Switch-Pros SP8100 Switch Panel Information & Discussion
Discussion in '2nd Gen. Tacomas (2005-2015)' started by ACEkraut, Jun 30, 2016.
  1. Apr 21, 2019 at 10:07 AM
    #301
    TWTaco
    TWTaco Well-Known Member
    Dave
    Anyone know if you can run 2 30" light bars on 1 switch? Total watts=240
  2. Apr 21, 2019 at 2:25 PM
    #302
    AKHawkeye
    AKHawkeye Well-Known Member
    Anchorage, AK
    15 AC Sport 4x4 6 Spd
    Locked as stock
    Watts Law:
    Watts=Volts(Amps)
    240=12(Amps)
    Amps=20
    So you would have a 20A draw with both light bars. Not sure if you have the 8100, or 9100. But the 9100 has 4(ea) 35A circuits, and 4(ea) 20A circuits. So you would be fine using one of the 35A circuits.
    seoulja99 likes this.
  3. Apr 21, 2019 at 5:34 PM
    #303
    TWTaco
    Dave
    Thanks for help.
  4. May 22, 2019 at 9:19 AM
    #304
    Gunshot-6A
    Gunshot-6A Prime Beef
    Conner
    Everett, WA
    '15 TRDOR / '17 Africa Twin
    Anyone else have an issue where the unit will just randomly cut out and then be in-op for a period between several minutes and several days, then randomly spring back to life like nothing happened?
    Been chasing gremlins trying to get it, and even Switchpros themselves are perplexed.
    Thought it was a loose 12v+ stud bolt, so that got tightened, then thought it was a bad connection on the blue wire, which fixed it for a little while. Now it is back to being finicky again.
    I have it wired in line with my bluesea fuse block on a powertray which is a common setup, so hoping someone else has this issue.
    Odd thing is it seems like it is temperature affected. Seems on cold/wet days is when it has the issue. It all worked fine when it was in the 60s and sunny, but now that it snapped to 40s and wet, it is having issues.
  5. May 22, 2019 at 10:00 AM
    #305
    DaMaDo
    DaMaDo Well-Known Member
    Northern AL
    2018 White TRD Pro
    It really does sound like a contact issue. When it's cold metal shrinks and looses contact. There are switches that can go faulty and have similar effect. Space Shuttle had the same issue where a switch would lose contact and give an error when they filled the tank with liquid hydrogen, but would work perfectly when empty. Took them a few cycles to figure out what was happening.
    Maybe remove the bluesea as a variable? Have you used a DMM to probe continuity around the system?
    Gunshot-6A[QUOTED] likes this.
  6. May 22, 2019 at 10:07 AM
    #306
    Gunshot-6A
    Conner
    Everett, WA
    So I have my HAM radio connected to the blue sea amongst other stuff, and even when the switchpro is dead, the radio still works just fine and shows the same voltage as my scanguage. That tells me continuity of the system as a whole is fine. The ONLY thing I haven't checked / retorqued / recrimped at this point is to replace the fuse tap connected to the blue wire. I redid the connection, but maybe the fuse tap is bad and it finally shit the bed... a cheap $1 chinese part is a likely failure mode. May have to go source one today at lunch.
    I'm thinking the issue is on the input side of the switchpro because of the bluesea working just fine.
    -Fuse tap to blue wire faulty
    -some switchpros had an issue where the seal around the power stud corroded internally and more or less fried the board. The fact that the issue is intermittent tells me this is a slim possibility.
    Temperature is very likely a factor at this point because all connections are solid at this point. Worked fine all saturday/sunday as I bounced it around a desert track, worked monday and on my way to work yesterday, then on the way home is when I noticed it went in-op again (about the time a cold/wet front moved in)
  7. Aug 20, 2019 at 7:45 AM
    #307
    ThomasMore66
    Dallas/Fort Worth & Durango
    BlakeyD and genghis71 like this.
  8. Sep 19, 2019 at 2:03 PM
    #308
    2barevo
    2barevo Member
    Any one know how to remove the bulk connector off the main box? Is white switch up or down? what a PITA to remove!
  9. Sep 19, 2019 at 2:48 PM
    #309
    crashdb
    crashdb I break chainsaws
    Dave
    Manassas, VA
    2008 Toyota Matrix
    Rollin' hydrocarbons!
