Switch Wiring Help
Discussion in 'Lighting' started by PlankRider6, Mar 18, 2017.
  1. May 30, 2017 at 12:54 PM
    #61
    Taco_Tues_3rdGEN
    Taco_Tues_3rdGEN Well-Known Member
    Josh
    2017 Grey Tacoma TRD Sport
    TRD Pro Front Grille Pop&Lock Cali Raised Slim LED Light Bar TRD CAI
    Tail light fuse!
  2. May 31, 2017 at 10:26 AM
    #62
    WAGEN3-17
    WAGEN3-17 Member
    2017 WHITE TACOMA SR5
    I'm also going to be adding reverse back up lights on a separate switch what are people using to illuminate a second switch?
  3. Jun 8, 2017 at 10:12 AM
    #63
    WAGEN3-17
    WAGEN3-17 Member
    @madcity27 @Taco_Tues_3rdGEN, can I add 2 light switches to the tail light fuse and add a fuse connector? I was planning on tying the two wires together and then put them both in the add a fuse wiring. Hope that make senses.
  4. Jun 13, 2017 at 1:13 PM
    #64
    Taco_Tues_3rdGEN
    Josh
    Unfortunately I don't know.
  5. Jun 13, 2017 at 2:41 PM
    #65
    buyobuyo
    buyobuyo Read The Fucking Manual
    Jeremy
    Camden, AR
    08 PreRunner SR5, I4, Manual, Silver
    A thing or two...
    If you're just using the add-a-fuse to provide switch illumination, I see no problem with adding more than one. You just need to have the right size fuse to handle both.
  6. Jun 14, 2017 at 9:05 AM
    #66
    WAGEN3-17
    WAGEN3-17 Member
  7. Jul 8, 2017 at 6:16 PM
    #67
    cchicoine
    cchicoine Well-Known Member
    Caleb
    Bozeman, MT
    2017 TRD OR DCLB
    GFC V2 Pro, OME Nitrochargers and heavy springs, Dakar heavy leaf pack, ECGS Bushing, Firestone airbags, MBRP cat-back Exhaust, FabFours Premium front bumper, Winch, Cali Raised LED ditch pods, CB radio, Motegi MR150 bronze wheels 16x8 0" offset, Falken WildPeak A/T4W 285/75 R16, Relentless Fab Tailgate reinforcement, painted headlights, AVS wind deflectors.
    Just installed some @CaliRaisedLed ditch lights and wired it up to one of their switches. Like in their instructional video, I did not use an add-a-circuit simply because I dont have one right now. They said in their video that they just put the second red wire with the one closest to the green. I didn't fully understand this. Did they actually connect the two reds from the switch to the same wire or did they leave the second red switch wire not attatched to anything, just taped to the first red wire for organization? Right now I dont have the second red wire attached to anything and the lights and switch work perfectly... The lights turn on and off with the switch whether the engine is running or not, and the switch's light only comes on when you push it on. Do I need to put the second red wire to an add-a-circuit or can I just leave it as is? Thanks!
  8. Jul 11, 2017 at 8:19 PM
    #68
    JStarr
    JStarr Life Off the Road
    Jonathan KH6X
    Kaupo Southeast Maui, Hawaii
    Tacoma 3rd Gen 2017 quicksand TRD OR, T4R 5th Gen TRD ORP silver , Tundra 2000 TRD OR silver, Deere 5300 4wd, Wrangler 1994 ARB air lockers, 1998 BMW R100RTL.
    Installed a Caliraisedled bumper light bar and I want to add a fuse to take switched power, but I can't figure out which fuse in my 3rd gen fuse box to pull from. My recent build '17 TRD OR DCSB fuse box looks different from those I've seen posted as illustrations. Where should I put the tap?
  9. Jul 13, 2017 at 11:27 AM
    #69
    Powerprozeus
    Powerprozeus IG: @1987toyota4r
    Aaron
    Birmingham, AL
    2016 Quicksand TRD OR 4x4 / 1987 4Runner SR5
    Thank you! Thank you! lol I just installed mine two days ago and I've had the same problem. I couldn't figure it out for the life of me.
  10. Jul 15, 2017 at 10:38 PM
    #70
    JStarr
    Jonathan KH6X
    How can I find the tail light fuse in a '17 ? ai don't see it on the legend in the back of the fuse panel cover?
  11. Jul 18, 2017 at 5:53 PM
    #71
    Chase8059
    Chase8059 Kinda Well-Known
    Chase
    ESVA
    2015 DCSB TRD Sport | Super White : 2008 Lexus IS 350
    OME 887, JBA UCAs, 1.5 AAL, Fox 2.0 RR w CD adj., SCS SR8s Gunmetal, Falken AT3/W 265/70r17
    Just wanted to add this helped me alot.
    My harness relay harness consisted of Black, Blue, and Red. I substituted Blue for White in your instructions and the switch is working as intended
    Took me a bit of extra time since my relay came incorrectly wired from Cali Raised.
