Switch Pros 9100 install and BS thread
Discussion in '3rd Gen. Tacomas (2016-2023)' started by PNWTacoma, Feb 16, 2018.
  1. Jun 18, 2021 at 2:58 PM
    #1381
    ClintS
    ClintS Well-Known Member
    San Diego
    2019 Tacoma TRD Off Road
    Try
    https://getoffroam.com/products/toy...YZ3BJAy9cwoC3smBCXFOo2KXdcQ_EnuBoCXWgQAvD_BwE
    or use the un-holey mount with RAM ball and your choice of phone holder.
    https://shop-hondogarage.com/products/un-holey-tacoma-dash-mount
    You will get a reflection in the drivers side window which was bothersome to me, especially at night.
  2. Jun 18, 2021 at 3:39 PM
    #1382
    daveeasa
    daveeasa FBC Harness Solutions
    David
    PNW
    2016 Tacoma OR DCSB 6MT, 2005 RC 5MT PreRunner, 2002 Tundra SR5 RCLB 4x4
    The fog intercept is easily accessible with the hood open. Top of the bumper. The connectors are easy to get too.
  3. Jun 19, 2021 at 11:16 AM
    #1383
    S2KON2
    S2KON2 Well-Known Member
    So Cal (SFV)
    I tried tapping into both, at different times, and couldn't get it to work. Ended up blowing fuses.
  4. Jun 19, 2021 at 11:22 AM
    #1384
    daveeasa
    David
    PNW
    did you try:
    1. disconnect fog intercept
    2. Cap off input w male connector and seals
    3. Connect female connector to output and wire to Switch-Pros circuit.
    they are just lights. You shouldn’t be doing anything with the OEM circuit.
    Or was your plan to have fog anytime w Switch-Pros and keep the stalk fog light switch as well? If so then you need a relay and some diodes from each input.
    S2KON2[QUOTED] likes this.
  5. Jun 20, 2021 at 8:22 PM
    #1385
    thrust
    thrust Member
    2017 MGM DCSB TRD OR
    Two questions boys:
    1. I have one of my external triggers on the high beam fuse for my light bar (switch 1.) Any way I could have switch 1 "toggle" whether or not I want the light bar to come on with the high beams? I like the option for it to do that but don't ALWAYS want it on with the high beams.
    2. I have switch 4 wired to a phone charger. A phone charger? yes. i don't have many things right now :( So I have switch 4 set to battery so that i can turn the phone charger on when the truck is off. I also have it set to come on when the truck starts. Only problem is it doesn't go off when the truck turns off. Anyway I can change that?
  6. Jun 20, 2021 at 9:20 PM
    #1386
    ShimStack
    ShimStack Well-Known Member
    Ben
    NC
    '91 Truggy, '98 Project, '16 DC OR M/T Locked F/R
    1. Hold down programming button and press switch 7. This toggles the trigger 1 function on and off. Three flashes it's active and one flash it's not.
    2. Look at the off delay setting for the switch. Switches that are auto on with the ignition can have an off delay time after the the ignition is switched off.
  7. Jun 21, 2021 at 10:58 AM
    #1387
    thrust
    thrust Member
    Beautiful. Thank you!
    ShimStack[QUOTED] likes this.
  8. Jun 21, 2021 at 2:38 PM
    #1388
    Gdennee315
    Gdennee315 Well-Known Member
    2017 MGM TRD OR 4X4
    do you re add the inline 40amp fuse between the relay and the batter
  9. Jun 24, 2021 at 4:11 PM
    #1389
    Gdennee315
    2017 MGM TRD OR 4X4
    Has anyone ran their ARB single compressor to the blue sea and Gotten rid of the inline fuse
  10. Jun 24, 2021 at 4:17 PM
    #1390
    vorkuta775
    vorkuta775 Well-Known Member
    Texas
    tesla truck
    I did the exact same thing a few months back. Mine just has one extra usb outlet.
    Frsh2df[QUOTED] likes this.
