Switching to a cluster with a tachometer
Discussion in '1st Gen. Tacomas (1995-2004)' started by SpeedoJosh, Feb 7, 2013.
  1. Nov 27, 2013 at 8:41 PM
    grovestreet
    grovestreet Well-Known Member
    I am thinking it's 6 sparks vs 4
    that's why all aftermarket tach has a switch for 4/6/8 cylinders.
    For the OP
    Have you considered to buy an ultragauge?
    My instrument panel is just like yours and the ultraguage solved all my needs.
  2. Nov 27, 2013 at 8:57 PM
    offrdmania
    offrdmania Taco Wagon
    Templeton, Ca
    96 Tacoma LX 4 banger
    I dont think the OP will respond. The thread is super old
  3. Nov 27, 2013 at 9:21 PM
    SpeedoJosh
    SpeedoJosh [OP] Well-Known Member
    Florida
    2010 Access cab, Base, 4x4
    Haha. Yea. It's been awhile since I stated this. I have since made the swap to a 01+ cluster w/ a tach.
    Works great, and was pretty easy to swap once I got the right cluster. First one I got was from a 6cyl, so the RPMs were way off.
  4. Dec 2, 2013 at 1:19 PM
    wisconsin
    wisconsin Member
    Wisconsin
    2000 Tacoma California Spec
    OME Suspension,16" TRD Wheels,245/75R16 Nokian Rotiiva tires
    So, I ended up with two of the gauge clusters with tachometers, both of them are from 1998, and have the LCD odometers and black faces. I had no idea what engines they were from. My truck is a 2000, 2.7 liter, 4WD, 5 speed, 4.30 diffs, 31" tires. I took both clusters completely apart to see if any parts were different between them. All of the components were identical, except for the one part:
    The gauge clusters have a 'control module' that is a small circuit board - about 1.5" x 3". It is held into the back of the cluster assembly with two small philips screws. The printed circuit board plugs into this module with a black connector. The LCD odometer display also plugs into this circuit board. This board had different components on it (3 of the chips had different numbers) on the two that I looked at. By the way, this can be easily removed from the back of the gauge cluster without any disassembly.
    I put one of the clusters into my truck and went out for a test drive. I found that when my GPS speed was 60 mph, in 5th gear, the tach read 1,750 rpm's.
    I took the cluster out, and swapped the other control module into the cluster, and went out for another test drive. This time, at 60 mph on the GPS, in 5th gear, the tach read 2,350 rpm's
    This tells me that it is the 'control module' is the only component in the gauge cluster that is specific to either a 4 or 6 cylinder. The module I tried first was from a 6 cylinder truck, and the second one was from a 4 cylinder truck.
    I took some detailed pictures of the control modules and disassembly of the gauge cluster that I could post. Here are just a few of them:
    cruiserguy likes this.
  5. Dec 2, 2013 at 1:27 PM
    wisconsin
    wisconsin Member
    Wisconsin
    This is the V6 module labeled 06B. The 4 cylinder module was labeled 02F
    Left one is V6 - Right is 4 cylinder
    Top one is 4 cylinder - marked 017, and number 2 in corner
    Bottom one is V6 - marked 009, and number 6 in corner
  6. Dec 2, 2013 at 4:29 PM
    COMAtized99
    COMAtized99 Well-Known Member
    North Carolina
    99 DCLB v8
    The Bed is stock...ish
    A 4cyl Tacoma tach WILL work with a v8 Tundra engine... Ask me how I know....
    #postwhoreandIdontcare
  7. Dec 12, 2013 at 1:27 PM
    Z U L A N
    Z U L A N Member
    1998 Toyota Tacoma Reg Cab
    anyone know of a good site to find a 01-04 4cyl cluster?? Or just search ebay/junk-yards?
  8. Aug 3, 2018 at 3:57 PM
    baachor
    baachor Member
    Nevada City,CA
    2003 4x4 3.4l V6 5spd Extracab
    trying to figure out why my tach shows less RPMs...it is 03 V6 4x4...white with orange backlight
    what can be wrong? seems to me someone was going to dashboard as it is rattle (had to stick folded paper between board and window to make it stop lol)
    on picture going 60MPH on 4th gear tach shows only about 2300 RPMs!!:
  9. May 12, 2019 at 5:10 PM
    zms987
    zms987 Member
    Zachary
    1999 Toyota Tacoma
    My Tachometer on my 99 Tacoma V6 5 speed reads high and the difference gets greater with higher RPMs. One thing i do know is it was originally manufactured as an American truck sold in the USA and has such been imported into Canada and is now in KM's. Is it possible that the wrong tachometer has been put in ? I know it is off because my live engine data says so. Any help would be appreciated thanks
  10. Jun 2, 2019 at 7:38 AM
    Hooks98tacoma
    Hooks98tacoma Well-Known Member
    Georgia
    98 Tacoma 2.4
    Just thought about doing this swap in my 98. If I take the cluster out of an 01-04 it’s PnP into my 98? Simply want to gain a tachometer and have the white face gauges
  11. Jun 2, 2019 at 5:04 PM
    trdproven
    trdproven Well-Known Member
    its possible that you may have a wrong tach or it could be faulty or something going on with your electrical. but here is the general rule if you are buying another tach
    4cyl tach if you have 4cyl so 2.4 and 2.7 works either way. V6 to V6
    98+ i believe is already digital, don't quote me, you can confirm by checking if there is a cable behind yours
    to remove, just take out all the panels from the middle console to drivers side. you will be able to tell when you are doing it.
    cruiserguy and Hooks98tacoma like this.
  12. Dec 12, 2019 at 10:39 AM
    Frank319
    Frank319 Well-Known Member
    Monterey County California
    do you know if it matters if the donor truck is an automatic, and the truck that is going to is manual?
    specter208 and OG_Tacoma like this.