  12. Jul 19, 2017 at 5:09 PM
    #72
    Canadianguy91
    Canadianguy91 Well-Known Member
    Sean
    Halton Hills, Ontario, Canada
    2016 Limited
    Krown undercoating, Protect a plate, blindspot mirrors, Reese stainless steel towing ball, Bakflip MX4 tonneau cover, Tufskinz tailgate letter inserts, Console organiser, Tinted windows, LED interiors, Bed lights, Hood lights, Black Canadian flag decal (@bfeth), Oem bed mat, WeatherTech floor liners, Arctic Claw XSI tires, Recovery Shackle, Ultimate LED turn signals V3 @mesojdm, OEM TRD Off-Road tow hook, Bilstein 5100's with ARB's Old Man Emu 2887 coils, ICON progressive add a leaf, General Grabber ATX tires, Fuel ripper rims, Auxbeam F-16 H11 Led headlights, Borla S-type catback exhaust with black tip, custom powertray, vinyl badge inlays, (@rrentrop), Rear diff breather mod, Redarc trailer break controller https://m.youtube.com/watch?v=qqN7m1pc6AA
    does anyone know how i could use a fuse that isnt currently being used? I want to put on the led bed lights but dont want the wire just comming off the battery.
  13. Jul 27, 2017 at 10:30 AM
    #73
    Max5150
    Max5150 Well-Known Member
    Mark
    Corpus Christi, Texas
    09 SR5 DC 4x4
    Eibach Springs, Billies set at .85, 2" AAL Audio System: Pioneer AVH-X4600BT, Polk DB 6501, Polk DB 651s, Rockford Fosgate R2SD4-10, Alpine MRP-F320 Amp, Dynamat Sound Dampening
    Subd..
  14. Aug 9, 2017 at 8:35 PM
    #74
    sigrooms
    sigrooms Well-Known Member
    Sam
    2017 MGM Tacoma TRD Off Road 4x4 Auto DCSB w/JBL
    My Cali bar harness is different than all those mentioned thus far.
    2017-08-06 - 13:01:05.872.jpg
    My harness has the following colors:
    - Green with black stripe
    - Red with yellow stripe
    - Yellow with blue stripe
    I've emailed and messaged Cali a few days ago, but haven't received a reply yet. I don't want to cut away the shrink wrap on the relay wiring to see what wires are to what pins.
    A shame Cali hasn't resolved these wiring document issues. Otherwise their customer service has been great.
    JStarr likes this.
  15. Aug 10, 2017 at 3:32 PM
    #75
    buyobuyo
    Jeremy
    Camden, AR
    A thing or two...
    The Cali Raised harnesses are whatever they can get from China for cheap, so I wouldn't be surprised if they don't know. One wire will be power in, one goes to the relay, and the other is ground. If you have a multimeter, you should be able to figure it out fairly easily. One should go straight to the positive battery connection. One will go straight to the ground connection. The other will go to either pin 85 or 86 on the relay connector. The other of those two relay pins will be connected to the ground connection.
    Also, check the fuse that came in the fuse holder. It is probably WAAAAAY to big. My side projecting ditch lights came with a 30 amp fuse. Each light only draws 27 Watts, so the pair, worse case, draws 4.5 amps. I swapped it out for a 5 amp fuse.
  16. Aug 11, 2017 at 6:49 AM
    #76
    sigrooms
    Sam
    So this is what was conveyed to me from Blake at CaliRaised for my harness' differing wire colors. A shame they don't have this information documented thoroughly and freely available for their customers. I've wasted a good bit of time over this.
    SvenskTacoma likes this.
  17. Aug 27, 2017 at 12:54 PM
    #77
    Daver90s
    Daver90s Well-Known Member
    Hudson Valley NY
    '17 TRD Sport 4X4
    My wallet is empty
    I have the same question. Did you ever get an answer? I found the 7.5 amp fuse in the little fuse panel under the dash, inside the cab but It is too small to accept a fuse tap (without leaving the cover off) -
    JStarr[QUOTED] likes this.
  18. Aug 27, 2017 at 1:00 PM
    #78
    Canadianguy91
    Sean
    2016 Limited
    I was looking into that also. Thing is if u tap in the box under the hood
    how do you get your wire in there into the tap? You going to drill a hole through the box?
  19. Aug 27, 2017 at 1:02 PM
    #79
    Daver90s
    Hudson Valley NY
    '17 TRD Sport 4X4
    My wallet is empty
    Yes, that was my plan. Then seal the hole with some silicone. I'd just feed the wire thru the fire wall with the caliraised harness.
  20. Aug 27, 2017 at 1:06 PM
    #80
    Canadianguy91
    Sean
    2016 Limited
    I'm doing bed and good lights and was going to do that but just too nervous about warrenty issues. Obv I'm. It doing anything to affect it but just so they can't say anything I'm doing a inline fuse off the battery
