Switch Pros 9100 install and BS thread
Discussion in '3rd Gen. Tacomas (2016-2023)' started by PNWTacoma, Feb 16, 2018.
  1. Dec 18, 2020 at 8:32 AM
    #1241
    Gunshot-6A
    Gunshot-6A Prime Beef
    Conner
    Everett, WA
    '15 TRDOR / '17 Africa Twin
    I have a vinyl cutting setup, and have tried to make my own overlays. The tiny writing + dimensions is what makes it such a pain in the butt. Much easier with a laser cutter than a cheaper blade cutter.
    I can try and work something up for you though if you wanna give it a shot.
    the dashing ham likes this.
  2. Dec 18, 2020 at 5:01 PM
    #1242
    Mr.Pink Taco
    Mr.Pink Taco Well-Known Member
    Tim
    Jersey
    2020 TRD Pro Black
    Minor stuff.
    Question. I just got my Rigid chase lights. I am going to set them up tomorrow. I just want to make sure I got the wiring down right. I plan on putting the strobe on my SP and also use the trigger wire for the strobe for reverse so the strobes go off while I am in reverse. So for running light I tap the red into my running light wire. For brake light, tap the white into the brake wire. And the rest for the white reverse and cargo lights. For the strobe, I should run the yellow wire to the SP’. And then for the strobes to go off while in reverse, put the pink trigger wire onto a reverse fuse (using fuse taps) and then program it for that function? Do I have the theory correct or am I missing something? I attached the chase light wiring instructions. Thanks.
  3. Dec 18, 2020 at 7:41 PM
    #1243
    cmt_taco28
    cmt_taco28 Well-Known Member
    Johnny
    2020 Cement Tacoma TRD Off Road
    has anyone had a problem with their trigger setup not triggering what you set to turn on? for example the cargo lights?
  4. Dec 22, 2020 at 4:41 PM
    #1244
    mrCanoehead
    mrCanoehead Well-Known Member
    Ottawa
    2018 DCSB Sport manual 3.5 l
    Genius. That space is totally wasted in my truck, I just put car wash credit cards in there but it's otherwise useless. Now that you've been running it for a while, any issues with drinks spilling on it? Any issues with driver attention, finding buttons while moving?
    I'm also looking at the Meso overhead mount which might be slightly safer because you're not trying to find little buttons while looking downward, but I'm not sure it's really a big issue.
    What I find is that the steering wheel obscures the view of the area with the cubby where the SDHQ insert would put the switch panel. I'm not sure it's the best solution.
  5. Dec 26, 2020 at 5:45 PM
    #1245
    Mr.Pink Taco
    Tim
    Jersey
    2020 TRD Pro Black
    Minor stuff.
    I ran my trigger wires into the engine compartment fuse box today. I put my white wire into the low beam fuse and my switch pros did not dim when I turned my headlights on. I have a 5 amp and a 10 amp fuse in my fuse tap. I don't know what I am missing. I know the trigger wire works because I set up the white trigger wire to turn on my CB & Ham radio when I put my headlights on so I am going nuts trying to figure out why the switch panel won't dim..... Amy suggestions?
    Thanks.
  6. Dec 27, 2020 at 6:01 AM
    #1246
    mrCanoehead
    Ottawa
    Probably you already saw this in the manual, but I'll just post it anyway in case it might help you:
  7. Dec 27, 2020 at 7:45 AM
    #1247
    Mr.Pink Taco
    Tim
    Jersey
    2020 TRD Pro Black
    Minor stuff.
    Did that. But thanks.
  8. Dec 29, 2020 at 5:32 PM
    #1248
    daveeasa
    daveeasa FBC Harness Solutions
    David
    PNW
    2016 Tacoma OR DCSB 6MT, 2005 RC 5MT PreRunner, 2002 Tundra SR5 RCLB 4x4
    Got my wires through the firewall today, finally. My hands are nice and bloody now. Darn clutch pedal is right in the way.
    A09A6536-DF12-4F19-BE4F-59D77C341748.jpg 6E5A8D5E-0C54-440B-876C-F60F56A4693B.jpg
  9. Jan 6, 2021 at 8:44 PM
    #1249
    rageandlove
    rageandlove Member
    @SearArtist - I found this on another forum. This is instructions for an ARB single to Switch Pros.
    -Thick red with inline fuse direct to battery positive, thick black/white stripe and small black (that are taped to battery positive wire) direct to battery negative.
