Switch Pros 9100 install and BS thread
Discussion in '3rd Gen. Tacomas (2016-2023)' started by PNWTacoma, Feb 16, 2018.
  1. Dec 16, 2020 at 9:59 AM
    #1221
    cali_cement_tacoma
    cali_cement_tacoma Member
    2019 Cement Tacoma TRD OR 4WD
    How did you put the fuses into the tap a circuit? I understand that if they are put in backwards they are in series and could blow. I'm installing my SP now. Thanks!
  2. Dec 16, 2020 at 10:03 AM
    #1222
    Squirrel13
    Squirrel13 Well-Known Member
    2020 Black Tacoma TRD Offroad
    Cali_Cement - Due to the layout of the fuse box components I didnt have much choice in the Add A Fuse orientation. The OEM fuse goes in the bottom position the added circuit in the toip fuse. These are just triggers for the Switch Pros. I have them fused at 3A and thats overkill. Basically the Switch Pros sense voltage change on these circuits and performs operations in the controller. They dont draw much current.
  3. Dec 16, 2020 at 10:09 AM
    #1223
    cali_cement_tacoma
    Ok. I added a tap a circuit in the fuse box under the hood for the ignition, trigger and the white wire this morning. I just wanted to make sure that I don't have a fire. :)
  4. Dec 16, 2020 at 10:10 AM
    #1224
    Shellshock
    Iowa
    Mine hasn’t started on fire in the 2 years its been installed. You should be good
    Skydvrr and BOMBS like this.
  5. Dec 16, 2020 at 10:12 AM
    #1225
    cali_cement_tacoma
    Thanks! Also, another question, why is it necessary to have a blue sea fuse when the SP is solid state?
  6. Dec 16, 2020 at 10:12 AM
    #1226
    Shellshock
    Iowa
    It isnt. People usually put it in for other accessories needing constant power (like a fridge)
  7. Dec 16, 2020 at 10:16 AM
    #1227
    cali_cement_tacoma
    Oh ok. I have a lithium battery in the bed of the truck for my fridge. Thanks!
  8. Dec 17, 2020 at 8:09 AM
    #1228
    cali_cement_tacoma
    MJTH likes this.
  9. Dec 17, 2020 at 8:10 AM
    #1229
    cali_cement_tacoma
    Love the Deutsch Connector setup. I just installed my SP but wires are all over still. I tucked them under the side plastic panel. How did you mount the DTP connectors to the SDHQ mount? Did you have to fabricate something?
  10. Dec 17, 2020 at 9:23 AM
    #1230
    daveeasa
    daveeasa FBC Harness Solutions
    David
    PNW
    2016 Tacoma OR DCSB 6MT, 2005 RC 5MT PreRunner, 2002 Tundra SR5 RCLB 4x4
    Yeah, that is a nice setup with the deutsch connectors! High power and low power more clearly identified, fully waterproof. Good option for AT, might be hard to sandwich it in for MT though it might be possible with them separated a bit more.
  11. Dec 17, 2020 at 6:33 PM
    #1231
    cmt_taco28
    cmt_taco28 Well-Known Member
    Johnny
    2020 Cement Tacoma TRD Off Road
    Would anyone know by any chance where I can tap my trigger wire (pink) to the dome lights so I can trigger some outputs once it’s unlocked or walked by with the keys and the lights turn on? Or even the cargo light wire.
  12. Dec 17, 2020 at 6:37 PM
    #1232
    hoarder23
    hoarder23 Truck fell over
    Shay
    NJ
    15 Pyrite Mica DCSB Sport
    Scratches
    Look at the install instructions for the MESO puddle lights and see where they tap in
    Skydvrr likes this.
  13. Dec 17, 2020 at 6:41 PM
    #1233
    cmt_taco28
    Johnny
    I believe that’s all plug and play tho. That comes with a harness. I believe I tapped into the right wire but it’s not going off when I unlock the doors. The dome does but rn I have trigger to do the raptor lights and that’s not turning on. I tried setting it with my ditch lights as well and it’s not turning on
  14. Dec 17, 2020 at 6:51 PM
    #1234
    hoarder23
    Shay
    NJ
    Scratches
    The store page has the wiring diagram for the current setup, if you dig through the thread you might be able to find info on wiring the early version that wasn't plug and play
    https://mesocustoms.com/collections/exterior-lights/products/tacoma-puddle-switch-kit
    Skydvrr likes this.
  15. Dec 17, 2020 at 7:49 PM
    #1235
    s7726
    s7726 Well-Known Member
    2019 DCLB TRD OR Cement
    I got the dsim kit for the meso puddles. I'm planning on joining my pink wire to the yellow wire. I'm getting spoiled with all the plug and play. I can rewire things, I just don't want to.
  16. Dec 17, 2020 at 8:06 PM
    #1236
    Skydvrr
    Skydvrr IG: @kalopsianick
    Nick
    YMH
    Black '17 OR
    Custom stickers would be sweet.
    the dashing ham and Gunshot-6A like this.
  17. Dec 17, 2020 at 8:23 PM
    #1237
    cmt_taco28
    Johnny
    so it’s the yellow wire that the pink trigger wire from the switch pro should be tapped into?
  18. Dec 17, 2020 at 8:25 PM
    #1238
    s7726
    If you add the dsim kit to the puddle pod install, the yellow wire from the dsim is a positive trigger for the domes.
  19. Dec 17, 2020 at 8:32 PM
    #1239
    cmt_taco28
    Johnny
    im not doing any dsim kit. I’m trying to directly connect the pink trigger directly to a dome wire so once it unlocks, it triggers my raptor lights or whatever I set it to, to light up.
  20. Dec 18, 2020 at 8:30 AM
    #1240
    s7726
    My point is the dsim kit gets you a loose wire to connect to without tapping any factory wiring.
    I think there's another pnp harness in the market section that splits of the bed light switch.
