Switch-Pros SP8100 Switch Panel Information & Discussion
Discussion in '2nd Gen. Tacomas (2005-2015)' started by ACEkraut, Jun 30, 2016.
  1. Dec 24, 2016 at 12:39 AM
    #101
    joemyself
    joemyself Well-Known Member
    Hey man,
    for the blue wire connection, is that a 5 or 10 amp fuse that you are using? Looks like it's the 5 amp that is provided (judging by the color). Does it work for you? For me, I used the provided 5 amp and the system works when ignition is turned halfway, however, when I start the truck the engine turns on and then turns off a second later. I'm thinking it has something to do with it not being a 10 amp?
    Let me know what you think, or anyone else that might know!
    Cheers
  2. Dec 24, 2016 at 7:24 AM
    #102
    Coop68
    Coop68 Well-Known Member
    Coop
    Erie/Dacono, CO
    2014 TRD OR Magnetic Gray
    Method double standards 16" COOPER S/T MAXX 285/75/16 DEI clifford 2-way remote start with smart-start. Lift Kings with Dakar TC UCA extended brake lines Keyless POP-N-Lock tailgate lock,relentless tailgate reinforcement, Weather Tech Mats all around, pelfreybilt front bumper steel with middle hoop warn VR-8000s switch Pro lights coming soon see build thread
    So the fuse you cant see is the red 10 amp fuse which is under the 5 amp fuse should be the orginal 10 amp fuse than the 5 amp with the add a fuse. two fuses per add a circuit. Check your fuses maybe its a bad one try swapping them out. I used a volt meeter to check for 12volts when the truck is on and when its off you want no voltage. Thats EFI fuse does that for the blue wire.
    If your only running the 5amp fuse and not the 10 plus 5 that could be the issue if you are i'd say try new fuses and see if that fixes it.
  3. Dec 27, 2016 at 2:29 PM
    #103
    CO MTN Steve
    CO MTN Steve Well-Known Member
    RaMbLiN' CoLoRaDo
    2015 Taco DCSB Blue
    Lifted, Armored, needs more lights.
    Man, My news years resolution is to get this thing freakin installed already!
    nfs257 likes this.
  4. Dec 27, 2016 at 11:23 PM
    #104
    adio
    adio Well-Known Member
    HI
    2015 INFERNO TRD PRO
    Finally wired up the bed/cargo lights to the SP8100. Man I'm still amazed that I can control the lights via BT.
    745F3E7B-EE7D-47AF-9DC7-9D5A19F0E4F4_zps_fa5dede32f3e0faea22f9686bccdac0169bee449.jpg
    BB70A0F0-6752-4DE8-A300-A439A95E2463_zps_f2caf2932b6e40ef6a2c539bd0aa42153772e9ab.jpg
  5. Dec 29, 2016 at 2:31 PM
    #105
    ramonortiz55
    ramonortiz55 Not A Well-Known Member
    Ramon
    Texas
    2015 DCSB Offroad 4x4
    stock
  6. Dec 29, 2016 at 2:31 PM
    #106
    ramonortiz55
    Ramon
    Texas
    stock
  7. Dec 30, 2016 at 3:38 PM
    #107
    Iggy
    Iggy Well-Known Member
    Northern CA
    09 4x4 Off-Road Access Cab
    Check out the build
  8. Dec 30, 2016 at 3:47 PM
    #108
    ramonortiz55
    Ramon
    Texas
    stock
  9. Dec 30, 2016 at 3:51 PM
    #109
    Iggy
    Northern CA
    Check out the build
    Yeah sorry the pic is for the other ones, but in the drop down you can select the SP. They look like this.
  10. Jan 27, 2017 at 12:06 PM
    #110
    DRJ1014
    DRJ1014 Well-Known Member
    CA
    Has anyone wired up something like these before?
    http://www.whelen.com/auto/product.php?head_id=12&cat_id=74&prod_id=648
    They have a Alley and puddle light wire separate from the caution light which can be activated separately.
