Switch Pros 9100 install and BS thread
Discussion in '3rd Gen. Tacomas (2016-2023)' started by PNWTacoma, Feb 16, 2018.
  1. Mar 17, 2022 at 1:31 PM
    #1641
    aturk
    aturk Well-Known Member
    Tony
    Charlotte, NC
    Can I bother you for a picture of that drivers side tuck?
  2. Mar 17, 2022 at 1:50 PM
    #1642
    Shellshock
    Iowa
    I’ve cleaned some stuff up since this pic but you get the idea
    aturk[QUOTED] likes this.
  3. Mar 18, 2022 at 4:07 PM
    #1643
    Absolut_Boost
    Absolut_Boost Well-Known Member
    Cincinnati, OH
    2021 Tacoma TRD OR DCSB Cement
    Finally got my powertrays mount this week that was on back order for the longest time. Got it installed today and cleaned up the wiring. Only a hidden bumper light bar and ditch lights wired up so far, but there will eventually be rear facing scene lights, a roof rack light bar and possibly some aux reverse lights yet to come. Dave’s headlight harness is where I tapped the high beam signal for trigger 1 and the parking light signal for backlight dimming. Ignition wire is run to the 10A inj fuse with a fuse tap. Everything is in loom and heat shrink to keep the install as clean as possible. I’m trying to decide if I should leave the controller harness coiled, or cut the length back so it is a better fit. I’m thinking I’ll leave it coiled so I don’t mess with the factory sheathing. (Not sure why the first picture is sideways, it’s upright on my phone.)
    8D6D28F5-CA2B-45E4-9A86-0B1525C95B15.jpg 5203A16C-FBAF-4640-A73E-0B515626AB87.jpg
  4. Mar 18, 2022 at 6:37 PM
    #1644
    Menjivar54
    Menjivar54 Well-Known Member
    2020 TRD PRO
    Hey man! Who makes that tray? I have a M/T too. Thanks!
  5. Mar 18, 2022 at 6:39 PM
    #1645
    Kronk21
    Kronk21 IG @uniquely_Us_adventures
    Monte1
    2021.DBLCB.LB.GRN
    King 2.5 with reservoirs, CBI sliders, RCI skids, Leer camper shell, Methods, K02, switch-pro
    Those battery terminals from taco garage?
  6. Mar 21, 2022 at 8:57 AM
    #1646
    aturk
    Tony
    Charlotte, NC
    I've finished re-wiring all my lights into Switch Pro.
    I have 3 lights that have amber backlighting, and I want to put them to one switch on the switch pros.
    Does anyone know of a 3 to 1 connector or similar I could use to connect them cleanly? I know I can cut and solder/heatshrink them all, but that's a pretty big joint. I really should have just used another bus bar but didn't think ahead enough.
  7. Mar 21, 2022 at 8:48 PM
    #1647
    Absolut_Boost
    Cincinnati, OH
    for 3 into 1, I will usually put 2 wires into one side of a butt connector, the 3rd into the other side with the single wire out to the switch-pros. this helps with keeping the crimps even/secure on a butt connector. with good 3:1 double wall adhesive heat shrink on top of that, it should be a lot more weather sealed than a buss bar would be.
    aturk[QUOTED] and utbytn like this.
  8. Mar 21, 2022 at 9:07 PM
    #1648
    aturk
    Tony
    Charlotte, NC
    Great idea, didn’t even cross my mind! Ty
  9. Mar 22, 2022 at 4:45 AM
    #1649
    mquibble
    mquibble Well-Known Member
    Michael
    2021 TacomaTRD Pro
    Is this what you are describing? Not trying to steal your thunder, just trying to visualize before I make a mistake for misunderstanding.0DB2EC36-A5B8-4AC4-8DB7-7239DE822005.jpg
    Absolut_Boost[QUOTED] likes this.
  10. Mar 22, 2022 at 9:39 AM
    #1650
    Waxifari
    Waxifari Well-Known Member
    Denver/Boulder Metro
    2021 Pro
    Morning TW. I searched this thread but couldn't find - so apologize if this is redundant (likely so).
    I have a SwithPro 9100 installed. I am simply looking for the best/easiest trigger source to trigger my roof rack BD Rock Lights with interior/dome lighting. The rock lights run off the 9100, standard on/off push button config ATM. Is there a good T Tap or Add-A-Fuse source on the engine side of the firewall where the pink wire/9100 already are? Or do I need to pull the pink wire through the firewall and add-a-fuse off the dome circuit on the secondary cabin fuse panel? Or something else entirely?
    Thanks in advance.
  11. Mar 22, 2022 at 9:53 AM
    #1651
    Supr4Lo
    Supr4Lo Well-Known Member
    Surprise, AZ
    2020 DCSB Offroad MT, Supercharged, NWF Eco-Crawler, 4.88's Locked F&R on 37's
    I think you are going to need to use something like the DSIM module as the dome lights are a negative trigger. See here https://dsimsolutions.com/products/domerock-v4 Then you'd hook the 9100 trigger to the DSIM.
    But maybe someone else has a better way.
  12. Mar 22, 2022 at 9:55 AM
    #1652
    panicmonster
    panicmonster no
    Anchorage, AK
    2021 Mallcrawler Pro
    I use Metri-Pack 280 connectors.
  13. Mar 27, 2022 at 2:52 PM
    #1653
    Kronk21
    Monte1
    2021.DBLCB.LB.GRN
    Ordered mine today.. super excited!
    Shellshock likes this.
  14. Mar 27, 2022 at 11:58 PM
    #1654
    Absolut_Boost
    Cincinnati, OH
    Sorry for the delayed reply, but yes. That is exactly what I meant.
    mquibble[QUOTED] likes this.
  15. Mar 29, 2022 at 1:38 PM
    #1655
    TRD.Meza
    TRD.Meza Well-Known Member
    Jose
    SoCal - Hi Desert
    2019 Super White 4x4 Tacoma
    Stage 1 Eibach , Dirt King UCA & Sibi Tune
    Has anyone mounted the switch panel on the head liner?
  16. Mar 29, 2022 at 1:49 PM
    #1656
    daveeasa
    daveeasa FBC Harness Solutions
    David
    PNW
    2016 Tacoma OR DCSB 6MT, 2005 RC 5MT PreRunner, 2002 Tundra SR5 RCLB 4x4
    Yes, @Shellshock (see his build thread for photos). Looks nice too.
  17. Mar 29, 2022 at 1:59 PM
    #1657
    TRD.Meza
    Jose
    SoCal - Hi Desert
    Thank you but I am looking to install the switch panel like this.
  18. Mar 29, 2022 at 3:04 PM
    #1658
    907rx7
    907rx7 Well-Known Member
    James
    '20 Tacoma DCSB SR 4x4
    That's the same spot, he just has a sunroof so the headliner is shaped a bit different
    Gunshot-6A and Shellshock like this.
  19. Mar 29, 2022 at 3:34 PM
    #1659
    TacoTruckCO
    TacoTruckCO Well-Known Member
    Joel
    Portland, OR
    Voodoo Blue 20 OR DCLB
    I did this for my Tacoma. Made some little brackets that slip over the headliner at the sun roof. Need to make new ones a bit longer though.
    on my previous f150 I just put holes in the headliner and used the mounting hardware.
    ca08tacoma and Gunshot-6A like this.
  20. Mar 29, 2022 at 3:44 PM
    #1660
    TRD.Meza
    Jose
    SoCal - Hi Desert
    I see now , thank you.
