Switch's dual battery setup
Discussion in '3rd Gen. Tacomas (2016-2023)' started by switch, Apr 30, 2023.
  1. Apr 30, 2023 at 8:58 PM
    switch
    switch [OP] Well-Known Member
    Norther California
    2022 Tacoma Access Cab
    Now that I've done most of my top priority upgrades, I thought it would be great to add a dual battery to my 2022 Tacoma.
    This project started 15 years ago when I did my .
    Since I am repurposing most of the parts from my '06 I'd refer you back to that post for more background info.
    On my '06 I used the space next to the main fuse block but there is not enough space on the 2022 Taco in that location for a battery. I used that location for a 6 fuse/relay fuse block instead.
    I did find a space next to the air intake box on the passenger side.
    In the photo above, you will see that I already stacked a pair of hex nut spacers on the top machine screw in that location.
    Next step: Cardboard mock up
    In this project I found it useful to make a plexiglass mock up to help me see what was going on underneath the battery mount
    I got a piece of 1/8" galvanized steel plate from a local scrap yard and cut it to shape:
    I was concerned about the weight of the battery on the top attachment machine screw since it was obviously not engineered for that purpose. So I added a weight bearing spacer:
    Here the mounting plate is installed.
    I mounted the Hellroaring battery isolator on some ABS plastic I had on hand
    So the (almost completed) project looks like this:
    The ABS plastic that holds the Hellroaring battery isolator is on top of a 1/4" aluminum plate that was also salvaged from my 06' project.
    The battery is an Odyssey PC 925
    The switch to use the backup battery is located in my dash and labeled "Power".
    The dash switch mount is from Fitzaprint on Etsy
    The switches are sold by CH4X4 on Amazon.
    Finished setup
    Spadi_5 and OBXPaul like this.
  2. May 1, 2023 at 4:19 AM
    Vmax540
    Vmax540 Well-Known Member
    Chuck
    Clarion PA.
    2019 TRD Sport 4X4 Access Cab Blue
    Nice work now, why the second battery ?
  3. May 1, 2023 at 11:52 AM
    switch
    Norther California
    Here's what ChatGPT had to say:
    Installing a second battery in your off-road truck can provide several benefits. Here are a few reasons why you might want to consider adding a second battery:
    1. Power for accessories: Off-road vehicles often have a variety of accessories that require power, such as winches, lights, and air compressors. Adding a second battery can provide extra power for these accessories, ensuring that they don't drain your primary battery.
    2. Backup power: If your primary battery fails, having a second battery can provide a backup power source. This can be particularly important if you're offroading in remote locations where getting a replacement battery may be difficult.
    3. Increased capacity: By adding a second battery, you can increase your overall battery capacity. This can be particularly useful if you have a lot of power-hungry accessories or if you need to run your vehicle's electrical systems for an extended period of time.
    4. Improved performance: A second battery can also help improve your vehicle's performance. By providing additional power to the starter motor, you can improve your vehicle's cranking speed and make it easier to start in cold weather or other challenging conditions.
    Overall, adding a second battery can provide a number of benefits for off-road enthusiasts. However, it's important to make sure that your vehicle's electrical system is properly set up to handle the additional battery, and that you use high-quality components to ensure reliable performance.
    I was mostly focused on item #2, since I already replaced my main battery with an Odyssey PC1700 deep cycle battery. But it does increase capacity by about 50%.
    Vmax540 and TriniPhantom like this.
  4. May 1, 2023 at 12:04 PM
    CLVol1255
    CLVol1255 Well-Known Member
    Tennessee
    2017 TRD Sport DCSB
    Bilstein 8112/8100 ICON RXT Stage 2 JBA UCAs Archive Garage HH w Shackles Archive Garage U Bolt Flip kit Nitto Ridge Grapplers 255/80/R17 TRD Front Skid and RCI Transmission Skid Kenwood DMX 1057XR Head Unit Focal Utopia WM 3 way plus WM10 Sub Mosconi 5/30 and Genesis Dual Mono Amp
    IMG_5540.jpg IMG_5552.jpg Very nice batteries! Love my dual battery odyssey with redarc setup. I recently added solar connections
  5. May 1, 2023 at 12:21 PM
    OnHartung'sRoad
    OnHartung'sRoad -So glad I didn't take the other...
