Switch Wiring Help
Discussion in 'Lighting' started by PlankRider6, Mar 18, 2017.
  1. Mar 18, 2017 at 5:08 PM
    PlankRider6
    PlankRider6 [OP] Well-Known Member
    Phoenix, AZ
    2014 Super White TRD DCLB 4x4
    I recently installed at Cali Raised 31.5" LED bumper light bar. The installation of the light itself when smooth however, I'm having some trouble with the switch wiring.
    I used the provided wiring harness and relay. I also "upgraded" to the OEM "bumper light bar switch" that fits in the factory blank. I spliced all the wires according to their instructions, however the switch always remains lit, even when the truck is off.
    The switch itself works fine and turns the light bar off and on as it should. I'm just having trouble trying to figure out why the switch is always lit, as this will drain my battery. I included a diagram below of what I've done so far. I figured the switch would light along with the headlights or DRL just as everything else does in the truck. Can anyone help me out with this please?
  2. Mar 18, 2017 at 5:18 PM
    oilslick
    oilslick Slicker than shnot!!!
    Big John
    northeast Pa.
    2017 DC 4x4 Sport
    Light Bar w/4 KC Off Road lights,
    Are there 2 red wires coming out of your switch?
  3. Mar 18, 2017 at 5:21 PM
    medic2230
    Murph
    Bama! Roll Tide
    The wire for the light on the switch needs to be hooked to one of the wires going to a light on the dash that turns on when your parking or headlights are on.
    Like the wire that turns on the lights for the A/C etc.
    wilcam47 likes this.
  4. Mar 18, 2017 at 5:24 PM
    windsor
    windsor Just a guy
    Homeless in Oregon
    2008 Tacoma Super Duty aka Tundra
    Canopy, fitted seat covers, OBA with self leveling air bags, 100w solar, dual Rhino Rack Pioneer platforms, side & rear LED work/FU lights, CB, cell booster. 7x16 cargo conversion, 3" lift, 7'x6.5' fold down aluminum rear deck.
    File IFR likes this.
  5. Mar 18, 2017 at 5:34 PM
    medic2230
    Murph
    Bama! Roll Tide
    What do you have red 2 connected to?
  6. Mar 18, 2017 at 5:50 PM
    PlankRider6
    Phoenix, AZ
    Please see my wiring diagram. I have the red closest to the green wire connected to the red from the relay. The second red (closest to the black) goes to the "add-a-circuit". The green wire is connected to the white wire from the relay and black to black. The red and black wires from the relay go to the positive terminal of the battery and ground.
  7. Mar 18, 2017 at 5:54 PM
    medic2230
    Murph
    Bama! Roll Tide
    It's the add a fuse lighting it up. You need the red 2 hooked to a dash light wire not to the fuse block.
    jimboemgee, wilcam47 and File IFR like this.
  8. Mar 18, 2017 at 5:55 PM
    medic2230
    Murph
    Bama! Roll Tide
  9. Mar 18, 2017 at 5:56 PM
    windsor
    windsor Just a guy
    Homeless in Oregon
    Move the add a fuse one space to the left.
  10. Mar 18, 2017 at 5:59 PM
    PlankRider6
    Phoenix, AZ
    If I completely take the add a circuit out of the fuse box the switch still stays lit and works the bar
  11. Mar 18, 2017 at 5:59 PM
    SocalOC
    SocalOC Well-Known Member
    2015 Sport
    17" rockstart 2 levling kit 285/70/17 toyo ipen country
    You need to find aux power ... for the switch light itself. Right now you have cont power which will never turn off .. get a light probe from auto parts only a few dollars and find it by playing with your lights. The bulb will light up when you find it and turn off when its off tha just tag into that
  12. Mar 18, 2017 at 6:03 PM
    cllowe24
    cllowe24 Well-Known Member
    Mid Tennessee
    2015 access cab
    Billstines with 885 coils 2”aal Lce header, pro dry drop in filter, charcoal filter removal, light bar in grill, ditch lights, yaesu dual band radio, and a bunch of other junk
    I have my circuit tap hooked to the power window block.
  13. Mar 18, 2017 at 6:06 PM
    medic2230
    Murph
    Bama! Roll Tide
    What do you have the green wire connected to?
  14. Mar 18, 2017 at 6:10 PM
    PlankRider6
    Phoenix, AZ
    The green wire is connected to the white wire from the relay. The relay goes to the bar, a black and red to the battery, and the another red, white and black that go into the truck for the switch
  15. Mar 18, 2017 at 6:10 PM
    Finch1018
    Finch1018 Well-Known Member
    Hampton Roads VA
    2015 DCSB TRDOR
    Build Thread: https://www.tacomaworld.com/threads/finch1018s-15-dcsb-build-thread.489528/
    Just experiment, I've had mixed luck with mic tuning switches, but as long as the black is hooked up correctly, you can horse around with the green and reds usually without penalty until you find the right combo. I did, truck hasn't blown up yet.
    PlankRider6[OP] likes this.
  16. Mar 18, 2017 at 6:11 PM
    PlankRider6
    Phoenix, AZ
    it doesn't matter where I plug in the tap the switch always has power from the battery even with the truck off. Do I have the red and black from the relay hooked up wrong, should it even be hooked up to the battery. I hate electrical....
  17. Mar 18, 2017 at 6:11 PM
    cllowe24
    Mid Tennessee
    2015 access cab
    I think I have green and red 2 together. Then red one goes to switch leg of my relay. I have my relay comming out of my aux fuse panel. The switch should not draw much power so if I remember right that's why I did it like that. All of your current will be on the relay.
  18. Mar 18, 2017 at 6:12 PM
    windsor
    windsor Just a guy
    Homeless in Oregon
    Green wire should go to a fuse that has power when the key is on. Black to a ground under the dash (I use the fuse panel mounting stud). Red 1 goes to 85 on the relay. Red 2, can go to an ign powered fuse or to a wire that gets power from the lighting circuit (I found that wire on one of the unused plugs hooked to a switch blank).
    I haven't looked at the harness that is sold with the lights. @CaliRaisedLed, please chime in on any differences with the harnesses from a basic wiring setup.
    I have 3 CH4x4 switches wired with relays how the above pictures shown. All 3 work exactly as they should. Only difference is my horn switch which has the factory horn circuit going to 30, 87A goes to 12v horns, and 87 goes to my air horns. Switch controls which horn will activate when I hit the horn.
  19. Mar 18, 2017 at 6:13 PM
    medic2230
    Murph
    Bama! Roll Tide
    I did a drawing for someone a while back for a different switch but it may be helpful for you. Let me see if I can find it. It has everything for a light bar drawn out. You should be able to tell what needs to go where just leave out the double wire for the other switch.
  20. Mar 18, 2017 at 6:14 PM
    medic2230
    Murph
    Bama! Roll Tide
    8 is the black wire on your switch
    2 is your green wire
    3 is (red 1)
    6 is (red 2)
    The dash light switch can go to any light that is triggered by headlight switch. He was mounting his in the center console was the reason for labeling it like that.
    Disregard the blue sea relay. The wire going to blue sea will go to your power point under the hood.
    Ignore my typo on switch too. lol
