Switch's 9-switch center console mount
Discussion in '3rd Gen. Tacomas (2016-2023)' started by switch, Dec 13, 2022.
  1. Dec 21, 2022 at 8:07 PM
    PTSDTherapy
    PTSDTherapy Well-Known Member
    22 SR5 DCSB
    Awesome. And right after I asked too. Already better customer service than a lot of companies. Headed there now. Thanks.
  2. Dec 21, 2022 at 8:17 PM
    PTSDTherapy
    22 SR5 DCSB
  3. Dec 28, 2022 at 7:24 PM
    switch
    switch [OP] Well-Known Member
    Norther California
    2022 Tacoma Access Cab
    That 12 Deutsch connector proved overkill (too bulky & wire gage too thick). I scaled down to a 18AWG connector which will address the 9 switch panel in the console.
    Now I'm looking at how to tie the wires from the 9 switch panel into my existing setup and my previous use of quick disconnects is not going to scale. What was a modest tangle of wires that was only embarrassing would become downright humiliating.
    The challenge is that I now have wires from switches in three locations:
    1: OEM switch panel
    2: truck bed
    3: proposed 9-switch panel.
    And I have wires going to relays located in the
    1: engine bay
    2: taillights.
    In summary: I have inputs and outputs going to four locations.
    I'm realizing that I need a central circuit board to route signals to all of these locations correctly. I just need to design a PCB circuit with the appropriate connectors and put it in a project box which I can print using my 3D printer.
    The circuit board would connect the various switches to their lights allowing for independent operation each light from the 9-switch panel and combined operation of lights from the OEM panel using appropriate diodes.
    What I need are PCB panel mount connectors that I can use to tie everything together in a compact location.
    I've started researching JST connectors, Molex, Deutsche, etc...
    I'm lost...
    I need automotive grade locking connectors (12 pin, 8 pin, 6 pin, and 4 pin) that I can attach firmly to a project box. Then I can change all of the quick connects to 4 plugs (one for each wire harness destination) that connect to a single box that does all of the electrical routing.
    [edit] 12/20/22
    I'm no longer lost. After too much research on connectors I realized these wires should simply be spliced and placed in protective sheathing. Problem solved...
  4. Dec 31, 2022 at 6:12 PM
    switch
    Norther California
    I got the 9-switch panel installed today.
    Cut hole in console for the wires:
    Wired up the switches
    I used this connector.
    If I had dreamed up this 9-switch panel eight months ago, I would not have bothered with the dash mounted switches. But since I had already spent the time and money on the dash mounted switches, I figured I should integrate them with the new 9-switch panel.
    Now the LED Light Bar switch in the dash controls the LED Light Bar in the front bumper and both cornering lights. And the sight lights switch controls both side lights on the A-pillars and truck cap.
    Here's a video of the 9-switch panel in action. As I press each dash switch:
    Front lights
    Side lights
    Rock lights
    Reverse lights
    Each switch indicates the light (or set of lights) that have been powered on.
    https://youtube.com/shorts/Wveg6hz_WkQ?feature=share
    https://youtu.be/Hq06zH8fCMg
  5. Apr 20, 2024 at 8:17 PM
    switch
    Norther California
    Here's another demo I did in the Sonora Desert:
    Each switch position corresponds to the geometric position of the light
    Top center: Front LED light bar
    Top corners: Left and right cornering lights on the bumper
    Sides: Left and right side lights on the A Pillar
    Rear corners: Left and right side lights on the ARE cap
    Rear center: reverse light in bumper
    Center: Rock lights
