Switch-Pros SP8100 Switch Panel Information & Discussion
Discussion in '2nd Gen. Tacomas (2005-2015)' started by ACEkraut, Jun 30, 2016.
  1. Apr 21, 2020 at 6:39 PM
    #341
    paranoid56
    paranoid56 Well-Known Member
    San Diego
    14 double cab taco
    i dont know on the first one, as my race bug doesnt have a dimmer lol
    but on the second question, you can program any of the buttons to be hot on acc or always :D its super nice.
  2. Apr 21, 2020 at 7:31 PM
    #342
    ramonortiz55
    ramonortiz55 Not A Well-Known Member
    Ramon
    Texas
    2015 DCSB Offroad 4x4
    stock
    Oh wow.
    Regardless of how i wired the blue/yellow wires?
  3. Apr 21, 2020 at 7:36 PM
    #343
    paranoid56
    San Diego
    14 double cab taco
    the light blue still needs to be tied in to acc on power. as thats who it will know what type of power it has. yellow wire is for your lights or what ever you hook up..
  4. Apr 21, 2020 at 7:40 PM
    #344
    ramonortiz55
    Ramon
    Texas
    stock
    Thank you.
    Still doing a bunch of reading, want to make sure I understand what I am doing.
  5. Apr 21, 2020 at 10:16 PM
    #345
    Coop68
    Coop68 Well-Known Member
    Coop
    Erie/Dacono, CO
    2014 TRD OR Magnetic Gray
    Method double standards 16" COOPER S/T MAXX 285/75/16 DEI clifford 2-way remote start with smart-start. Lift Kings with Dakar TC UCA extended brake lines Keyless POP-N-Lock tailgate lock,relentless tailgate reinforcement, Weather Tech Mats all around, pelfreybilt front bumper steel with middle hoop warn VR-8000s switch Pro lights coming soon see build thread
    honestly never tried it I doubt it since you would have to wire into the dash lights in the cab. Switch pro has its own dimming with in the app or fallowing the program card. The yellow wire just tells it. You have your lights on when driving at night so it will dim the SP to what brightness you want.
    Depending how you program the SP will answer your second question. There are setting if you want it to run off battery or not. meaning one switch or all could stay on when the truck is off if you choose. Example my rock lights are set up this way so I can have lights On around the truck at camp.
    hope that helps.
    ramonortiz55[QUOTED] likes this.
  6. Apr 22, 2020 at 4:18 AM
    #346
    ramonortiz55
    Ramon
    Texas
    stock
    thanks coop!
  7. Apr 22, 2020 at 7:50 PM
    #347
    the dashing ham
    the dashing ham Taco n00b
    Scotty
    Los Angeles
    '12 DCLB rattle can
    yes, I have done the mods
    The switchpro backlight does not dim with the dash lights dimmer switch - the switchpro just watches that wire for any signal so it knows when to switch the backlight to the darker setting, so even if you wired the yellow wire into your dimmer circuit, it still wouldn't match. You can program what level of dimming you want using the app, but it doesn't sense your dimmer switch.
    Also using the app, you can program each switch individually to be always hot or only hot with ACC power. But you can activate any switch at any time when you bluetooth in using the app, regardless of whether the switch is set to always hot or ACC.
  8. Apr 22, 2020 at 7:57 PM
    #348
    ramonortiz55
    Ramon
    Texas
    stock
    thank you!
  9. Oct 11, 2020 at 11:47 PM
    #349
    Ponasaurus
    Ponasaurus IG: a_fishy_taco
    Pon
    LongBeach/Menifee
    15' DCLB TRD SPORT 4x4 SUPERWHITE
    Currently Building
  10. Oct 12, 2020 at 10:50 AM
    #350
    ardrummer292
    ardrummer292 500k or bust
    Austin
    Virginia Beach, VA
    2015 DCLB V6 A/T 4x4 1D6
    Overbuilt daily driver
    Possibly a dumb question, but here goes: How important is it to rig one of the external trigger wires so it tells the SwitchPro when the truck is turned on?
