Switch-Pros SP8100 Switch Panel Information & Discussion
Discussion in '2nd Gen. Tacomas (2005-2015)' started by ACEkraut, Jun 30, 2016.
  1. Feb 15, 2018 at 8:24 AM
    #241
    TACOVRD
    TACOVRD I Identify As A Prius
    TW Addict
    AZ/WA
    2019 T4R ORP - Formerly 2013 DCSB OR Spruce Mica
    Workin' on it....
    But I gather you can’t have on/off/on function? ie. 2 separate on modes — one where only say the DRL is on or off and one where the main set of offroad LED’s is on or off?
  2. Feb 15, 2018 at 8:32 AM
    #242
    My Truck
    My Truck Well-Known Member
    Bay Area, CA
    2016 SR DCSB 4x4 Super White`
    To be honest, it would come down to the wiring of the light, and whether it enables that option. In order to do that, you would have to run the wire for the DRL function on the light to one switch, and the main light output wires to a different switch. Both would have the option of being flash/strobe, depending on your programming.
    TACOVRD[QUOTED] likes this.
  3. Feb 15, 2018 at 8:34 AM
    #243
    Hextall
    Hextall Well-Known Member
    NH
    17 Inferno OR DCSB
    I think with the 9100 you can do what you're asking. There's an extra trigger wire with the 9100 that you can program to turn on certain circuits if that wire senses current (I think that's how it works). It's an extra pink wire on the 9100 that isn't on the 8100.
    Unfortunately, I don't think there's a lot of information about the 9100 yet, all switchpro's videos and stuff reference the 8100.
  4. Feb 15, 2018 at 8:37 AM
    #244
    TACOVRD
    TW Addict
    AZ/WA
    Workin' on it....
    That’s kind what I was afraid of - I don’t want to tie up 4 switches to run 2 lights in 2 different on/off modes.
    Thanks for the info guys. I’ll likely still end up getting them since I’m more interested in the offroad lighting aspect I was just hoping to be greedy and have the best of both worlds occupying 1 switch only per light.
  5. Feb 15, 2018 at 8:46 AM
    #245
    My Truck
    Bay Area, CA
    You would only have to use two switches for both lights, not 4. One switch for the DRL wires both lights, and one switch for the main output of both lights. The LP9 amp draw is well below SP maximum per switch, even when combined. So long as you are okay with both lights coming on at the same time. Make sense?
    Also, all my knowledge is based on off the 8200, not the 9100. So the functionality you seek may very well be possible given the additional trigger wires they have allowed.
  6. Feb 15, 2018 at 8:49 AM
    #246
    TACOVRD
    TW Addict
    AZ/WA
    Workin' on it....
    I thought when I had calculated it out the amp draw for both LP9’s wired together was 18.2 amps and each switch is only rated for 18.
  7. Feb 15, 2018 at 8:52 AM
    #247
    My Truck
    Bay Area, CA
    That calculation is correct if running all wires and function to one switch. But, if you split the wires for the DRL and main output to two different switches, the draw is reduced.
    DRL: 1.52 amp draw per light x 2 = 3.04 to one switch
    Main output: 15.2 amp draw per light x 2 = 15.2 to one switch.
    Also, the new 9100 has 4 switches rated at 35amps per switch.
    CMScheid likes this.
  8. Feb 15, 2018 at 9:00 AM
    #248
    TACOVRD
    TW Addict
    AZ/WA
    Workin' on it....
    You sir are a genius!!!:hattip::cheers:
    Yeah I’d love to have a 9100 but I’m not going to bother upgrading.....maybe if I run out of switches I’ll get a second one....:spending:
  9. Feb 15, 2018 at 9:12 AM
    #249
    My Truck
    Bay Area, CA
    Glad I could help!:hattip::thumbsup:
    I know I had a hard time wrapping my head around it all until I finally got mine installed.
    It will all come down to the wiring harness BD provides, but I am sure they have all that accounted for.
    Also, I have a trick for getting the unit to dim with the trigger wire if you are in need of that.
    TACOVRD likes this.
  10. Feb 15, 2018 at 11:08 AM
    #250
    ThomasMore66
    Dallas/Fort Worth & Durango
    Sub'd
    These are awesome.
  11. Feb 15, 2018 at 11:34 AM
    #251
    Doc V
    Doc V Well-Known Member
    Caldwell, ID
    2013 Tacoma Double Cab Short Box
    Rear seat 12V Outlets Streamlight Flashlight Install Remote Start Bed lights Amber emergency lighting Aries Grille Guard ARE topper with ski-rack USB power point
    Hey @TAF_Taco where did you drill the hole for the panel wires? I tried on the rear surface(closest to the map light) of the housing but it still doesn’t close right?
    CBChief likes this.
  12. Feb 15, 2018 at 2:33 PM
    #252
    Doc V
    Caldwell, ID
    For those minds wondering about what the new 9100 has to offer here is the installation and programming guide. Sorry for the low-res the original size was 1.6mb over the file limit.
    TACOVRD likes this.
  13. Feb 17, 2018 at 2:00 PM
    #253
    mww982
    mww982 Well-Known Member
    Michael
    DFW
    2017 White TRD Offroad DCLB
    TRD Pro Grille Hondo Radio Nobs Black Bumper Caps ARE Camper Top -Full OME lift kit -Huskliner Floor Mats
    Having trouble getting the app to work on my phone. Try searching for the device in my app but it is not popping up? Any ideas?
  14. Feb 17, 2018 at 2:37 PM
    #254
    My Truck
    Bay Area, CA
    I have been having intermittent trouble with mine as well, but I have found that you do have to be withing a 10ft, and when first setting it up, the ignition need to be on for programming.
    Hope this helps
  15. Feb 17, 2018 at 2:40 PM
    #255
    TAF_Taco
    TAF_Taco Well-Known Member
    Patrick
    Lacey, Wa.
    17 TRD Sport Access Cab
    17" Method NV w/BFG KO2 CVT Rainier RCI bed rack Empyre Off Road grille Cali Raised bumper light bar/fogs
    I had to dremel a large portion off.
    CBChief likes this.
  16. Feb 18, 2018 at 7:00 AM
    #256
    joshtxedition13
    joshtxedition13 Well-Known Member
    Joshua
    Maryland
    TRD Off Road
    From the expedition outfitters mount? I just got mine and the switch pros doesn't fit in the cutout and the wire gets pinched when I try to close the sunglasses holder.
  17. Feb 18, 2018 at 10:14 AM
    #257
    Doc V
    Caldwell, ID
    I have the same problem. I am now torn on dremeling a notch in the EE mount or whether I relocate the wire to directly above the panel.
    EDIT: Or drill a hole to allow the cable bundle to pass through, but that would make the face of the bracket look funny.
  18. Feb 18, 2018 at 7:51 PM
    #258
    TAF_Taco
    Patrick
    Lacey, Wa.
    Through the sunglass holder up to the headliner.
  19. Feb 18, 2018 at 7:53 PM
    #259
    TAF_Taco
    Patrick
    Lacey, Wa.
    CBChief and joshtxedition13 like this.
  20. Feb 18, 2018 at 8:13 PM
    #260
    RuggedOverland
    RuggedOverland Active Member
    Jeff
    2016 Tacoma TRD Off Road
    None yet: that's why I'm here: need help
    You should not have to dremel the mount. You will just need to dremel the upper part of your console to allow it to open close smoothly.
    joshtxedition13 and TAF_Taco like this.