    I am looking to do these types of lights, 2 left, 2 right, 2 rear and want to have controls for each side separately (left strobe pattern, left alley/puddle light on, etc)
    If I press ON (1 click) with the Switch Pros, will the caution lights revert to their programmed strobe pattern or will the light just stay on solid?
  11. Feb 10, 2017 at 11:12 PM
    #111
    SeekingZero
    SeekingZero Well-Known Member
    Ben
    Sierra Mountains, CA
    01 Xtracab 4x4 SR5 TRD Supercharged
    Anyone have any thoughts on wiring to an inverter. I have an 8 gauge wire to my 800W inverter now, wired to my blue sea fuse panel. I'm a little worried about moving that connection directly to one of the outputs on my 8100. Any thoughts?
  12. Feb 12, 2017 at 12:04 AM
    #112
    nfs257
    nfs257 Well-Known Member
    DFW
    She gone
    Don't do it. They have amp ratings listed. Even for my light bars I'm running relays because it couldn't handle it.
    seoulja99 likes this.
  13. Feb 12, 2017 at 6:53 PM
    #113
    the dashing ham
    the dashing ham Taco n00b
    Scotty
    Los Angeles
    '12 DCLB rattle can
    yes, I have done the mods
    Traded a few emails with Switchpros yesterday, and they say "green, blue and red backlighting available in 2-3 months."
    nfs257 and seoulja99 like this.
  14. Feb 16, 2017 at 11:38 AM
    #114
    HABOOBS
    HABOOBS Well-Known Member
    Bill
    Phoenix AZ
    2008 AZ-BASED DCSB
    Not mine... Saw it on IG... Posting it cuz I had never seen one mounted in this position before...
    ramonortiz55 likes this.
  15. Feb 16, 2017 at 11:54 AM
    #115
    XPOTRPR
    XPOTRPR CNC Programmer/Machinist
    Josh
    Chandler, AZ
    > BUILD LINKS >
    Have you tried a Switchpro? The exact same thing can be said about it. Curious about this statement.
    adio likes this.
  16. Feb 16, 2017 at 1:58 PM
    #116
    paranoid56
    paranoid56 Well-Known Member
    San Diego
    14 double cab taco
    I think what hes saying is that the switchpro doesnt have the output of the spod.
    spod has 6 40amp output
    switchpro is 8 Outputs, 7 rated @ 18A, 1 rated @ 30A
    so the switchpro would barely handle a standard small lightbar (200w bar @ 16amps)
    both are neat products though.
    nfs257 likes this.
  17. Feb 16, 2017 at 2:27 PM
    #117
    HABOOBS
    Bill
    Phoenix AZ
    2008 AZ-BASED DCSB
    There's also the new model w/ 8 switches at 30 amps as an option from spod... http://www.4x4spod.com/product_p/8-800-hd-jk.htm
    Pretty sweet...
    But still... for the price difference... at least back when we could get the 20-25% off coupon... I'll take the switch-pro any day. Then again, I'm only running lights on mine anyways so no need for the additional amp draw rating.
  18. Feb 16, 2017 at 2:38 PM
    #118
    XPOTRPR
    Josh
    Chandler, AZ
    > BUILD LINKS >
    Hmmm.. Im running all my lighting just fine. Including a 240w light bar.
    Price, ease of use, features. To each their own I guess.
    mytacoisweksos likes this.
  19. Feb 16, 2017 at 2:41 PM
    #119
    paranoid56
    San Diego
    14 double cab taco
    on the 18amp circuit? Good to know. I guess thats really only 2ish amps over the rating. Also, for the record, i would pick this one over the spod too. for the moment, I will just us the bussman setup lol.
  20. Feb 16, 2017 at 2:47 PM
    #120
    Synergy001
    Synergy001 IG: @pnwx.taco
    PDX
    00 ACLB -Daily, 16 DCSB -Adventure Rig
    Are you using the relay that comes with your lightbar or are you just connecting straight to the Switch Pros? Just wondering for when I get my Switch Pros in. Kinda sucks that I'll have to connect to the battery and then to the Switch Pros if I have to use the relay. Thanks in advance!