    Where?
  10. Sep 19, 2019 at 2:50 PM
    #310
    2barevo
    2barevo Member
    Switch Pro main control box. Although I figured it out. There was a lot of corrosion inside. Going to celan it really good and use some dielectric grease to keep water out.
  11. Sep 19, 2019 at 3:05 PM
    #311
    crashdb
    Dave
    Manassas, VA
    2008 Toyota Matrix
    This seems to be part for the course.
  12. Sep 19, 2019 at 5:03 PM
    #312
    Caboose117
    Caboose117 foul mouthed Marine
    Chad
    Kentucky
    ;IGY6 Rescue Truck
    smashed this, broke that, covered it up with tape and paint
    Most commonly it’s from people mounting them flat with the connection facing up meaning anything that drops in from the top
    Stays in
    Switch-Pros even goes to length to say
    Do not lay flat it will corrode
    But alas.
    I’ve had mine for a couple years now
    Both 8100 and 9100
    No corrosion and it’s mounted against the bulkhead in the engine bay quite easily
  13. Sep 19, 2019 at 5:11 PM
    #313
    crashdb
    Dave
    Manassas, VA
    2008 Toyota Matrix
    Mine isn't vertical because there's no room for me to do so. I do, however, have it covered so that little to no water gets in. I've had one melt and the replacement is showing corrosion in places. I don't understand how you can market an item to the off-road community and not expect it to get wet, muddy, or whatever.
  14. Sep 19, 2019 at 11:32 PM
    #314
    Caboose117
    Chad
    Kentucky
    ;IGY6 Rescue Truck
    All of the systems to include spod are massively flawed in how they are able to be exposed to the elements
    They are both very susceptible to any form of outside elements
    But I think the Switch-Pros May be a bit more susceptible to temperatures creating cracks in the housing seals over time
    But the Switch-Pros is more safe in turbulent off-road heavy use as its protected from vibration by being solid state.
    There is no perfect switching system in my opinion but Switch-Pros is still by far the best.
    And honestly
    All high end products require maintenance and cleaning
    As for the melting thing
    I had a similar problem and Switch-Pros replaced my unit under warranty so in my opinion no harm no foul
  15. Sep 20, 2019 at 5:54 AM
    #315
    crashdb
    Dave
    Manassas, VA
    2008 Toyota Matrix
    So out of curiosity I'm wondering what reasons you have for thinking that the Switch Pro is the best. Not trying to start a debate, just wanting some differing opinions.
    To explain further: When I was looking at switch deals I wanted the sPOD. I based that mostly on the form factor. I liked that the wiring goes into the box and there isn't a huge plug hanging off it with unused wiring. On the same note, I like that the sPOD accepted the ground wiring as well. I also liked the way the box closed up. Not perfect, but it just appeared a better solution. Finally, I also liked the touchscreen.
    What finally budged me onto the Switch Pro was SDHQ's switch panel solution. It looks OEM and it's pretty awesome. To deal with my perceived short-comings with the Swith-Pro, I constructed a cover out of acrylic and used distribution blocks. It works, but it looks like a rat's nest and takes up a lot of room.
    Now sPOD has a Tacoma-specific switch panel mount..... I'm almost as the point where I want to remove the Switch Pro and replace it. So I'd like to hear your thoughts.
  16. Sep 20, 2019 at 9:36 AM
    #316
    Italia234
    Italia234 Well-Known Member
    Nick
    Tucson
    TRD offroad
    I emailed switchpros about some strange issues I’m having with my unit. Currently waiting to hear back from them. But in the mean time I was wondering if any of you have experienced any of these issues and how did you fix it.
    here is the email I sent quickly explaining what’s happening.
    Good evening,
    I was wondering if you could help me troubleshoot my sp8300. Over the last few weeks I have been having some strange issues that have seemed to develop from nowhere.
    I have been running the sp8300 for a while now with no issues. About 3 weeks ago the unit didn’t power on when I started my truck none of my switches would activate any of my lights or accessories even lights set up to battery. After checking the connections I was unable to find any issues. Later that day the problem seem to resolve itself just as it showed up. Haven’t had that issue occur since.