  11. Jun 24, 2021 at 5:48 PM
    #1391
    BOMBS
    BOMBS Well-Known Member
    2017 Black Tacoma TRD Off Road
    Man....you should do a write up on how to you did the install on that. Looks super clean, like pro level.
    shiftd and Frsh2df[QUOTED] like this.
  12. Jun 24, 2021 at 6:10 PM
    #1392
    TheTacoAdventurer
    TheTacoAdventurer Well-Known Member
    Boston, MA
    2018 DCSB TRD OR
    Forever modding!
    Shoot I have the exact same thing and I remember there being a write up somewhere. Bit it was basically measure like 15 times and then brace as you cut into your truck bed with a Dremel
    BOMBS[QUOTED] and Frsh2df like this.
  13. Jun 24, 2021 at 7:13 PM
    #1393
    Frsh2df
    Frsh2df Well-Known Member
    2017 MGM TRD Off Road 4x4
    Thanks i appreciate it. There was a thread on here I followed. I really should have done my own write up on it though.
    When you remove the cubby, if you reach up you will feel braces / ribs on the inside of the bed. You just have to lay it out in order to miss them with all the holes you have to drill out. Makes it a much easier install if the holes you drill out don’t go through those ribs.
    Kinda hard to explain but once you reach up there you will know what I’m talking about.
    Hope this helps if you ever decide to install one.
    BOMBS[QUOTED] likes this.
  14. Jun 24, 2021 at 7:15 PM
    #1394
    Frsh2df
    Yeah there is definitely a write up on here somewhere that I followed. I ended up using a hole saw to drill out the holes. Was a little nerve racking at first , but once the first one was drilled out it was all downhill after that. :rofl:
    BOMBS likes this.
  15. Jun 25, 2021 at 6:38 AM
    #1395
    TheTacoAdventurer
    Boston, MA
    2018 DCSB TRD OR
    Forever modding!
    Here's where I got mine: https://bit.ly/2T9iG5U (sorry for the short url. TW doesnt like their actual URL. Idk why) I tried finding some install directions for this kit but no luck. I really was just cut a hole where you want and then run the wire under the truck to the engine bay
    Frsh2df and BOMBS[QUOTED] like this.
  16. Jun 25, 2021 at 8:04 AM
    #1396
    BOMBS
    Hey guys...thanks for the info. I appreciate the link to the hardware as well. At the moment I still have some unused switches at the moment, but I know this mod will most likely be added to the "to do list."
  17. Jun 29, 2021 at 9:49 PM
    #1397
    shiftd
    shiftd Well-Known Member
    Pennsylvania, USA
    2020 Tacoma TRD Pro
    Hi all,
    Picked up a switch pros (with power trays and blue sea fuse setup) and planning to install soon. I've also picked up a dual battery setup (off grid engineering split system with redarc controller) that I'll be installing next weekend.
    I plan to extend the cable that came with the switch pros and run it to the aux battery positive.
    I'm curious about the positive off the blue sea and the negative off the bus bar. Should they both also be run to the aux battery?
    My initial thought is yes, at least the positive off the fuse block, but not 100% sure after seeing some pics in this thread and others. Looking for knowledge.
    TheTacoAdventurer likes this.
  18. Jun 30, 2021 at 3:58 AM
    #1398
    Skydvrr
    Skydvrr IG: @kalopsianick
    Nick
    YMH
    Black '17 OR
    I can't help you with the blue seas extension. But the power wire from the switch pro can be disassembled, so you can retain the SP fuse and just add a longer length cable.
    shiftd[QUOTED] likes this.
  19. Jun 30, 2021 at 4:13 AM
    #1399
    shiftd
    Pennsylvania, USA
    2020 Tacoma TRD Pro
    Thanks, that is my plan. I picked up a 4 foot length of 4 AWG and will add it to one side of the existing switch pro power cable to retain the inline fuse.
    Tatoryota likes this.
  20. Jun 30, 2021 at 4:22 AM
    #1400
    Skydvrr
    Nick
    YMH
    Black '17 OR
    Nice, same exact thing I did.
