Switch Pros 9100 install and BS thread
Discussion in '3rd Gen. Tacomas (2016-2023)' started by PNWTacoma, Feb 16, 2018.
  1. Aug 19, 2021 at 4:34 PM
    #1441
    907rx7
    907rx7 Well-Known Member
    James
    '20 Tacoma DCSB SR 4x4
    Good to know, I checked in the little engine bay fuse box and the empty slot for inverter is pinned as well. I wonder how plug and play it would be if I can get one for cheap.
  2. Aug 19, 2021 at 6:55 PM
    #1442
    Shellshock
    Iowa
    SDHQ
    daveeasa likes this.
  3. Aug 20, 2021 at 10:22 AM
    #1443
    baileybrandon
    baileybrandon 2016 DCSB OR - MGM -
    Bailey
    Tennessee
    2016 Tacoma TRD Off Road Double Cab
    Looking for some help / advice.
    Just installed some BD S2 lights on my prinsu / topper rack.
    How would you all go about wiring this to a switch pro under the hood?
  4. Aug 20, 2021 at 10:30 AM
    #1444
    907rx7
    James
    Those have three wires correct? Positive main light, negative, and positive backlight?
    baileybrandon[QUOTED] likes this.
  5. Aug 20, 2021 at 10:34 AM
    #1445
    baileybrandon
    Bailey
    Tennessee
    correct - the harness has a white, blue and black wire
  6. Aug 20, 2021 at 10:56 AM
    #1446
    WaitingOnMyR1T
    WaitingOnMyR1T No longer waiting…
    Josh
    Portland, Oregon
    2020 White TRD Pro - Magnuson S/C & Rivian R1S
    My S2 Pros have two wires (there is no backlight).
    baileybrandon likes this.
  7. Aug 20, 2021 at 11:04 AM
    #1447
    daveeasa
    daveeasa FBC Harness Solutions
    David
    PNW
    2016 Tacoma OR DCSB 6MT, 2005 RC 5MT PreRunner, 2002 Tundra SR5 RCLB 4x4
    If you want a DRL T tap (with or without relay) I can probably hook you up. I assume you'd burn two circuits off the switchpros otherwise which would be a bit annoying? Bummer on the DRL T tap is I don't see an easy way to avoid another feed from the battery? I can probably fit everything into a single GEP though so it could be more compact with just one fuse and one relay, DRL T and output to the 3rd wire to mate up with the switch-pros circuit for the main lights.
  8. Aug 20, 2021 at 12:23 PM
    #1448
    907rx7
    James
    Sorry I was thinking these were Diode Dynamics. Bailey, a pic of the wires on the back of the light would be helpful. Perhaps you were looking at the switch side of the wiring harness instead?
  9. Aug 20, 2021 at 12:50 PM
    #1449
    baileybrandon
    Bailey
    Tennessee
    yup- that's my bad and pardon my ignorance but learning as I go. The pods themselves have two wires:
    1 black
    1 white
    Pic:
  10. Aug 20, 2021 at 12:54 PM
    #1450
    daveeasa
    David
    PNW
    So no thinking then, black to ground, white to your switchpros +, done and done.
    907rx7 and baileybrandon like this.
  11. Aug 20, 2021 at 12:57 PM
    #1451
    baileybrandon
    Bailey
    Tennessee
    Got it! Wondering what's the best "route" to take given I gave to run the wiring the length of the truck.
    1 option would be along the rack itself, into the molding down the left side of the windsheild
    2 would be to run between the cab and the bed under the truck up into the engine bay?
    open to ideas and suggestions
  12. Aug 20, 2021 at 12:59 PM
    #1452
    907rx7
    James
    Option 2 for sure, once below the truck you can run along the frame.
  13. Aug 20, 2021 at 1:06 PM
    #1453
    baileybrandon
    Bailey
    Tennessee
    10-4
  14. Aug 20, 2021 at 3:34 PM
    #1454
    907rx7
    James
    Well, all finished for now. Next project will be making 2-pin DTP flanged connectors since they don't seem to exist.
    Found this tiny gap to run the trigger wires into the fuse box after removing the ground wire and the piece next to it.
    Red wire through tiny gap for demonstration purposes.
  15. Aug 20, 2021 at 3:45 PM
    #1455
    daveeasa
    David
    PNW
    Looks really nice. What is your trigger?
  16. Aug 20, 2021 at 3:54 PM
    #1456
    907rx7
    James
    Currently light blue to AC(need to find something else as this means the fan has to be on for switch pros to power up).
    White to low beams, pink to high beams.
  17. Aug 20, 2021 at 3:57 PM
    #1457
    daveeasa
    David
    PNW
    @Puppypunter since @907rx7 already has his grubby wires in the fuse box, think you could hook him up with a T tap for ignition? In the meantime, James, I think sometimes we go INJ for simulated ignition? Did you consider that and pick AC for a reason?
    I could 100% give you a T tap for high and low beam triggers off the driver headlight if you wanted? Maybe you prefer add-a-fuse though? I got all cranky about extra wires in the box but what's done is done right?
    Personally I'd pull the white off the sidemarker connector since it's so easy to steal, instead of the low beams, but I think most of the time we go past parking lights to low beams on with the stalk?
  18. Aug 20, 2021 at 4:08 PM
    #1458
    907rx7
    James
    No specific reason for the current setup actually, just mimicking a layout I saw some else use. I have the headlight extensions in place so I could tap into those. I just got excited when I found a way into the fuse box without modifying it :rolleyes:
  19. Aug 20, 2021 at 4:12 PM
    #1459
    daveeasa
    David
    PNW
    Yeah, around here in SD we are all experts in tunneling into places we don't belong :)
    907rx7[QUOTED] likes this.
  20. Aug 20, 2021 at 5:04 PM
    #1460
    Shellshock
    Iowa
    I just did add a fuse for all 3 wires. Was super easy
    BOMBS and 907rx7 like this.