    -Three plug setups: use the one with the thick red/white stripe and black/white stripe to plug directly into the compressor (tape off the other two plugs these are for locker solenoids and not used)
    -small single red and small single blue wires with small plastic plugs go to your pressure switch which you are still using in the compressor (doesn't matter which way they are plugged in)
    -lastly the small red wire (in the bundle (of 4 small wires; red green yellow blue) goes to the switch pros while the other wires are taped off and not used.
  10. Jan 8, 2021 at 1:24 PM
    #1250
    aaronqn
    aaronqn Well-Known Member
    Bay Area, CA
    Any issues with hooking up a unit with less draw onto the 35a outlet? I am out of 20a outlets
  11. Jan 8, 2021 at 1:32 PM
    #1251
    SearArtist
    SearArtist GX poor
    NC
    GX470 & GX460
    Things
    Hmm, yeah I'm a visual learner, so I'm not really comprehending these instructions. I'll have to pull my harness out and take a look at it.
  12. Jan 8, 2021 at 1:41 PM
    #1252
    MJTH
    MJTH PretenderLander
    Joe
    Colorado-Westslopebestslope
    19 OR- Land Yacht, w/ fireplace
    I haven't had an issue. Running some 2amp lights off the #8 35amp.
    You can go into the settings on the app and you can change the overload amperage for that switch.
    Gunshot-6A likes this.
  13. Jan 8, 2021 at 2:55 PM
    #1253
    aaronqn
    Bay Area, CA
    Awesome thanks!
    HAVA likes this.
  14. Jan 10, 2021 at 9:42 AM
    #1254
    rageandlove
    rageandlove Member
    I spend a few hours taking apart the ARB harnass and cutting out the 75% not needed. Hopefully will finish the install next weekend. Will post some shots if helpful.
  15. Jan 10, 2021 at 10:00 AM
    #1255
    SearArtist
    SearArtist GX poor
    NC
    GX470 & GX460
    Things
    single or twin? Twin is easy cause it has built in relays. Just have to run the purple wire to the SP and ground the black wire.
    The single seems more complicated.
  16. Jan 10, 2021 at 10:05 AM
    #1256
    WaitingOnMyR1T
    WaitingOnMyR1T No longer waiting…
    Josh
    Portland, Oregon
    2020 White TRD Pro - Magnuson S/C & Rivian R1S
    This is all you need:
    https://store.switchpros.com/quick-connect-harness-for-arb-compressors/
    I’m sure you can make it yourself from the ARB harness, but jut to give you an idea of how little you need, 3 wires, for 2 lockers and a compressor. I assume the ground comes from the ground on the power harness.
  17. Jan 10, 2021 at 10:12 AM
    #1257
    SearArtist
    SearArtist GX poor
    NC
    GX470 & GX460
    Things
    you still have 15ft of unnecessary harness to hide as well. I don’t like having excessive harness wiring in my engine bay or under the dash. I’ll probably dissect the harness as well and shorten everything to my liking.
  18. Jan 10, 2021 at 10:29 AM
    #1258
    rageandlove
    rageandlove Member
    Single. It's definitely a bit more of a hassle.
    Exactly. Half of the wiring you don't need and the other half is way longer than you need.
    Here's what's left:
    (Note, much of that will get shortened when I install.)
    Here's what I cut out - plus a few other ground wires I trimmed off:
    ca08tacoma and Shellshock like this.
  19. Jan 11, 2021 at 12:58 PM
    #1259
    ISU800m
    ISU800m "Worst case Ontario"
    Kyle
    Plymouth, MA
    2018 Silver TRD OR
    So I am finally going with a switch pros to power a roof light bar, ditch lights with backlight, bumper light bar, and chase light bar. The only complex light is the chase light because of the multitude of features. Based on what I’m running, would I be better off with the SDHQ system, or go power trays with the blue sea stuff? I want to wire all these one last time and don’t mind spending the extra money with the blue sea stuff if it’s worth it.
  20. Jan 11, 2021 at 2:03 PM
    #1260
    daveeasa
    David
    PNW
    I was MT so my options were limited. I bought powertrays and had to resell since it was AT only. It was nice but pricey. I still have the blue sea fuse box unused but was able to put the bus bar and ground bar to work with a bracket @AY_ARONTRD makes which is MT compatible.
    The SDHQ bracket vs powertrays is an interesting question for those with AT. I don’t think I’m in a position to advise on that part.