    Somewhere in the Mojave Desert...
    2017 Tacoma OR 4x4 (formerly 2002 OR 4x4, 1995 4x4 4Runner, 1985 4x4 Toy PU) ... and RIP’s (rust in pieces) to a Bronco II 4x4 & S10 Blazer 4x4
    #2 is probably the most important reason for having a second battery, being able to jump yourself with a jump pack or a battery is essential for solo off-roading.
  6. May 1, 2023 at 8:15 PM
    Toycoma2021
    Toycoma2021 Well-Known Member
    Northern California, Temporarily
    2021 Access Cab, LB, AT, V6, Off Road
    @CLVol1255
    What are the two cables leaving the passenger fender going across the air intake for?
    CLVol1255 likes this.
  7. Jun 13, 2023 at 9:20 PM
    switch
    Norther California
    I guess I was not completely finished with this installation. I wanted to add voltage meters for both the main battery and the axillary battery.
    Here the led light indicates that the Hellroaring battery is working. And the two voltage indicators are for the main and auxiliary battery respectively.
    Maybe mount below the dash next to the cup holders.
    I don't need switches in this location but it made sense to explore the possibilities. Or a cell phone or map pocket?
    5 Switch version
    Or open for a cell phone.
    The main part conforms to the center console. I made it so the face plate can be changed to other displays/ switches:
    Face plate and length of the pocket can be modified to need:
    Need to move the LED light
    Skydvrr likes this.
  8. Jul 5, 2023 at 7:10 PM
    switch
    Norther California
    Still chipping away at the design for the LED voltage displays. I have switch positions available to the left of the steering wheel but I think it makes more sense to concentrate gages and a switch for the aux battery in one location. I also realized I have room for a third voltage display - like for my solar panel!
    So my current design has an LED light for the Hell Roaring battery isolator, three voltage indicators for OEM battery, Aux Battery, and Solar Panel, plus the switch to connect the Aux battery if needed. And a slot for my iPhone. Now I have to wait two weeks for a third LED voltage display. But I can get everything wired up...
  9. Jul 5, 2023 at 10:36 PM
    CLVol1255
    Tennessee
    2017 TRD Sport DCSB
    That’s my 50amp Anderson plug connector that runs to my solar panels
    Toycoma2021[QUOTED] likes this.
  10. Jul 18, 2023 at 6:24 PM
    switch
    Norther California
    I finally got around to completing the Aux battery switch, LED, and voltage displays. Something about the camera I used makes the digits appear a bit washed out but the voltage readings are very clear to the naked eye.
  11. Jul 19, 2023 at 6:49 AM
    shaggy135
    shaggy135 Well-Known Member
    Valley of the Sun, AZ
    2019 Barcelona Red TRD 4x4 OR DCSB MT
    Isn't it a little sketchy having those terminals so close to the hood latch?
  12. Jul 19, 2023 at 8:41 AM
    CLVol1255
    Tennessee
    2017 TRD Sport DCSB
    They’ve got a good 2 and half inches of clearance or more and it’s been trouble free for 3 years now. Even if I rear ended somebody everything is fused. At the terminals and at the red arc bcdc charger
  13. Jul 24, 2023 at 7:43 PM
    drkite
    drkite New Member
    2013 Tacoma
    Does the second battery charge in parallel with the primary battery from the alternator? Is it a concern to have two different batteries charging like that? I would like to do something similar, but can't find the space for another full size battery.
  14. Jul 25, 2023 at 6:19 AM
    switch
    Norther California
    That question would be better to ask Hellroaring (who made my battery isolator) but I can say that I never had any problems on my 06 Taco and I had the setup for 16 years.
  15. Aug 4, 2023 at 11:30 PM
    terryjm1
    terryjm1 Well-Known Member
    Terry
    2023 Tacoma
    Good stuff!
