Switch Pros 9100 install and BS thread
Discussion in '3rd Gen. Tacomas (2016-2023)' started by PNWTacoma, Feb 16, 2018.
  1. Feb 14, 2022 at 9:40 PM
    #1601
    BOMBS
    BOMBS Well-Known Member
    2017 Black Tacoma TRD Off Road
  2. Feb 15, 2022 at 3:45 PM
    #1602
    andersen24
    andersen24 Well-Known Member
    Andy
    Pismo Beach, CA
    2021 Tacoma SR DCSB V6 4X4
    Just make sure you order the right one…..2016-2019 or 2020+
    BOMBS[QUOTED] likes this.
  3. Feb 15, 2022 at 4:58 PM
    #1603
    soysauce021
    soysauce021 Well-Known Member
    Bay Area, CA
    2021 DCLB Sport
    I'm pretty sure these are made by MESO unless something changed recently.
    andersen24[QUOTED] likes this.
  4. Feb 15, 2022 at 5:02 PM
    #1604
    WaitingOnMyR1T
    WaitingOnMyR1T No longer waiting…
    Josh
    Portland, Oregon
    2020 White TRD Pro - Magnuson S/C & Rivian R1S
    MESO made mine
    soysauce021[QUOTED] likes this.
  5. Feb 15, 2022 at 6:45 PM
    #1605
    BOMBS
    I did see there are 2 different version for the model year.
    I have one that is made by MESO, but I do want to upgrade to the one with the extra slot next to the Switch Pro location.
  6. Feb 16, 2022 at 6:23 AM
    #1606
    aturk
    aturk Well-Known Member
    Tony
    Charlotte, NC
    Doing my SwitchPro install this week finally, but a question for those that have their Switch Pro's controlling backlighting. I have 3 sets of lights that have backlighting options, none are wired up yet.
    Light Bar (BD S8)
    Fogs (DD SS3 Max)
    Ditch Lights (DD SS3 Max)
    My first thought was to wire all the backlighting together as it's a super low amp draw, and then just wire to one switch of the switch pro. Have it trigger on Ign and turn off when low beams or high beams are activated.
  7. Feb 16, 2022 at 7:12 AM
    #1607
    BOMBS
    I am curious about this idea as well. I have one set of lights that has the backlighting, but I have it on a dedicated single wiring harness to a 3 position switch which gives me full control of the main light and backlight.
    Diode Dynamics SSC1
  8. Feb 16, 2022 at 7:21 AM
    #1608
    Shellshock
    Iowa
    Thats what i would do
    BOMBS likes this.
  9. Feb 16, 2022 at 7:23 AM
    #1609
    aturk
    Tony
    Charlotte, NC
    Thanks for being a wiring guru and confirming sir!
    GuildOutfitters likes this.
  10. Feb 16, 2022 at 7:32 AM
    #1610
    BOMBS
    Would that mean, for the backlighting it would use one of the button on the Switch Pro panel and for the main light it would use another button?
  11. Feb 16, 2022 at 7:33 AM
    #1611
    aturk
    Tony
    Charlotte, NC
    Yes that is correct.
  12. Feb 16, 2022 at 7:33 AM
    #1612
    Shellshock
    Iowa
    Yeah. Basically one button controls all the backlights. Then theres a button for each individual light
    The other thing people do is wire the light and backlight together so they are controlled together.
    Just depends what you want.
  13. Feb 16, 2022 at 8:10 AM
    #1613
    BOMBS
    If the main light and backlight are wired together and are assigned to one button on Switch Pro, how do you set the main light and backlight function apart from each other?
  14. Feb 16, 2022 at 8:15 AM
    #1614
    Shellshock
    Iowa
    You don’t on the 9100 lol
    on the 12 panel switch pro you can have one button control multiple outputs. So like one press would be backlight and second press would be the light.
  15. Feb 16, 2022 at 8:17 AM
    #1615
    daveeasa
    daveeasa FBC Harness Solutions
    David
    PNW
    2016 Tacoma OR DCSB 6MT, 2005 RC 5MT PreRunner, 2002 Tundra SR5 RCLB 4x4
    If only the 12 button switch-pro were a bit easier to fit in places. It's so big.
    Gunshot-6A likes this.
  16. Feb 16, 2022 at 8:27 AM
    #1616
    BOMBS
    Now...that would be dope. Damn!...they should program the 9100 to function like the 12 panel Switch Pro.
  17. Feb 16, 2022 at 10:41 AM
    #1617
    panicmonster
    panicmonster no
    Anchorage, AK
    2021 Mallcrawler Pro
    Yes, as others above have said. This is what I do for the backlights on my S8 30". The switchpro button memory is on, with ignition rather than always on power. I use the backlights like pseudo-running lights, but with the option to turn them off via switchpro switch. The main lights are on a separate switch. I don't have the backlights on other LEDs wired (intentionally), but could repeat this process for them separately, or combine all the backlights into one switch. The current draw for these backlights is so minimal, you could use one of the low amp switches for everything.
    Downside is that it takes up 2 of the 8 switch spots for one backlight/main combo. I don't have that much stuff wired up so not an issue (yet?).
    One day I might do what this guy did for his raptor lights and make it an automatic low beam +/- DRL triggered switch. I would just make it relayed and fused in addition to how he describes it.
  18. Feb 16, 2022 at 11:06 AM
    #1618
    BOMBS
    I understand your method and it's cool. I prefer to use one button per accessory. We are alike, I have some things wired up and still have room to wire some more accessories.
    panicmonster[QUOTED] likes this.
  19. Feb 16, 2022 at 12:00 PM
    #1619
    daveeasa
    David
    PNW
    I truly wish the 9100 had 4-5 trigger inputs. I'd want high beam, fog light, drl + park combo, dome and reverse. Cargo wouldn't be terrible as well. I have some small hope of an upgraded version in the future with the same form factor.
  20. Feb 16, 2022 at 5:09 PM
    #1620
    GuildOutfitters
    GuildOutfitters Well-Known Member
    Shaun
    Columbus, OH
    2021 TRD Pro Custom
    Custom switch panels, wire harnesses, roof rack, light bar, ditch lights, rock lights, and every week more.
    Think anyone would be interested in us making a custom 12 button switch pro left panel? I’ve drafted up one but it requires pulling the lower row that’s recessed forward.
    Jematti and BOMBS like this.
