Switch wire question
Discussion in '3rd Gen. Tacomas (2016-2023)' started by Tacomike18, Jul 18, 2020.
  1. Jul 18, 2020 at 8:52 PM
    Tacomike18
    Tacomike18 [OP] Well-Known Member
    J
    I bought this switch, I know one is ground (prob the black wire), one is power (one of the red wires), one is the backlight, but what is the 4th wire for and which wire is which? There is a green wire, two red wires, and a black wire. Thanks in advance.818BA744-E90F-4AF3-9102-443D33A5C139.jpgECFB18B4-5AAD-4EEC-9388-45DC6BB9683C.jpg
  2. Jul 18, 2020 at 9:04 PM
    TnShooter
    Deogee
    07' TRD Off-Road, Auto
    STOCK
  3. Jul 18, 2020 at 9:10 PM
    Tacomike18
    J
  4. Jul 18, 2020 at 9:21 PM
    TnShooter
    Deogee
    STOCK
    Correct, the fuse typically goes before the switch.
    The switch above, is only rated at 3a. And is generally used with a relay.
    Depending on how you wire the switch, you may not need to add a fuse.
    You could use an existing fused circuit in the truck. Such as the dome light or tail light.
    If you draw power straight from the battery to the switch, you should add a fuse.
    3A is not a lot, I’d probably go with a relay.
  5. Jul 18, 2020 at 9:23 PM
    Tacomike18
    J
    Thanks. I’ve recently added a front camera and figuring out the switch is the last part.
  6. Jul 18, 2020 at 9:32 PM
    TacoParty2020
    TacoParty2020 Well-Known Member
    2020 Tacoma TRD Pro Army Green
    I not that saavy when it comes to wiring. Where would red 2 wire to? where exactly would the dash light circuit be?
    davidstacoma likes this.
  7. Jul 18, 2020 at 9:36 PM
    Tacomike18
    J
    On the auto high beam push button, I’m going to put a test light with dash lights on and switch off to figure out which wire powers on with the dash light and possibly just alligator clip to it. I plan on putting the switch next to the auto high beam.
  8. Jul 18, 2020 at 9:38 PM
    tcjacado
    tcjacado Well-Known Member
    G8R_Taco and TnShooter like this.
  9. Jul 18, 2020 at 9:42 PM
    TnShooter
    Deogee
    STOCK
  10. Jul 18, 2020 at 9:43 PM
    tcjacado
    OP in that thread wired it to constant hot (always lit) though. I think they got it sorted out.
    TnShooter[QUOTED] likes this.
  11. Jul 18, 2020 at 9:49 PM
    Tacomike18
    J
    Honestly, I just want to have the switch operational and I’m prob just going to ignore the illuminate with dash light function for now.
    TnShooter and tcjacado[QUOTED] like this.
  12. Jul 18, 2020 at 9:51 PM
    tcjacado
    Basically it's a fuse tap on a circuit that's only on when the truck is on.
    TnShooter likes this.
  13. Jul 18, 2020 at 9:57 PM
    Tacomike18
    J
    So if I tap into the obd 7.5 amp fuse in the driver footwell area, it would light up only when the key is in the on position or engine on then?
    tcjacado[QUOTED] likes this.
  14. Jul 18, 2020 at 9:59 PM
    tcjacado
    Pretty sure that's correct. Just need to supply the illumination light with power when the truck is on.
  15. Jul 18, 2020 at 10:01 PM
    Tacomike18
    J
    I will try that. Btw I hear that fuse box lid in the driver footwell is a pita to get off and hear people have broken the tabs.
  16. Jul 18, 2020 at 10:03 PM
    tcjacado
    Yes it is and it won't fit back on after putting the fuse tap on. Meso makes a modified one that fits
  17. Jul 18, 2020 at 10:06 PM
    Tacomike18
    J
    That’s what the glove box is for, I’ve put so many small parts in there that don’t fit anymore after mods.
  18. Jul 18, 2020 at 10:07 PM
    tcjacado
    Btw....:hattip:
    Neighbor.
  19. Jul 19, 2020 at 8:06 AM
    Tacomike18
    J
    Maybe you could help me out here, here is the switch I’m replacing. Which wire is ground and which is power. I read online that black is power and red is ground but isn’t red usually power?image.jpg
  20. Jul 19, 2020 at 8:22 AM
    tcjacado
    Do you have a voltage meter?
