Switch Pros 9100 install and BS thread
Discussion in '3rd Gen. Tacomas (2016-2023)' started by PNWTacoma, Feb 16, 2018.
  1. Oct 19, 2022 at 6:42 AM
    #1781
    daveeasa
    daveeasa FBC Harness Solutions
    David
    PNW
    2016 Tacoma OR DCSB 6MT, 2005 RC 5MT PreRunner, 2002 Tundra SR5 RCLB 4x4
    The reason that the 9100 has two wires instead of 1 is due to current limitations of the terminal. By using two positions in the connector it can provide double the current capacity of a single terminal. Those two wires are meant/designed to be combined when feeding the output circuit.
    Shellshock likes this.
  2. Oct 19, 2022 at 7:25 AM
    #1782
    Blackdawg
    Blackdawg Dr. Frankenstein
    Monte
    Wyoming/St. Louis
    The Trifecta of Taco's
    This describes my issue. Which started a long time ago. Just sent mine in. Guessing it was a bad batch.
  3. Oct 19, 2022 at 4:46 PM
    #1783
    Absolut_Boost
    Absolut_Boost Well-Known Member
    Cincinnati, OH
    2021 Tacoma TRD OR DCSB Cement
    Even if you don't hook it up, the other wire will still be getting power when that switch is on. I know you can effectively cap a live wire, but my brain still says that having it connected properly is the safer option.
    Kronk21[QUOTED] likes this.
  4. Oct 19, 2022 at 7:23 PM
    #1784
    ShimStack
    ShimStack Well-Known Member
    Ben
    NC
    '91 Truggy, '98 Project, '16 DC OR M/T Locked F/R
    They're both already common so connecting it achieves nothing if the current can be safely carried by one wire.
  5. Oct 20, 2022 at 12:39 AM
    #1785
    Absolut_Boost
    Cincinnati, OH
    I realize that it may not be necessary to carry the current. I just don't like having wires with live voltage that are only capped and not part of a circuit. There is zero advantage to doing that, so why risk having a live wire that just ends in space when its just as easy to keep it part of the circuit? It takes zero extra time to solder or butt splice the extra wire in at the same time. Admittedly I'm weird about that stuff though. I have liquid electrical tape on my bus bar terminals to make sure they stay insulated.
  6. Oct 20, 2022 at 7:01 AM
    #1786
    ShimStack
    Ben
    NC
    Don't have to attach a wire to that 2nd terminal in the first place if it's just redundant.
  7. Oct 20, 2022 at 12:31 PM
    #1787
    TACOMA2NDGEN
    TACOMA2NDGEN Well-Known Member
    ROLAND
    new jersey
    2010 dcsb silver sport trd
    baja squadron pros
    Just got mine back from switchpro new serial number so different module. Plugged it right in and everything seems to be working great. No explanation on what was wrong. Either way great company to just replace the unit
    ttaaooaa likes this.
  8. Oct 20, 2022 at 1:41 PM
    #1788
    Blackdawg
    Monte
    Wyoming/St. Louis
    I got shipping from them today. Will see but would expect a new one probably considering how fast they turned it around.
  9. Oct 20, 2022 at 1:46 PM
    #1789
    disel_V1
    disel_V1 I eat cold pizza rolls
    3rd Gen
    few things here and there.
    Question for y’all.
    I have “burst strobe”, or whatever it’s called, enabled for a few of my lights.. but it doesn’t seem to work. Any ideas as to what I’m doing wrong? It will flash on and off (slowly) but the strobe could be beneficial. Thoughts?
  10. Oct 20, 2022 at 3:56 PM
    #1790
    Blackdawg
    Monte
    Wyoming/St. Louis
    Do you have double trigger enabled for strobe? As in you have to press the button twice in under 1 second. That's how I have mine setup.
    disel_V1[QUOTED] likes this.
  11. Oct 20, 2022 at 4:49 PM
    #1791
    disel_V1
    3rd Gen
    Im going to be real honest when I tell you I’m unsure. I just know I clicked the options strobe for the light I’d like it to be.
  12. Oct 20, 2022 at 5:19 PM
    #1792
    Blackdawg
    Monte
    Wyoming/St. Louis
    I don't have mine back from service yet so I can't remember the exact setting or where it is. Will look at the manual to point you there in a bit.
  13. Oct 20, 2022 at 8:12 PM
    #1793
    ktbell444
    ktbell444 One who throws exceptions
    ᚺᛖᛚᚺᛖᛁᛗ
    Here's the PDF instructions
  14. Oct 25, 2022 at 10:28 PM
    #1794
    Blackdawg
    Monte
    Wyoming/St. Louis
    TACOMA2NDGEN likes this.
  15. Oct 30, 2022 at 12:19 PM
    #1795
    Blackdawg
    Monte
    Wyoming/St. Louis
    Got my new unit in. Works perfect. And they even loaded my originals settings on there near exactly. So didn't have to reconfigure too much.
    907rx7 likes this.
  16. Nov 11, 2022 at 7:44 AM
    #1796
    BOMBS
    BOMBS Well-Known Member
    2017 Black Tacoma TRD Off Road
    Can you provide additional information on your set up with the circuit breakers or a diagram of some sort?
    Inquiring on the what wires are connected to the circuit breakers.
  17. Nov 13, 2022 at 5:13 PM
    #1797
    Absolut_Boost
    Cincinnati, OH
    I don't know the specifics to that setup for certain, but I'm pretty sure those CBs are fed directly from the two wires coming off the block at the battery positive terminal. One CB would feed the switchpros module on the right, and the other CB would feed the blue sea fused distribution block just to the left of the switchpros module.
    BOMBS[QUOTED] likes this.
  18. Nov 20, 2022 at 2:13 PM
    #1798
    Sixtwentythree
    Sixtwentythree Active Member
    AJ
    Tacoma
    2021 Tacoma O/R
    Can anyone help me find the high beam wire to connect the pink trigger wire to? My SP pink and white wire are already sheathed together, so I'd prefer to tap into the headlight itself rather than the fuse box. I have the non-LED headlight harness for the 3rd gens.
  19. Nov 20, 2022 at 5:13 PM
    #1799
    daveeasa
    David
    PNW
    Not sure if I have an explicit sku for that and I’m rather behind but it is in my wheelhouse.
  20. Nov 21, 2022 at 1:17 PM
    #1800
    Sixtwentythree
    AJ
    Tacoma
    2021 Tacoma O/R
    I think(?) this is my high beam. Do you know which wire I would tap into to connect the pink trigger wire?