    I know the 9100 has 2 external triggers. I plan on wiring one trigger up to the low beam fuse so I can use the Master On/Off function with my foglights, which is necessary to pass state inspection. Similarly, I want to hook up the remaining external trigger to the high beam fuse so I can use the same Master On/Off function for my auxiliary high beam LEDs. That leaves me with no external triggers left to tell the SwitchPro when the truck is running. Big deal or not really?
  11. Oct 12, 2020 at 11:13 AM
    #351
    hoarder23
    hoarder23 Truck fell over
    Shay
    NJ
    15 Pyrite Mica DCSB Sport
    Scratches
    If you have a 9100 you’d get a better answer in that thread. Or call their support number, we called recently to get help with a non responsive switch panel and the person we talked to was quite patient and extremely knowledgeable.
  12. Oct 12, 2020 at 11:14 AM
    #352
    ardrummer292
    Austin
    Virginia Beach, VA
    I don't have anything yet, and I was under the impression that the 8100 had 2 external trigger wires.
  13. Oct 12, 2020 at 11:24 AM
    #353
    hoarder23
    Shay
    NJ
    Scratches
    You will have a hard time finding a new 8100 as it was replaced about 3 years ago. A second hand one may bring its own set of problems depending on prior usage.
  14. Oct 12, 2020 at 11:49 AM
    #354
    Coop68
    Coop
    Erie/Dacono, CO
    the 8100, basically has two wires one blue one yellow.
    Yellow is to only trigger or tell the sp you have turned on your lights so it dims the display unit in the truck.
    Blue, is for saying the engine is on that you have started the truck so it knows to power on. This allows you to program the switches for battery only and or only functioning when the truck is running. Ext...
    Not sure on the 9001, but assuming its similar.
    ok read into this more the 9100 new model has the external trigger this is a new feature if you want to have this you will need to buy the sp9100.
    the 8100 does not have this feature!
    ardrummer292[QUOTED] likes this.
  15. Oct 12, 2020 at 12:27 PM
    #355
    ardrummer292
    Austin
    Virginia Beach, VA
  16. Oct 12, 2020 at 12:31 PM
    #356
    Coop68
    Coop
    Erie/Dacono, CO
    nope i don't have any trigger wires that can control a function or limit a switch on my 8100. Cool feature see the reason they added it in for states with DOT requirements or a need for switches only being available for certain conditions you need.
  17. Oct 12, 2020 at 12:32 PM
    #357
    hoarder23
    Shay
    NJ
    Scratches
    Reading the instructions it looks like the 8100 has ignition and lights as inputs and the 9100 has ignition plus two other input triggers.
    ardrummer292[QUOTED] and Coop68 like this.
  18. Oct 12, 2020 at 1:13 PM
    #358
    ardrummer292
    Austin
    Virginia Beach, VA
    OH. I'm a huge idiot. I thought the 9100 only had ignition and lights. My mistake gents.
    Coop68 likes this.
  19. Nov 22, 2024 at 10:00 PM
    #359
    Uncle Cliffy
    Uncle Cliffy Never tell me the odds.
    Clifford
    So. Oregon
    06 DCSB 4x4
    https://www.tacomaworld.com/threads/uncle-cliffys-build.327590/
    Sorry for the necro-bump, but I'm wondering if anyone with an 8100 has had any bluetooth issues lately? Mine used to work fine, but after an app update or two it doesn't even see my unit any more. No blue light on the keypad either.
    I called the company and it gets weirder; I KNOW that I used to be able to program my unit using the app. You could change all the button functions like strobe, flash, memory ect. Switch Pros is saying that was never a feature on the 8100. And yes, I definately have the 8100. I bought one as soon as they came out!
    Anyway, just curious how everyone's bluetooth is working.
  20. Nov 23, 2024 at 8:02 AM
    #360
    Coop68
    Coop
    Erie/Dacono, CO
    I will have to test mine i still have a 8100 as well. Haven't used the bluetooth in a while but i was able to edit the switches as well back then.
    Uncle Cliffy likes this.
