GX460
    Things
    My fog lights are wired directly to my SP. when I turn the fogs on at the stalk I want them to work like factory using one of the triggers on the SP. my other trigger is tapped into the high beam fuse, and I have it currently programmed to trigger on my fogs, ditch lights, and light bar.
  20. Sep 7, 2020 at 10:50 AM
    #1100
    caribe makaira
    The vehicle stalk switch is a negative one.
    Are the fogs OEM or add-ons?
    If you notice in the drawing, there are to wires of same color going to the relay, these are (+) fused hot. The green (5) goes to the fog lamps. And the remaining one (beige) is a negative to close the coil inside the relay.
    What you have and what the vehicle has is not compatible "circuit-wise".