    Last week I had the Bluetooth activated via my iPhone the voltage that was showing was 8.3 while the truck was running. it was concerning because normally the voltmeter on the switch pro is pretty accurate. when camping this is how I check the condition of my battery. I connected a voltmeter to the battery and it was charging at 14.2. After once again troubleshooting what I could I found no issues. This too seems to resolve itself and was getting correlating readings.
    Now tonight I can’t seem to get the bluetooth from the switch pro to connect to my iPhone. With this issue I didn’t know what to troubleshoot. I restarted my phone, downloaded the app to another phone and the switch pro won’t show up in the devices. Unfortunately this problem has not seemed to resolve itself yet. I am able to use all the functions on the in cab mounted control only bluetooth is not working.
    I was wondering if similar issues have come up. Do they sound like wire connection issues? I was wondering if you had any suggestions on things to check or another way to get the bluetooth to connect to my phone.
  17. Sep 20, 2019 at 10:00 AM
    #317
    Caboose117
    Chad
    Kentucky
    ;IGY6 Rescue Truck
    Short of typing a bunch of tech stuff
    The easiest way I can explain this is as follows
    I was gonna buy an SPoD
    Even toured their shop and met the owner
    Super cool experience nice people ect ect
    Switch-Pros on the other hand
    I saw online
    Made a comment on their post
    And then they emailed me and we opened a business dialogue and 48hr later I had two of their units at my door and shortly soon after in my truck.
    The simplicity of the wiring made it quick
    Easy to organize
    No need to find a hole to fit a huge box in an already tight engine bay
    And room to move the whole module into the cab if I really decided to do that.
    Not as easy to move the Spod... still doable
    But not as easy.
    Ontop Switch-Pros also told me they can cut you custom length harnesses to order meaning length of this or that wire won’t hold back your choice of placement.
    I’m unsure if Spod will do the same without losing the warranty.
    Additionally
    My first 8100 did have a catastrophic failure that I wasn’t even around to stop
    (Thanks Toyota lexington)
    And it fully melted in a couple of places and two things immediately happens
    Switch pros jumped to the plate to help.
    And all my lights accessories and other items on my truck were all checked for damage.
    What we found was this
    Head unit- nuked
    Everything else in the whole truck?
    Protected and perfectly fine.
    On the other hand
    I know Spods will fail under the same conditions as the Switch-Pros
    But
    Do you know what will happen when it does?
    Will all your stuff be protected
    Will your unit get warranty?
    I don’t know... but I’m gonna stick with Switch-Pros
    And this shouldn’t matter at all
    But I’ll add it for conversation
    I also worked at Intel in research and development for 2 years building stuff like this for computers and then 6 years in the Marines working on this level of tech in satellites and communications vehicles and I as well carry a degree in various aspects of computer design and engineering. And after having both units from Switch-Pros and Spod in my hand...
    I’ll stay switch pros for life
  18. Sep 20, 2019 at 10:04 AM
    #318
    Caboose117
    Chad
    Kentucky
    ;IGY6 Rescue Truck
    If it was me
    I’d do this
    Check the Switch-Pros add a fuse in your cab and replace it with a freshie
    Pull all the cables for the Switch-Pros and check by hand and eye for visible cable damage or discoloring.
    Pull both plugs on the head unit and clean with a dry toothbrush where needed.
    Reinstall into your vehicle as if it was a new device following all Switch-Pros install instructions.
    If problem persist
    Then you’ve completed all the basic reasonable troubleshooting and all other issues will likely need resolving with help from Switch-Pros troubleshooting.
    Italia234[QUOTED] likes this.
  19. Sep 20, 2019 at 10:19 AM
    #319
    Caboose117
    Chad
    Kentucky
    ;IGY6 Rescue Truck
    Additionally
    Go take your battery to Vatozone and have them charge it overnight
    If your battery is failing it will make the Switch-Pros act funny to protect the power needed for the truck to run
    Switch-Pros will always cut its power if it’s putting a strain on the vehicle
    (When set up properly)
    G.T. likes this.
  20. Sep 20, 2019 at 10:40 AM
    #320
    crashdb
    Dave
    Manassas, VA
    2008 Toyota Matrix
    Thanks for the information. And thanks for not getting technical. It would have mostly gone right over my head. :)
    Caboose117[QUOTED] likes this.
